Results 1 to 14 of 14
    Knee position while riding
    I was riding road bikes a few weeks ago with some buddies that don't ride MTB and they commented that I seem to ride with my knees spread out too far. They said that the problem is that you don't utilize the inner quads (Vastus Medialas) as much as you should when your legs are too far out. I told them it was because my package was so big that the legs wouldn't go any closer, they didn't buy it.
    The only thing I found online was a short video saying that ideal position is about shoulder width. I was watching some pro cycling and it seems that some guys ride with knees way in and others are about shoulder width.
    I raised my seat and that seems to help me keep the knees in. Also I have really been focusing on knee position, in case it is just a bad habit I've adopted. Any thoughts on where your knees should be as you pedal.
    nvphatty
    Guest
    knees inline facing straight ahead is optimum. splayed outward will result in knee pain and undue stress on the joint.
    First if it hurts don't do it....
    Second carry a mental image of flashing the knees upwards as the foot comes up....
    This will help unweight or maybe even provide some up lift...
    But more importantly the knees will tend to fall in to line "where they should be"...ie a neutral postion niether in nor out...
    Once you establich the neutral position try to practice riding there...more and more, and of course to the mental image of flashing the knees up...
    I would think that the pros would also practice riding with knees in just to get a little more aero...
    Lastly watch your knees if the come up straight then kinda pop outwards at the top...you probably need to raise the seat a bit....and get some physio advice.
    Are you using flats or clip in? If clip in you might need to move your cleats or get fitted .
    I have Flat Pedal shame.
    Ya, I always get a kick out of the roadies with their knees way out. Your knees should move straight up and down close to the bike. Anything else is asking not to be able to ride due to knee pain.
    We don't ride to add days to our life, we ride to add life to the days we have left here.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Thustlewhumber View Post
    Ya, I always get a kick out of the roadies with their knees way out. .
    Ride More, Work Less
    Reputation: heyyall's Avatar
    You should go to an lbs and get a fit. Your saddle could be too wide, too low, in the wrong position, etc. your feet / cleats could be poorly placed on the pedals. You like need to gain some flexibility, too.
    As for my knees, I like a lot of pedal float and I find my knees move in towards the top tube when I loosen up.
    Craigslist & MTBR --free ads for all
    gobsmacked Moderator
    Quote Originally Posted by J.B. Weld View Post
    I agree. I can't remember ever seeing a roadie with their knees splayed out.
    nvphatty
    Guest
    Quote Originally Posted by girlonbike View Post
    i have numerous times.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The size of your junk shouldn't affect how wide your knees are when pedaling. When one leg is up, the other one is down. Generally it's advisable to have your genitalia out of the way, you'll need form-fitting undies for this.
    My preference is knees straight ahead. Sometimes I tuck them in a little bit thinking there's an aero advantage, but I don't actually believe it matters much.
    Quote Originally Posted by nvphatty View Post
    LOL......assuming the bike is exempt here
    Quote Originally Posted by rangeriderdave View Post
    I'm using SPD's but I don't think I really need to change their position to pedal knees in or out. There is enough freedom in my cleats. I think mostly this is a bad habit I've crept into. There was no knee pain or pressure. Even as I focus on keeping the knee more inline there is no pain or pressure. I noticed last night that it seems to becoming more natural to keep the knees in.
    9 lives
    I developed MCL pain a few months ago. Medial Collateral Ligament is the knee ligament located on the inner side of the knee joint.
    I had a tendancy to ride with my knees turning inward rather than straight ahead. This was a riding style I developed with road cycling. My improper knee placement has put strain on this ligament. I am working with my cross fit coach to correct this habit because it has effected my weight lift technique specifically when doing squats. My knees start to rotate inward especially when I'm adding heavier weights. I'm now making a conscious effort to ride with my knees straight.
    Its better to make the corrections now rather than undo old habits.
    F*ck Cancer
    Eat your veggies
    Flexibility issue is a real possibility. Might want to look into some IT band stretches.
  1. Is it just my riding position?
    By AlexDeLarge in forum 29er Bikes
    Last Post: 11-20-2013, 08:05 AM
  2. Knee pain and foot position on platform pedals
    By The111 in forum Beginner's Corner
    Last Post: 07-18-2012, 01:12 PM
  3. Dialing in Riding Position
    By dirtrider7 in forum 29er Bikes
    Last Post: 03-04-2012, 02:06 PM
  4. Is it Ok to Ride before Knee MRI?? Knee turns very warm (blood flow?) while riding..
    By jrl1073 in forum Rider Down, injuries and recovery
    Last Post: 10-01-2011, 05:58 AM
  5. Stumpjumper FSR, riding position tips
    By InlawBiker in forum Specialized
    Last Post: 06-22-2011, 05:07 AM
