Results 1 to 7 of 7
    Need help deciding between these 2 pedals
    Im trying to decide between these 2. These will be my first pair so I don't necessarily need anything too fancy, just something that will work for now and I could get used to riding with these
    Amazon.com: Crank Brothers Pedals (Egg Beater 1), Stainless: Sports & Outdoors
    OR
    Crank Brothers Egg Beater C Clipless Pedals Eggbeater Clip Less Black Spring | eBay
    Thank you!
    Reputation: MSU Alum's Avatar
    I may be wrong but (I should preface all of my posts like this) I think the Eggbeater C is the older model that requires occasional lubrication whereas the Eggbeater 1 is the newer model with sealed bearings.
    Reputation: theMeat's Avatar
    Being able to rebuild at that pricepoint is pretty useless. Plus you're more likely to wreck the pedal before the bearings get worn. I like Candy's for some platform and it helps keep them protected a bit but that's not your question.
    The only difference IMO that you should think about is the ebay ones don't come with cleats.
    the strongest trees grow on the windiest plains... ~Tone's
    Thanks guy, im going to look at a few other models but ill probably end up buying the eggbeater 1 from amazon
    Front Range, Colorado
    Oct 2000
    TIME ATAC and don't look back.
    --------- __o
    ------- _`\<,_
    ************^^^^^^^^^Rock Garden
    Quote Originally Posted by frutistafreeze View Post
    That link says candy, but them's eggbeater 2. The 2s have the new supposed air/water tight design, but also wieght about 70 grams more if that matters.
    These are candy ++ candy1 pedals :: crankbrothers.com ++ They come in the same levels/models as eggbeaters. Either 1,2,3, or 11
  1. Help deciding which flat pedals for my MTB
    By PedroDank in forum Beginner's Corner
    Last Post: 12-08-2013, 12:22 PM
  2. XTR M980 pedals vs. XTR M985 trail pedals
    By jcard14 in forum Shimano
    Last Post: 08-03-2013, 10:14 PM
  3. Real Metal Pedals to Replace POS Plastic Pedals
    By mappable in forum Families and Riding with Kids
    Last Post: 02-26-2013, 06:49 PM
  4. Need help deciding on a pair of platform pedals.
    By jon777 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2012, 03:47 PM
  5. Need help deciding on a pair of platform pedals.
    Last Post: 04-06-2012, 01:13 PM
