Results 1 to 3 of 3
    Reputation: gabriel10's Avatar
    Marzocchi 22 RLO (travel 120mm)
    Im about to replace my ol' dirt jumper, but i cant be picky considering my actual financial status.
    Ive decided to go for Marzocchi 22 RLO travel 120mm even if i might be pushing this marzo 22 a bit over the limits:
    - a 203mm disc brake;
    - style or riding: on Marzo DJ - everything/anywhere - all mountain (freeridish).
    I know ill have to pace myself when riding 22 (obvioulsy) and i know ill be drooling all over the freeridish trails. Now, my question is how long will i be able to ride this 22 ? Will the 203mm rotor kill the fork?
    frame Specialized Rockhopper, weight 155lbs.
    EDIT
    RockShox Dart 3 or Marzocchi 22 RLO ?
    Huckin' trails
    Reputation: David C's Avatar
    Freeride with less then 150mm won't hold up very well... 203mm rotor idk, but you will just blow out through the full travel when freeriding... I have a 150mm Marchozzi air, I'm 110lbs and I can easely blow out the travel on it while freeriding (with good preload and SAG, off course) and I ahve a Dart 2 80mm on my trail bike, which I also blow out the travel when doing light AM, good XC, so 120mm of travel won't get you anywhere close to what you want...
    Check chainlove.com, they had a few Marchozzi forks on sale more then 60% off today... a 55 Ti r and a 66 Ti RC3, the 66 was only $560 (over $1 000 new)... Just wait and you could get a great deal...
    And you should get a fork that is the right spec for your frame... and 203mm rotor are usually for bigger stuff then 120mm fork would be design to handle...
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Huckin' trails
    Here you go...
    Marzocchi 44 Micro Ti... 150mm of travel, air spring, open bath oil Damper, compression adjust, lockout...
    $280 free shipping... just need a front hub with 15mm axle...
    Marzocchi 44 Micro Ti Fork from Hucknroll.com
    David
  1. Marzocchi 33, 120mm travel
    By pooky in forum Shocks and Suspension
    Last Post: 04-27-2009, 06:39 AM
  2. Replies: 0
    Last Post: 02-11-2009, 10:00 PM
  3. A fork under 350 dollars to replace: MARZOCCHI MZ COMP, 120MM TRAVEL
    By drain bamage in forum Shocks and Suspension
    Last Post: 12-13-2008, 07:24 PM
  4. Replies: 1
    Last Post: 11-04-2008, 01:43 PM
  5. marzocchi MX pro lockout air 120mm travel fork
    By SeanyRocket in forum Shocks and Suspension
    Last Post: 07-15-2007, 07:02 PM
