Results 1 to 5 of 5
    jeb
    jeb is offline
    PEDROS synlube any good for bearings?
    I need to lube my bearings on my Intense 5.5 frame, i have Pedros synlube, that what i can get hold of in my LBS, will it work, or should i go for something more sticky, in a motorshop??
    Thanxxxxxxxx
    Jesper
    Wouldn't you use grease for the bearings?
    Low speed bearings are beter protected with grease and there is very little advantage in the friction department.
    Grease will last alot longer.
    I tried Pedros on some worn out wheel cartridge bearings, sure helped but it only lasted one or two rides.
    neutiquam erro
    Reputation: Chris130's Avatar
    Mar 2005
    Rock n Roll SuperWeb grease is the best thing for bearings, IMHO.
    Cheers, Chris
    ...idios...
    Reputation: SteveUK's Avatar
    Pedro's Syn is designed for use in bearings, so use it with confidence. I use it on my girlfiend's hubs (she likes that!) and I used it on my own hubs and headset before switching to components with sealed bearings. I still use it to repack the cartridges in my headset, but find it only takes a short while longer to simply switch the bearings in my sus. pivots, so that's what I do.
    Peas,
    Steve
    Diogenes
