Results 1 to 7 of 7
Thread: Loctite ?
    Reputation: rickcin's Avatar
    Loctite ?
    Should I be using this on bottle cage and frame pump bolts?
    Diggity Dog
    Reputation: ShinDiggity's Avatar
    No, grease is fine. Loctite would be OK but is too expensive for that application.
    Reputation: mtbzarg's Avatar
    Oct 2011
    Yup, just some grease.
    Plays with tools
    Reputation: customfab's Avatar
    If they stay snug grease is fine, unless one or the other is titanium then you need to use anti-seize. If they keep coming loose I wouldn't hesitate to put a little bit of 242 on them.
    242? Not sure what that is.
    Reputation: 11 Bravo's Avatar
    Quote Originally Posted by rickcin View Post
    242 is the blue thread locker. Bolts can be removed with simple hand tools.
    262 is the red loctite and is permanent. You often need to heat the parts to get them apart again. A lot of heat is usually required. The product sheet says 482 degrees F to break it down. I never use it on small fasteners, but on bigger bolts, like over 3/8" an impact wrench will usually remove them. Many times I do have to take the torch to them though.
    I'm not very smart, but I can lift heavy things
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    243 is the latest medium, strength formula, works better on aluminum and plated parts...
    Not nearly as runny as the old 242 product too!
  1. Loctite #609/680 woes...
    By mtbhead in forum Santa Cruz
    Last Post: 06-09-2011, 05:16 AM
  2. Loctite? which?
    By BBW in forum Turner
    Last Post: 04-28-2011, 09:26 AM
  3. Loctite 3479
    By istrabike in forum Frame Building
    Last Post: 04-26-2011, 05:41 PM
  4. Loctite in Lever
    By rmontgo21 in forum Brake Time
    Last Post: 04-05-2011, 02:50 PM
  5. Loctite 608. Where to get some around here (South Bay)
    By ziscwg in forum California - Norcal
    Last Post: 04-04-2011, 06:07 PM
