Results 1 to 9 of 9
    siv
    siv is offline
    Reputation: siv's Avatar
    Lock-on grip bolt head stripped, now what...
    Do I have to drill them out, that will ruin the threads of the grip as well. Any tricks?
    discombobulated SuperModerator
    Jun 2005
    Quote Originally Posted by siv
    Its not fun...Not sure of the material of your bolt...Drilling it is most likely the remedey, with an "EZ out". Hopefully
    If it the bolt is in a clamp like I have on my ODI's, ruining one clamp is not the end of the world.
    Not sure what size bolt it is, but I like to think its 4mm...Coarse most likely.
    http://www.engineersedge.com/manufac...rill-chart.htm
    That lists the TAP drill to tap an object with that thread. I would go smaller to be safe.
    Something like this , you need a good assortment of drills in tiny increments....
    CDT
    plasma donor
    Reputation: Barkleyfan's Avatar
    http://www.irwin.com/irwin/consumer/...IrwinCat100497
    Threads will be fine. You can get these at most hardware and autoparts stores. I would recommend the spiral rather than the straight flute.
    Reputation: stretch169's Avatar
    I have found that if I use Vice grips to compress the clamp itself it takes a lot of pressure off the bolt and I can usually get it out. If not I spin the clamp and take a hacksaw to the bolt.
    Pivot Firebird, Tomac Snyper, KTM 250SX
    yeah, uh............bikes
    Reputation: FloridaFish's Avatar
    dremel tool and new grips.
    Drill Out the Screw HEAD
    Nothing but a drill bit needed here.
    No easy-out type stuff.
    With a drill bit about the size of the screw head, drill the screw HEAD.
    Stop pushing when the screw head spins with the drill bit.
    Once the screw head is removed, tension is released and the collar can be removed from the Hbar.
    The remaining threaded part of the screw is now easily removed.
    If not, it will have a perfectly centered cone from drilling the HEAD to start a much SMALLER drill bit to screw the threaded piece out. (clock-wise bit rotation turns screw out through the hole.
    Reputation: rabidchicken's Avatar
    Use a dremel tool to cut a screw driver slot in the bolt head.
    Te mortuo heres tibi sim?
    Quote Originally Posted by rabidchicken
    yep. or cram a small torx into the thing. that has worked for me.
    crash test dummy
    Quote Originally Posted by scrublover
    Yes. I had 3 stripped cleat bolts and tried drilling (couldn't find an inexpensive metal bit hard enough) and screw extractors. In desperation I pounded a cheap torx bit in there (I have a Craftsman screwdriver that takes replaceable bits), turned it and the bolts came right out. Didn't even seem to damage the torx bit either. Good stuff, craftsman.
