Results 1 to 3 of 3
    Mallet C - two questions
    #1 - I was wondering if it is possible to remove the eggbeaters from Mallet Cs. Just for jaunts to the skills park or any other time I just want to ride flats. Something tells me the answer to this is to just buy a pair of flats and swap them in and out... but I thought I'd ask.
    #2 - Somehow one of my Mallet C pedals is on so tight that I can't get it off. Have tried everything I can think of, including using a cheater bar which only resulted in a broken allen wrench. Any ideas? (yes I am turning the wrench in the proper direction)
    Thanks for your time.
    Aug 2005
    Quote Originally Posted by thepaul
    you probably can take the eggbeater portion of the pedal off but it it would invovle removing the outer screw and diassembling the whole pedal - probably not worth it.
    if your pedal is not threading out take some Tri-Flow spray lube, spray it on both sides of the pedal threads, let it sit for a few hours, then try and taking the pedal off
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    The Mallets don't provide any traction. Only easy casual rides would be ok, casual like on the sidewalk. You would be better off buying some flats and changing out.
