Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Reputation: fondoo's Avatar
    Sep 2012
    its time.. clipless pedals??
    okay, its time to invest in clipless SPD pedals. which one do you guys recommend from shimano or from crank brothers??
    2013 Cannonale Jekyll 3 M
    Reputation: MTBeing's Avatar
    My answer is in your question/title, ironically.
    Sent from my mountain bike while crashing
    I love it when a plan comes together.
    Fat-tired Roadie
    Nov 2007
    LOL.
    To expand on post #2, Time ATACs. I like the Aliums and while they've been discontinued, there's a ton of stock kicking around on the 'net.
    If you must do Shimano or Crank Brothers, people are saying the current model XT and XTR pedals are really good. Don't mess around with a caged model, if there is one at that level.
    The main event is the shoe. The pedals just need to work. That turns out to be a pretty high bar, actually, and I think that Times are awesome for working well and not needing a lot of attention or having a lot of doo-dads to play with.
    A guy on a bike Moderator
    Reputation: TobyGadd's Avatar
    Pretty much any clipless pedal will work well. Although people will strongly recommend one over the other, and provide a whole bunch of huff behind why theirs is the ONLY AND BEST CHOICE EVER!
    Take a look at the different types, and buy one that tickles your fancy. If you end up hating it, try something else.
    2012 SC Blur LT
    Reputation: TwoHeadsBrewing's Avatar
    As AdnrwSwitch said, the shoes are the most important part of the equation. I prefer Shimanos just because I've been riding them for 10+ years and I've only broken one in that entire time (and used cheap Deore's too!). But just like running or hiking, if you get the wrong shoes it's going to make your time just miserable. Here's my checklist for shoes:
    1. Comfortable
    2. Stiff sole, but not inflexible in case of a hike-a-bike or mechanical
    3. Ratchet buckle with straps.
    4. Good airflow
    Here's what I've been using for the last year, and they're the best shoes I've used thus far: Shimano M087 - ~$90
    My only complaint is that the airflow is TOO good in the winter/spring. Lots of water or cold temps mean frozen toes, so I have to use a waterproof shoe cover. No biggie, but this Chirstmas I think brown Santa is going to bring me these: Shimano MW81
    "Got everything you need?"
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    ^ This!
    You will get as many answers as there are pedal choices. I have friends that swear by Time and plenty that like egg beater buy I prefer Shimano only because I have been riding with one form of SPD or another for nearly 20 yrs with zero problems. That being said there are ways to try out a couple different types to find what you like. You could buy a couple choices from REI and return the pair that doesn't work for you.
    2012 SC Blur LT
    Oh, and for the money I don't think you can beat the PD-M520's (Deore level). I rode mine for 5-6 years before one started clicking and making noise. I have a riding buddy that has a set of XT's in the box, but has been riding these because they came on his bike and he can't seem to break them . Even if they turn out lousy, they're only $34 so no big loss.
    I ran the PD-M424, which are the Deore pedals but with the plastic cage around. I really liked these pedals and got a second set for my commuter/roadie. They work with regular shoes decently well, but you can also clip in.
    I now run the 2012 XT caged type pedals and like them a lot. I could take or leave the cage, although sometimes it does help when you miss a clip in. The cage is not like the previous set I mentioned, where you could use them with normal shoes. But since I don't do that on my Blur anyways it's not much of an issue.
    Sep 2012
    I got these (M647) a little while back when they were on clearance sale - and they have worked well for me. I like that I can pedal without being clipped in if need be.
    I picked the Northwave Mission shoes (was also on sale) because they looked like a "normal" hiking shoe instead of like a bike shoe:
    -S
    I've read reports of poor bearing logevity in the Crank Bros so it's narrowed down to Shimano or Time. Shimano are cheaper for each level and of course far more common so you'll be able to swap bikes with your buddies more easily. I've had M424 (the one the be plastic platform) M520, M540, XT and XTR - all good.
    I've not tried Times but they have and excellent reputation too. If you have a knee problem then the Times are supposed to have more 'float' (you can just run the Shimanos loose of course) and Times are also supposed to be easier to clip into when very muddy.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    For a new clipless user I'd recommend Shimano M540's because they have adjustable tension. You can start out with lighter tension until you get used to unclipping then increase tension as you get more experienced. They can be found at Nashbar for around $40 bucks
    Living vicariously through myself
    May 2012
    I have M536's These are old pedals, but they work great. I have bashed them on many rocks and they always work. I had another set years ago (non shimano, but SPD type) and hit a rock and busted off part of the pedal attachment. I ditched them and went with the shimano and love them. I will say however I don't ride in mud very often.
    Joe
    2003 KHS Alite 4000 26" Hardtail - XC, All mountain, blah blah blah.. I just ride.
    Front Range, Colorado
    Oct 2000
    TIME & TIME again this question comes up. And every TIME the majority rules in favor of TIME ATAC pedals. The only people that go with a different brand are people that haven't tried TIME. So do yourself a TIMELESS favor and choose TIME from the get go. TIME and TIME again I have heard of people switching to TIME but never have I heard of someone switching from TIME. It's about TIME I got that off my chest.
    29'ers should come with a warning label affixed to the toptube.
    WARNING: Objects may be further than they appear.
    And you can great deals on Time's at the moment. Check out Jenson and Nasbar.
    2012 SC Blur LT
    Quote Originally Posted by DIRTJUNKIE, View Post
    You ok man? Where are all these riders that use time atac? I've never seen one...on the trail that is.
    Oct 2000
    Quote Originally Posted by fondoo View Post
    shimano
    make sure there is no shoe pedal interfernce and back spring out all the way.
    Reputation: Eazy_E's Avatar
    I use Shimano M520s.
    Do yourself a favor and get M cleats, though. M cleats will release left, right, or with a good tug up. It's all the benefits of being clipped in, without the worry of falling over.
    The White Jeff W
    Have them. Dont like them. Replaced with Shimano SPD's. I dont like being welded to my pedals.
    Fat-tired Roadie
    Nov 2007
    Can't say I've ever had trouble getting out of my Times. I've had a few different systems - some knockoff SPDs, Speedplays, Time ROC-ATACs and Time ATAC Aliums. Actually haven't tried SPDs per se - back when I was shopping for pedals, they didn't have a particularly good reputation and Time ATACs were, and are, quite cheap.
    I don't know that Times are ever the majority choice on these boards, though, and I don't know that I see them a ton in the wild. I'm actually a little surprised by that. I'm living in the Pacific Northwest, and even the new, less-cloggy SPDs are still supposed to have problems here, to a much greater degree than Crank Brothers or Times. So Times seem like they ought to be pretty popular AM/Trail pedals. I think they're just not doing much to push their product. SPDs show up on new bikes a fair amount and Crank Brothers show up on a few new bikes and advertise a lot.
    Oct 2000
    Quote Originally Posted by jeffw-13 View Post
    "Welded to your feet" not even close. I have ran these pedals for 13 years and have never had that feeling. An easy clip in and easy release whenever needed. I was turned on early on to the pre- shaved cleats that Speedboats sells. They work like butter, I used them on my old Time ATAC aluminums. And have since bought TIME ATAC XS Titanium Carbons and use those cleats. And these new ATACS have an adjustable float screw for an easy to harder release depending on your preference. I set that screw to my desired release pressure 5 years ago and haven't touched it since. These pedals are top notch bomb proof and will never let you down.
    Quote Originally Posted by AndrwSwitch View Post
    I spent many a year in Southern California and am now in Colorado and in both areas I have seen numerous people using them on the trails. Like you said they don't advertise like other top brands because their flawless reputation keeps them at the top.
    Sep 2012
    thanks for everyones advice.
    i picked up a pair of shimano mo77 tonight from REI. i've decided to go shimano spd
    i am considering the following:
    PD-M980
    PD-M985
    PD-A530 so i could flip between flat and clipless.
    which one do you guys recommend?
    Reputation: Berkeley Mike's Avatar
    Let's hear it for 757s!!! (cricket chirping here....)
    Just make sure you set your pedals up right up right and that the cleat/sole clearance is adequate.
    I don't rattle.
    2012 SC Blur LT
    Either of the XTR's will be great, but I'd go for the non-cage 980s. Just don't go for the A530s. Those are more geared towards a commuter/city bike rather than a mountain bike.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    Quote Originally Posted by TwoHeadsBrewing View Post
    Was this question posted in jest??
    I have used TIME ATAC's for years, and see lots of them here in Bend.
    Sep 2012
    thanks for everyones advice. i've decided to go with the shimano PD-M985 and SH56 cleats
Hot Deals
Contests
Latest Mountain Bike Articles
