Results 1 to 40 of 40
    Reputation: KevinGT's Avatar
    Dec 2012
    No way a through-axle makes that much difference...or does it?
    Last night, the parts arrived for me to upgrade my Yeti ASR-5 to a 142x12 through axle. I only did it because I love how easy it is to remove and install my front wheel with the QR15 axle. I also think it's more reliable after realizing my old 9mm QR had come loose on a ride.
    But I expected no other real benefit.
    I took it out for a 90 minute singletrack ride tonight. Are you kidding me? Sure, maybe I wanted it to ride noticeably better but I swear the bike has never felt or sounded this good. I don't want to say the rear end just felt more solid, because that's what the marketing people want me to say, but the rear end felt WAY more solid. I noticed it most when standing and climbing (at 49 years old, I'm not a fast descender with or without a through axle) but the whole bike felt much better. It even felt like the shifting was crisper.
    I'm sure 90% of the perceived benefit is just wishful thinking...kinda like when my car feels like it's running better after I wash it...but if any of this improvement is due to the through axle system, I should have done this when I built the bike!
    Reputation: thickfog's Avatar
    Oct 2010
    Re: No way a through-axle makes that much difference...or does it?
    See. Now I swear my car runs better after a wash too. Wtf is it?
    CRAMBA Chairman
    Hi There!
    Reputation: TheGweed's Avatar
    Quote Originally Posted by thickfog View Post
    My car knows it's been washed....it knows. Maybe your's does too.
    NTFTC
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    My car goes faster when i put stickers on it.
    Nov 2012
    Backpedaling and bunny hops fix 86% of unwanted bike noise
    Of course cars go faster when they are clean. Without dirt on it
    there is less drag and it weights less also.
    Reputation: Flamingtaco's Avatar
    Mar 2012
    I was having an issue with the 10mm rear axle flexing under my weight and pushing the rotor up against the pads. Using a 10 mm DT Swiss RWS (aluminum) with a carbon fiber sleeve to mate to a 12mm hub stopped that noise altogether, and impacts to the rear are more harsh, noted as I ride the road a lot with dry pack tires. If one can notice going from a 10mm steel to 10mm aluminum axle, yeah, a 12mm is going to beat the snot out of a 9m. WITHOUT the benefit of the rigidity of a through-axle setup.
    There's a reason the industry settled on 12mm thru-axle. It's a major improvement over 9mm QR, and is more than enough for what we need until you get into DJ and DH.
    I will suffer no butt-hurt fools!
    Reputation: aliikane's Avatar
    Thru axles do make a difference in peace of mind that your wheel is not going to fall off especially if you are going fast on very rocky or rooty chop where your wheel has a lot of deflection. I have had QR skewers where the lever released several times but wheel never fell off which is good. As far as stiffness goes, I don't think it is a noticeable stiffness difference.
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by KevinGT View Post
    In the case of through axles on long swing arms it really is not.
    You are directly attaching each side of the swing arm together instead of relying purely on the tension of the skewer, it makes a massive difference when you start applying twisting load to the tips of the swing arm (like hard braking and cornering).
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Agreed, it's a noticable difference.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Self Appointed Judge&Jury
    Oct 2000
    So what you're saying is your rear end is noticeably stiffer. Have you been working out.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by Fix the Spade View Post
    Quite a few riders were breaking the rear triangles on the Iron Horse MkIII and such (~2008). Mine was pretty whippy in the rear when it was new and the 10mm QR even worked loose once. I went with a bolt-on axle and it was a noticeable improvement. I don't huck big stuff, and the IH is the back-up bike to my back-up bike, but the triangle is still in one piece.
    I don't believe the OP imagined anything.
    -F
    It's never easier - you just go faster.
    Dec 2012
    C'mon, bro, do you even squat?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by Flamingtaco View Post
    No one has ever used 9mm in the back.
    Death from Below.
    Mar 2012
    Quote Originally Posted by Le Duke View Post
    Either you are familiar with all axle iterations worldwide, in which case I would be considerably impressed, or you like pointing out people's mistakes as means to discredit their knowledge. Either way, nothing was added to the thread.
    For clarification, The first part of that sentance (why the industry settled on 12mm) was referrring to the rear axle spec, while the remainder of the sentance was referring to the improvement in stiffness with 15 and 20mm thru vs 9mm QR on the front. I probably posted it at 5am after a long day of work, and hopefully a long ride on the bike as well.
    The current industry standard for road and mountain is 10mm axles in the rear, of course excluding thru-axles, so Le Duke is correct to a point. Truthfully I cannot say that no one has ever ridden on a 9mm rear axle.
    Thru-axles do make a difference in stiffness, especially as hub spacings get wider, they also help in the alignment of the hub in the dropouts.
    I like turtles
    Reputation: TiGeo's Avatar
    My next bike will certainly have thrus on the front/rear.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Good to hear that the rear TA makes a difference. I replaced my standard QR fork lowers so I could run 15mm TA, and at the same time replaced the stock wheels with XT/Stans Crest I got off eBay. I reamed the rear hub out to take a Hadley 10mm axle.
    Of course it rode like a different bike. I attributed most of it to the TA in the front, but glad to know that the effort and expense on the rear probably wasn't wasted
    meow meow
    Reputation: b-kul's Avatar
    i remember my sj fsr 29er with rear qr. the back wheel wandered around like it had a mind of its own. ill happily stick with through axles.
    Ride Instigator
    Reputation: Ricko's Avatar
    A clean car is a happy car and a happy car just runs better.
    ...Oh yeah, and I will agree that thru axel does indeed feel more solid too!
    ****** to the dirt
    So a solid axle feels stiffer, more solid and better in the rear.
    Apr 2014
    Quote Originally Posted by b-kul View Post
    My old Trek Superfly 100 was the same way. What a nightmare between QR axle, wimpy wheels and the ABP convert stuff coming loose.
    I like bikes
    Contains no juice.
    Nov 2003
    Quote Originally Posted by LittleBitey View Post
    43% of posts using percentages are wrong.
    Is my paycheck just a bribe to forget my dreams?
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    Quote Originally Posted by Finch Platte View Post
    Nope, resent studies have shown that is at least 48% with the margin of error of +15/-53.2%.
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Nope, you should clean the rear 100%
    All barks have been rendered into english...
    ****** to the dirt
    Quote Originally Posted by Deerhill View Post
    know any good ointments?
    moar alike..
    Dec 2009
    Quote Originally Posted by deke505 View Post
    Mild soap & warm water..NEVER use high pressure!
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    My QR seems to be stiffer when it's clean.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    ....or you like pointing out people's mistakes.... The first part of that sentance...
    i couldn't read any farther than this....
    Don't Tread on Me
    Reputation: Lopaka's Avatar
    Concerning 12 mm in the rear, I screen potential doctors by the size of their fingers. The doctor with the smallest hands gets my business.
    Consciousness, that annoying time between bike rides.
    Evolutionsverlierer
    Oct 2010
    Nah, just man up and enjoy the itch, makes riding way more fun, not that I know anything about that, that is just what a friend of a friend said.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    I heard the same thing, now I read it on the inter webs. Must be true.
    I don't rattle.
    moar alike..
    Dec 2009
    Huh? I never had an itchy axle, maybe use stiff joint cpmpound for that?
    Evolutionsverlierer
    Oct 2010
    I am a little out of the loop with all these terms you crazy young kids throw around nowadays but back in my hey days having an itchy axle was bad news all the way around and there was no cure whatsoever so I am not sure if I want to know what "stiff joint cpmpound" is code for.
    ****** to the dirt
    nah just rub it a little with some lube, it should help.
    I've been wanting to do the 10x135 QR to thrubolt conversion on my Stans rear wheel. I'd imagine it would help out on my Spark, my Scale...dunno.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '99 Spec' FSR Comp
    '9x Spec' Hardrock Cromo rigid
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I've always been able to feel a lot more difference attributed to frame design, rather than rear axle type. I've had a few 12mm rear thru axle bikes now, but the bikes that stood out as the stiffest had stiff rear ends (foes, several turner bikes, ). Wheel construction also makes a big difference. I won't discourage anyone from getting a 12mm thru-axle, they are great, but they don't fix a poor/flexy design.
    You know I'm not one to judge what you are into, but what you do off the bike is your business.
    Lead by my Lefty............... right down the trail, no brakes.
    Mar 2013
    The single change from cheap steel skewers to XT ones on my rigid steel commuter resulted in a dramatic reduction in road vibration and a much nicer feel so I can appreciate what the OP is saying.
    Silence! I kill you!
    Reputation: Jorgemonkey's Avatar
    Thats what she said!
    My photography website:
    Scott Mosher Photography
  1. Hi-Vis Makes No Difference?
    By mtbxplorer in forum Commuting
    Last Post: 06-15-2013, 03:57 PM
  2. Days of our lives: what a difference a day makes
    By heyyall in forum Off Camber (off topic)
    Last Post: 03-19-2013, 07:05 PM
  3. What replacement makes a bigger difference?
    By kikoraa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2012, 11:11 PM
  4. What a difference 10 degrees makes...
    By Ken in KC in forum General Discussion
    Last Post: 08-04-2011, 04:52 AM
  5. Tire size makes a difference in gear inches...
    By Dion in forum Singlespeed
    Last Post: 07-24-2011, 11:50 AM
