Results 1 to 13 of 13
    Mar 2013
    Knee Damage from seat being lower a inch or so?
    I normally ride with my seat a inch or two lower than what it should be to help move my butt toward the rear easier. Would this call long term damage to joints? Been thinking about just putting tape on the seat and when I ride trails lower it, when I ride greenway raise it.
    Dec 2005
    dropper-post dawg
    Professional Crastinator
    Reputation: Fleas's Avatar
    I've found I get pain in the tendon above my kneecap if my seat is too low. If you're not in pain, then you are probably not having any negative effect. Some people like to pedal with their feet more in front of them, too. With your seat slid back on the rails and running a little lower, you might be perfectly comfortable. Although, then you have to get even further back to clear your saddle on sketchy sections.
    -F
    PS - I have been riding with my feet flat, not toes-down, and it helps give me an extra inch of leg extension to work around the saddle. It feels a little weird.
    It's never easier - you just go faster.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Yes, long term and if you put in a lot of miles, you'll get knee damage.
    I'm a mountain bike guide in southwest Utah
    Mar 2013
    Quote Originally Posted by Silentfoe View Post
    How can this be so? I'm talking about lowering the seat enough to be able to move behind it.
    Quote Originally Posted by Fleas View Post
    -F
    Thanks! I'v been moving around on the saddle to see which position I like more as well as toes down vs flat.
    HTFU!
    Reputation: S.O.B.'s Avatar
    If you are young, and not experiencing any knee pain, and are just riding (not racing, or riding endurance epics...) then there is no problem. When I was young, I rode all types of bikes. Sometimes I was too stretched out, sometimes my knees came to my elbows, didn't care, just rode. But now as an older guy with a couple knee operations behind me (not biking related), I need to have my bike dialed in just right. If you are going for optimum performance, small changes in crank arm length, stem length, bar rise and seat height can have a major impact on fit, feel, comfort and performance.
    Good Luck.
    I no longer deserve a signature.
    Oct 2012
    If you lower the seat an inch it has the same effect on knee angularity as using a crank an inch longer; would you use a 200 mm crank? OTOH, if you only use force when you're standing and just soft pedal sitting down, then you'll be fine.
    Compared to knee damage, a $250 dropper post is a bargain.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    correct.
    "ORANGE IS THE NEW BLACK"
    Reputation: MSU Alum's Avatar
    I'm guessing a physical therapist, if you know one, could give you detailed info on whether it would or not and why.
    +1 on dropper post.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I rode with my seat an inch or two low for years. No knees issues at all. It does work your thighs more than a proper position, but I never had any issues.
    I now have a dropper post, but the only time I have the seat all the way up is for climbing or mellow flat sections between or on the way to the trail.
    14 Aurum, 16 Fuse, 17 T130
    Mar 2013
    what kind of seat post do you use Mr. Lynch? Most of the time I'm on the greenways doing endurance or cardio. I will use the gears for a more "resistance" workout. But when I hit the trials I like the seat to be a tad bit lower to move around on.
    Looked at the rockshox
    Jun 2010
    I run the Specialized command post. It came with my bike and I really love it. So much so I put one on my 29er HT too.
  1. Replies: 27
    Last Post: 08-09-2013, 10:59 PM
  2. injury of outside of lower knee
    By brankulo in forum Rider Down, injuries and recovery
    Last Post: 02-16-2013, 06:19 PM
  3. lower quad/knee pain.
    By wizzer16 in forum Rider Down, injuries and recovery
    Last Post: 07-27-2012, 12:43 PM
  4. Knee Pain - Seat Too High?
    By peteuga in forum XC Racing and Training
    Last Post: 04-07-2012, 09:29 PM
  5. ASR 5 Alloy--possible damage to seat stay?
    By Porschefan in forum Yeti
    Last Post: 05-13-2011, 03:15 PM
