Results 1 to 7 of 7
    Downhill fan
    Reputation: #Cyclelife's Avatar
    Need to remove a few links from my new Sram cross step chain. I have a question.
    Can I use a regular chain remover tool to push a pin out and shorten the chain? I have used the chain pin removal tool many times on a Shimano chain and was just wondering if removing the pin/links on a Sram Cross Step chain is the same as my old Shimano chain? Thanx for any advice!
    I'm thinking about shreddin' it up right now!
    Giant Glory DH (custom)
    K2 Evo 4.0 FS XC (custom)
    Jun 2012
    Yes, as many links as you want.
    Downhill fan
    Great thanx for the confirmation!
    Downhill fan
    Confirmed. Removed 4 links from my new Sram PC991 chain with a regular chain tool. All good!
    Apr 2013
    How does one know if his chain is too loose? i've got some slack in my chain and i feel like i could take out a few links but how many is too many? Should i put it in the highest gear when shortening the chain?
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    Quote Originally Posted by lowtidejoe View Post
    Park Tool chain length sizing instructions. Go about 2/3rds down the page to the "Largest Cog and Largest Chainring Method", that's the method I always use. Basically, you put the chain around the big ring and largest cog and see the shortest link where the chain could be connected, then add two links to that.
    Downhill fan
    I just swapped all my stuff from a Shimano 3x8 to a Sram 1x9 and w/ a med cage rear derailleur (had a long cage Shimano before). In high gear (smallest cog) my derailleur had no tension on it and my new Sram chain was rubbing/dragging on the cage of the derailleur. No more rubbing and the shifts are a little snappier too.
  1. Sram component swap....chain question??
    By #Cyclelife in forum General Discussion
    Last Post: 03-01-2013, 06:50 PM
  2. SRAM 1071 chain (114 links) $29
    By mestapho in forum Where are the Best Deals?
    Last Post: 02-15-2013, 11:28 AM
  3. KMC / SRAM quick links 10sp
    By thecanoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-03-2011, 05:13 PM
  4. Dumb chain repair question - Why carry spare links?
    By murtaghstyle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2011, 04:13 PM
  5. SRAM 850 Chain question
    By morningmist in forum Beginner's Corner
    Last Post: 04-04-2011, 06:58 PM
