Results 1 to 3 of 3
    Stiff yet compliant
    Reputation: vkalia's Avatar
    Mountain Morph problem
    So after all the great reviews the Topeak Mountain Morph has gotten, I decided to get one. Now, all my bikes have Presta valves.
    When I reverse the insert in the chuck and try to use this pump, I start having a problem. The cavity of the chuck (which goes over and fixes onto the presta valve of the tube) seems to not be deep enough, and as a result, attaching the chuck to the valve means that air starts hissing out pretty much all the time - and quite rapidly, too.
    This pretty much makes the pump useless.
    Looking at the design, it doesnt appear to be defective or flawed. So am I defective/flawed and missing some pretty obvious step, or is anyone else also having this problem with filling prestas?
    I like the idea of having a tube to attach to the tire, instead of the pump directly, and otherwise, I am very pleased with this pump. Anyone know if the Turbo Morph G also has this problem?
    TIA,
    V.
    EMD9, drop-bar Bandersnatch, Surly LHT, a couple of Ridleys
    ... and a lot more bruises than can be counted
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Most...
    Quote Originally Posted by vkalia
    TIA,
    V.
    Mmost mini pumps have two inserts that require changing to switch between presta and schraeder valves.
    1. The rubber seal.
    2. A plastic insert underneath the rubber seal that has an open hole on one side (presta)and a plastic knob in the center of the insert to depress the schraeder valve on the other side.
    Stiff yet compliant
    Doh, you are correct. So the defect/flaw was with me.
    In my defense, in my other 2 pumps, there is only one bit that needs to be flipped, not 2 (just checked - apparently, the insert and seal are combined into one part).
    Thanks for the help, Ken!
