Results 1 to 56 of 56
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    intergrated headset on an alloy frame?
    deal breaker?
    I'm looking at a frame, but this headset standard has me worried. What say you?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by ElwoodT View Post
    deal breaker?
    Not a deal breaker. It works fine.
    mtbtires.com
    Live 2 Ride
    Reputation: Kona0197's Avatar
    Good to see you Shiggy. Where you been hiding?
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Binned
    Nov 2008
    Works just fine
    Quote Originally Posted by Hawg View Post
    Works just fine
    I have three bikes with it for a few years with zero issues, but I was also scar at first.
    Reputation: crossracer's Avatar
    Ten years on my Mtn bike, no issues at all. Just repack every year and it's fine
    Reputation: time229er's Avatar
    Oct 2013
    maybe it is just me, but...
    Quote Originally Posted by shiggy View Post
    this integrated and integral headset poop is still not 100% clear to me...someone school me up please which one uses the HT as the bearing race. If the bearing gets trashed, it takes the frame with it
    Attached Thumbnails Attached Thumbnails intergrated headset on an alloy frame?-dsc01911.jpg
    2014 Nail Trail 29...
    Feb 2014
    None of them use the frame material as a bearing race. That would be completely idiotic. What you have with a traditional style headset that has been designed to use cartridge bearings is essentially an adaptor pressed into the head tube, with the cartridge bearing slipping into that. Some designs do away with the traditional looking cup, and seat the cartridge bearing into the head tube, which has been machined with the appropriate shape. Saves weight, was the pitch. Made things a bit cheaper to manufacture too. Also allowed for more material to weld to on the head tube, all other factors being equal. That can be an advantage, especially on the smallest size frames. I don't know of any failures of that system, but then no system is perfect.
    Oct 2013
    um, not so sure...
    I agree with (as in I do not agree) with your "none of them use..." Do a little homework and get back to us...and maybe do a search on the Chris King website. There will be a test in the morning and yeah it certainly is idiotic
    Feb 2014
    There is a lot of confusion about bearings in the bicycle business. Much of it comes from some poorly defined terms. "Bearing race" is one of the culprits. The thing that is usually called a "crown race" is, for example, not a bearing race unless the headset is of the old loose ball type. Then it's an actual bearing race. Likewise, most people insist on referring to cartridge bearings as "sealed bearings." This is like the "square is a rectangle" thing. Not all sealed bearings are cartridge bearings, and not all cartridge bearings are sealed. Even some of them that look like they are. If you use a "shielded" cartridge bearing where you need a sealed one, then you won't get much life out of it. But I don't have time to argue with all the geniuses at MTBR. Been there, done that. Got the T shirt, wore it out, then used it as a grease rag.
    Dec 1998
    Quote Originally Posted by time229er View Post
    No. All current integrated headsets are a cartridge bearing that drops into a bearing seat--not bearing race-- in the head tube. Nothing to wear out that is not replaceable. In practice, this has been just as reliable as pressed in headsets. It is just as possible to ovalize the frame headtube with either.
    mtbtires.com
    Oct 2013
    ...what type of headset does CK refuse to support? It is the ding-bat design that "integrates" the alloy headtube with the headset bearings...no bearing cup pressed into the headset...bearing runs the on headtube
    Thread already spun
    Reputation: Zowie's Avatar
    Aug 2013
    deal breaker?
    Internal, sure. Integrated, no thanks.
    If there is a cup that is pressed in for a cartridge bearing to fret against, like in an internal headset, the cup will develop play and you can replace it. I personally don't see a headset with no cup that is just a drop in bearing competing with that in the long run. Will it work? Obviously it does well enough, they keep selling them...
    B.Ike
    Mar 2011
    thanks for your responses, this is reassuring. My initial research had me thinking this was going to be a deal breaker.
    A "good to go" from Shiggy means a lot to me.
    This is the frame I'm looking at btw: On-One Parkwood Frame | On - One
    Dec 1998
    If you do not like it, do not get a frame that uses it.
    Integrated headsets have been proven as reliable as press fit headsets.
    Should be noted that CK sells frames with headset cups permanently brazed into the head tube.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by Zowie View Post
    I have yet to see a cartridge bearing wallow out a cup. I have seen, and had, a press in cup ovalize a head tube, trashing the frame.
    When the bearing itself develops play with either type, you just replace the bearing.
    mtbtires.com
    Thread already spun
    Aug 2013
    Of course, that's the problem with new tech--we know all the ways a conventional external headset will fail, but there are no thirty or fifty or hundred year old examples of the new styles to see what happens with them.
    Dec 1998
    The current frames will be long dead or out dated from other reasons long before 30 years have passed. We are using many, many component/frame designs that lack 30+ years of field use.
    CK's anti-integrated piece is 12 years old.
    The integrated HS is still being used with few, if any, of the problems proposed.
    mtbtires.com
    Thread already spun
    Aug 2013
    Interesting response.
    Dec 1998
    Bottom line:
    No, an integrated headset is not a deal breaker for choosing a frame.
    mtbtires.com
    Feb 2014
    I can't help noticing that there is not a single reference to an actual failure of a frame because of an integrated headset. Lots of imaginary ones, though! This place never changes.
    Oct 2013
    thank you for the assistance, but... you still do not have a legit response to my original query...
    and, CK does not support the one you are describing...
    Attached Thumbnails Attached Thumbnails intergrated headset on an alloy frame?-dsc01891.jpg
    Dec 1998
    Your original question was answered, and you failed your own "test." No company currently produces an integrated headset/frame that uses a non-replaceable bearing RACE. They all use cartridge bearings, where the races are contained within the cartridge. The cartridge sits in a bearing SEAT formed into the head tube. They do NOT "run on the head tube." Trashing a cartridge bearing in any type of headset does not trash the cup or frame. You just replace the bearing.
    The depiction of an integrated HS in CK's 2002 rant is inaccurate in how the bearing is supported in the head tube. If this is the extent of your knowledge, it is very, very limited and incomplete.
    That CK does not support the common integrated HS standards does not matter. It is their choice. There are plenty of other companies that make them, and dang good ones.
    And why did you post drivetrain pics?
    mtbtires.com
    Oct 2013
    thanks for clearing that up...
    Dec 1998
    This was all covered in other replies if you had bothered to read them.
    mtbtires.com
    Oct 2013
    I actually did "bother..." to read and digest it all, but still feel there is a grey area regarding HS's that do not use a "cup". The cup dimension is cloned and the dimension is machined into the headset tube. And yes, the cone type cartridge bearing runs on the machined alloy surface in the headtube.
    My original query stands...can someone accurately define the differences between an integrated and integral headset and acknowledge they do exist. We certainly may not want them, but they are out there...what is what?
    I also would not consider CK's PDF document in their 2002 memo a "rant.."
    comments were also made that state "all current available..." that might be a legitimate response, so prove it to be a fact. If you really feel I am mistaken, and document your position, I will suck it up.
    I really do not have a horse in this race!...and
    my bike is fine...
    Feb 2014
    Octopus ink.
    Dec 1998
    comments were also made that state "none currently available.." that might be a legitimate response, so prove it to be a fact. If you really feel I am mistaken, and document your position, I will suck it up.
    You need to get your SHIS straight.
    As far as current HS standards go, there is no "integral" headset.
    Proving something does not exist is pretty much impossible, but unless you have a '90s Klein, time trial bike, or some other odd or custom bike it is going to use an off the shelf production SHIS headset.
    It is up to you to show us a frame that uses something else.
    http://www.canecreek.com/tech-center/headsets/shis
    http://www.canecreek.com/tech-center.../shis/overview
    http://www.parktool.com/blog/repair-...dset-standards
    Hope calls their internal/Zero Stack HS "Integral." That just confuses things when SHIS is widely used.
    mtbtires.com
    Oct 2013
    Tech Center | Headsets | SHIS
    SHIS Overview
    Park Tool Co. ParkTool Blog Headset Standards
    could be this thread has beat itself up...all good though
    thank you shiggy...
    Dec 1998
    thank you shiggy...
    Pretty much all but one poster understood what was being discussed.
    mtbtires.com
    Oct 2013
    I get it...just not sure I was effective describing my position...oh well
    Dec 1998
    You have been totally ineffective in making your point or asking your question.
    Just show us this "integral" headset so we know what you are talking about.
    mtbtires.com
    Oct 2013
    my question is self expainatory...are there two HS "standards"...integrated and integral this has been my question from the beginning...not sure why the answer is so difficult to respond to...
    as per shiggy's request, I have enclosed pictures of my FSA Orbit 1.5B ZS HT for the second time...see #7...not sure why he wanted it though, as FSA's website is clear as to what makes their zero-stack tick. And I also never said mine was "integral". All I ever wanted was a description of each.
    Somehow though, my desire to get an accurate definition/description has waned considerably...geeez
    Attached Thumbnails Attached Thumbnails intergrated headset on an alloy frame?-dsc01886.jpg
    Dec 1998
    as per shiggy's request, I have enclosed picture of my FSA Orbit 1.5B ZS HT for the second time...see #7...not sure why he wanted it though, as FSA's website is clear as to what makes their zero-stack tick. And I also never said mine was "integral". All I wanted was a description of each as I am not sure which catagory mine falls into.
    Somehow my desire to get an accurate definition/description has waned considerably...
    It is difficult because "integral" is NOT a term used for headset "standards" though it seems to be used by a few manufacturers.
    You are still confused as I never asked to see YOUR headset, or claimed you said your HS was integral.
    I asked for you to post pics or info about the HS type you are calling integral.
    I posted several links describing and illustrating the various HS types and accepted industry terminology. Can not be much more accurate than that.
    As for your headset, you said it yourself: it is a Zero Stack (ZS). That is internal. ALL of the relevant info has been supplied in this thread. Several times.
    mtbtires.com
    Oct 2013
    okay...I did find a copy of the CK PDF I was eluding to...it describes in detail that the integrated is the red haired step child...the headset bearings do ride directly on the HT, and yes, it was dated 2002..and no, CK does not support it. I feel so much better now...well, not really.
    I've read through this thread with complete bafflement.
    What is your specific concern? That you have a bike with an IS headset?
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
    Oct 2013
    Quote Originally Posted by trboxman View Post
    what is so complicated about wanting to understand which HS has the bearing that runs directly on the HT?
    Reputation: d365's Avatar
    What's so complicated about the S.H.I.S documentation that it doesn't provide an answer for your question?
    Or about any of Shiggy's responses?
    Oct 2013
    I was not familiar with the SHIS document till now...Park's website had the perfect explanation. Shiggy had mentioned it, but unitil you mentioned it again, I had not googled it.
    Dec 1998
    This is proof you did not bother to read the replies.
    I. Provided. LINKS. To. ALL. Of. The. info!
    You did not need to do a Google search.
    mtbtires.com
    So, in other words, you didn't read any of the links provided and continued to ask the same question answered by the links... Or am I misinterpreting your statement regarding the SHIS documentation?
    Dec 1998
    What is so complicated about understanding the numerous replies that answered that question?
    mtbtires.com
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I'm still confused as to why we were shown drivetrain pics?
    I'm a mountain bike guide in southwest Utah
    no motor, no way
    Reputation: life behind bars's Avatar
    May 2014
    Diversion.
    Oct 2013
    yeah, it certainly appears I did not pay attention to your links...I guess I just enjoy your company...and so let's just all pile on guys...I certainly will attempt to be more diligent in the future...
    Oct 2013
    Quote Originally Posted by Silentfoe View Post
    good question...should not have happened
    No hard feelings, your apparent lack of engagement with the content given to answer your question made you look like a troll.
    Personally I try to never attribute to malice that which can be explained as ignorance...
    Oct 2013
    thanks...I appreciate that. I guess it's okay to admit being ignorant.
    Feb 2014
    Well, to be fair, he did have some good advice.
    Dec 1998
    Quote Originally Posted by Austin Popper View Post
    Then he preceded to ignore his own advice--repeatedly.
    mtbtires.com
    Oct 2013
    yeah, that "he" guy is a real dink...
    I finally read through the CK pdf. I'm guessing that the bearings on many/most suspension frames must give them heart palpitations, what with no cups to protect the frame from the bearing...
    Thread already spun
    Aug 2013
    Yeah, they of all companies should know better than to worry about the immutably short lifespan of frames and components...
    Reputation: spyghost's Avatar
    Oct 2012
    Has anyone ever knackered a headtube from an integrated headset from years of use and abuse on the trail? Experience please...
    Canfield Yelli Screamy
    Oct 2012
    ^ that includes removal, replacement, installation on the same alloy frame...
  1. Frame vs Frame - Alpha Gold Aluminum vs QUICK CX , OPTIMIZED 6061 ALLOY SAVE
    By Paramount X in forum Bike and Frame discussion
    Last Post: 05-23-2013, 07:37 PM
  2. 2013 F29 1 Alloy Frame
    By Mr Pink57 in forum Cannondale
    Last Post: 12-29-2012, 07:07 PM
  3. Purchase Intergrated Head tube?
    By ggodwin in forum Frame Building
    Last Post: 05-06-2011, 05:01 AM
  4. 05 manitou dorado direct/intergrated crown stem
    By david8613 in forum Intense
    Last Post: 04-12-2011, 05:29 AM
  5. Intergrated style head sets.
    By C.M.S in forum General Discussion
    Last Post: 02-12-2011, 10:37 PM
