Any markings on the BB shell?
The rear end is likely an AMP. The whole frame may be, too, though many small builders used the AMP rear.
mtbtires.com
Are we sure this isn't a Wal-Goose frame? Didn't some of the dept. store bikes come with the Amp-style suspension?
Geologist by trade...bicycle mechanic (former) by the grace of God!
2012 Specialized Stumpy EVO 29 HT
Thr rear suspension say Amp.
It also has a Noleen fork.
Heres another detail shot.
Rear derailour is a Sram X7
The serial #s are on the head tube. That's weird in its own right.
I say AMP for the back too.
Correct, the BB is bare.
I am with the AMP chorus, but I didn't know they ever made 1 1/8 headsets frames which I thought was the Mega-Air. When did AMP stop making bikes, I though it was before the 1 1/8 headset "relolution?"
And the Mega-Air . . . light and one of the first to push 32mm. The chrome stantions wore quickly for me.
whatever it is, it looks like it hasn't been used in awhile (maybe a barn find), or at least not well taken care of. rusty vee post bolts and pad hardware, rusty rear QR, rusty hardware on craptastic plastic pedals.
The way it's built suggests it was a quality build at one time, though. I haven't seen canti posts that were bolted on before. usually they're welded on. I'd say the curved top tube also suggests a better builder. This thing can't be newer than 2000, I'd say, and curved aluminum tubes were not common back then because it's not easy to do that.
 Originally Posted by shawnt2012
...the other two morons are bellowing like wookies in a bush waiting for a response back
The GPS Geek
What is odd to me is the v. low level rusty parts such as the brakes. The bolt on cable clips on the downtube are odd too. The rims look really cheap. Is that a Noleen shock on the rear? I still say Wal-Amp...I can feel it flexing through the picture
Could it be a K2 Razorback?
that was the mass produced bike with this suspension design I was thinking of but could not recall the name. I've never seen one in person so I'm not sure if any of the small details match.
The GPS Geek
Close, but I don't think so.
It is definitely "not" a K2 Razorback.
But it is a 1999' Titus Racer x
1999 titus racer x - Google Search
29'ers should come with a warning label affixed to the toptube.
WARNING: Objects may be further than they appear.
Could this thing be a Titus?
 Originally Posted by DIRTJUNKIE,
Hmmm i don't see the racer-x
The GPS Geek
What the links not working, it just worked for me. Click and once the black screen appears give it a minute to load.
Doesn't look like a Racer X to me.
Yeah you guys are right it's not. My brain can usually pick these old rides out. There were a number of knock offs with this basic frame design but for some reason they have escaped my memory. Time for some Ginkgo. It most definitely is a 1998-1999' time frame.
I'm trying to decide if I should rebuild it or not.
I would hold off until you figure out what you got. Although the components scream a good brand. The Noleen fork was concidered a good fork. They never made it main stream. Some companies used them to appear more high end than the norm. Most of the parts have been upgraded from the year of the frame.
- You may not post replies
- You may not edit your posts
Forum Rules
