Hello,
This is my first post on MTB but I'm on the site quite a bit.
I have a question about the bottom bracket setup on this bike. The bike was ordered directly from Devinci but it came to my lbs in a couple separate orders because they didn't have the bike in my size. So the lbs is building it up for me.
My lbs mechanic is having troubles getting the Shimano XT cranks to work with the PF30.
I have noticed on the Devinci specs it say the bb is a PF30 Adaptor.
TECHNICAL SPECIFICATIONS
FRAME
CARBON DMC-G
FORK
FOX FLOAT 32 CTD FIT 29 100MM, KASHIMA COATING
HEADSET
CANE CREEK 40-SERIES ZERO STACK
TIRES
MAXXIS CROSSMARK 29X2.10 EXCEPTION SERIES HIGH TPI
FRONT WHEEL
EASTON EA70 XCT
REAR WHEEL
EASTON EA70 XCT
FRONT BRAKE
SHIMANO XT M785
REAR BRAKE
SHIMANO XT M785
REAR DERAILLEUR
SHIMANO XT M780
FRONT DERAILLEUR
SHIMANO XT M786
FRONT SHIFTER
SHIMANO XT M780
REAR SHIFTER
SHIMANO XT M780 10S
CRANKSET
SHIMANO M785 HOLLOWTECH II 40/28T
BOTTOM BRACKET
PF30 ADAPTOR
CASSETTE
SHIMANO XT 10S 11-34T
CHAIN
SHIMANO XT HG94 10S
HANDLEBAR
TVT NOIR T30 FLAT
STEM
TRUVATIV STYLO T30 31.8MM
SADDLE
SELLE ITALIA SL XC
SEATPOST
TRUVATIV NOIR T30 31.6MM
SEAT COLLAR
ALLOY CNC 37MM
GRIPS
DEVINCI PERFORMANCE W/LOCK-ON
It seems weird that a bike from the factory would be using adaptors like WheelsMFG or others.
Does anyone know the proper procedure Devinci would use for this XT cranks with PF30 setup?
I can't get ahold of Devinci on the phone or email. I've tried a couple times.
Anyways, I just thought I would put it out there hoping someone or a Devinci factory mechanic might come across this and have an answer.
Thanks for any help
