Results 1 to 37 of 37
    Improving the Current Mountain Bike Brake System - XPOST from Brake Time.
    in school, we've been asked to improve on an existing design. after a lot of thought, i have decided to work on the hydraulic brake systems on mountain bikes.
    i was wondering if you folks have any suggestions as to what sort of feature/improvement you would like to see from the current brake designs. what kind of pitfalls are there? what could be better?
    Do you have to design the improvements, or just write about them?
    I'm thinking an ABS system would be pretty easy to add to the hydraulic brake setup. It would ad a bit of weight, but could be worth it on an AM or DH bike where weight isn't a huge concern anyway.
    Nov 2007
    I got a design improvement idea, but its not about bikes. I think a recliner based computer desk would rule. Imagine sitting in a la-z-boy reclining it and the monitor would have to be housed in some type of frame then it would be held over you in perfect viewing positon, have that mechanism tied in with the recliner mechanism so when you get up it moves the monitor out of the way, a lil desk surface on a swivel for the keyboard on the left side, same thing on the right for the mouse. there ya go, you owe me $10 ehhh
    AW_
    AW_ is offline
    locked - time out
    Reputation: AW_'s Avatar
    Quote Originally Posted by AllKnowing
    Dude that's awesome. I'm always looking for new ways to have as little physical exertion as possible. Maybe you could combine it with one of those adjustable beds that changes from flat to sitting position. Then, you'd barely have to move all day.
    Nov 2007
    Yeah you could have your porn in bed ehhh
    Quote Originally Posted by Dave In Florida
    Thats a good idea! Im gonna keep it in mind... thanks a lot!
    Nov 2007
    Dont say it like that, in America we call it relaxing.
    Nice concept... but i dunno, I had my mind set on brake systems.... and the fracking thing is due by 5pm today, so i had already started typing stuff up.... its going to be a pita to scrap it all and start over with the porn in bed recliner idea.... where were you when I was brainstorming?
    Nov 2007
    Well i had a thread on bike improvement, I learned all the good ideas are in use. I think explaining a bike ABS setup is gonna be tough. Wheel speed sensors, lil computerized gizmos, whewww. I think its gonna be a tough sell, so i know your done brainstorming, but ill throw this out there. I think a new type of locking bike rack would be a great idea. People would love to take their high end bicycles to stores, librarys etc. if they knew it wouldnt get stolen. Some kind of steel frame bike rack the wraps the bike, the cyclist will like it because all they would need to carry is a padlock. If possible throw in there the need to cut greenhouse gas emissions, call it the bike locker. Good god man your saving the planet, shaving 5lbs of weight on the urban bicycle, solving the obesity problem. Be careful if you use this idea, you might end up with a nobel prize, youll be cutting more greenhouse gas than gore lol, good luck
    Reputation: FireDog46's Avatar
    MTB ABS Braking System
    Quote Originally Posted by _ALX_
    sounds like a very worthwhile project. We already have wireless trip computers. Use
    the same wheel sensor technology to detect lockup and design a modulator the hand
    controls pass through. Designed properly it could be marketed as an add-on compatible
    with most current braking systems.
    michael
    "Be not afraid of going slowly but only of standing still." - Chinese Proverb
    Nov 2007
    Oh yeah be sure to have a basic air pump on each rack, you know something heavy duty like a pay phone so vandals couldnt screw it up. Nothin worse than going out to your bike and its got a flat. Damn thats a good idea!
    change your handle
    it should read "AllAnnoying"
    Bicyclochondriac.
    Hmm, this got me thinking...
    I think the biggest challenge to an ABS system on a mountain bike is that the wheels leave the ground a lot. I'm wondering if that would cause the abs to kick in more than it should if you are lightly braking over rough (but solid) terrain. I have to think that if a wheel leaves the ground even for a fraction of a second it will slow down quite a bit, and then re-accelerated when contact with the ground is achieved. For example how abs would deal with a wheel that is slowing down between each root in a series of roots where you are just skimming along the tops with the wheel slowing down between each one. Is it fast enough to disengage as soon as you hit the next root-top?
    Is ABS used much in serious off-road competitive applications where wheels are often off the ground?
    Quote Originally Posted by FireDog46
    michael
    Sensor tied to the wheel speed sensor.
    The computer would have to be a bit larger (probably like an E-trex size) and would have to connect to a solenoid valve or something similar. Brake lines would have to run through the solenoid valve. Also a power source would be needed for the solenoid.
    It would certainly work, but would likely be heavy. And you'd have to probably go with a rear wheel sensor as well. I see it being overly complicated and not of much value. Something like shimano's airlines. It would be a great novelty item though.
    Nov 2007
    I think mtbr should give me my own forum, itll be called the Da Vinci forum and youll have to pay to get access to my revolutionary ideas. FireDog get that credit card out, you know you would be a member lol
    MTBR Demi-God
    its funny that we are talking about ABS brakes. I put it that way because I was visualizing the same concept a couple of days ago. Here's my take:
    Have two sensors:
    One on each wheel to measure their rotational speed
    One sensor:
    Measure ground speed
    A simple, (probably ARM based) microprocessor controller that will continually monitor the feedback from the two sensors. If the two values from the sensors do not match closely, it can actuate the mechanism for ABS... until it starts to match up.
    As for how exactly what the ABS system could be, I was thinking of making a "ABS reservoir"- which would have two hoses routed from each of the brake systems- the front and back.
    Once the microprocessor detects an uneven speed from the two sensors, it can instruct the ABS reservoir to open a valve to let a little bit of fluid to come in from both the brake systems, thereby reducing the pressure on the calipers. Once the speed values from the two sensors starts to match up again, it can close the valve.
    It obviously needs a lot of fine tuning. The main thing is to make sure that there is no air in the system. I could keep going with my idea for quite a while... but hopefully this will start you up.
    Let us know how it goes.
    "Winners never quit. Quitters never win. But those who never win and never quit are idiots."
    just along for the ride
    Reputation: Brown_Teeth's Avatar
    Why not just use a light sensor on the rotors to monitor the wheel/traction. Most rotors have holes light passes through. Hardest part will be the modulation of the brakes, hard to avoid using electronic controls but maybe possible to do mechanically, would be a fun project!
    My god...you're a new breed of dumbass...
    Reputation: wormvine's Avatar
    ABS would be most effective on the front brake IMO. Like Kapusta said, the rear jumps around alot. But then on steep descents it's really hard to lock up the front anyway.
    How about power assisted brakes. Just a little but too help with those all day DH days.
    Switchable on/off.
    Quote Originally Posted by wormvine
    Switchable on/off.
    thanks a lot to all who came up with ideas... im still holding on and working with the ABS idea.....
    how would power assisted brakes be of help? what would their job be? do you think there might be a huge difference between 203mm 4piston brakes and power assisted ones? let me know what you all think...
    Noob
    Reputation: Trouble Maker's Avatar
    Lol.
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    You must have really crappy brakes. I can easily lock the front brake on steep descents, and I have the broken helmets to prove it!
    I agree this would only matter for the front, who cares if you lock up the rear? Sometimes it even helps you steer. And yes, I know it's bad for the trails and I don't make it a habit, but if it's crash or skid a little, I'll abuse the trail before my body, thank you.
    Quote Originally Posted by Rufudufus
    My brakes work pretty well. I said it was hard to lock up the front, not impossible. Certainly a lot harder than the back brakes with your weight in a neutral position. Just hitting the front brakes causes the front end to dive and more force is exerted on the front tire helping traction while the opposite happens to the rear.
    I would say that a front brake that causes you to go OTB and break helmets would be bad brakes. No modulation. I certainly don't want my front brake to lock up easily. I want range.
    Also, bad tires or improper position on the bike can unweight the front end and cause the front bike to lock up on steep descents. If you are sitting on your tire, you are doing it wrong.
    Power assisted brakes would help apply more pressure with less finger pressure and you could probably use smaller pistons and smaller rotors to get the same power. After a hard day of DH'ing my hands are cramping and I can barely squeeze the brakes. Of course, it could increase the chance of locking up. Now how about power assisted ABS brakes.
    Reputation: Ultra Magnus's Avatar
    ...cutting more greenhouse gas than gore lol, good luck
    All Gore did something do reduce greenhouse gases?
    BM
    "I've come to believe that common sense is not that common" - Matt Timmerman
    Quote Originally Posted by kapusta
    Apparently not. Pure off-roaders pull the fuse or install a kill switch.
    http://www.4x4abc.com/4WD101/ABS_offroad.html
    Traditionally ABS prevents any wheel lockup. This can actually be a problem off-road.
    In sand or gravel, a locked wheel plows the surface, shortening the braking distance.
    With ABS the wheels skate across the surface and can lead to longer braking distances.
    New for 2008 in some off-road vehicles is what they call selectable On/Off-Road ABS.
    Off-Road ABS provides for cycling lockup to allow the plowing effect to occur.
    The latest for Jeep and Porsche have it.
    I still think ABS for an MTB would be an interesting experiment.
    Hey...a decade or so ago people laughed at the idea of disc brakes for bikes.
    Who knows...a decade from now we might have light weight sophisticated ABS for a bike.
    michael
    Without an outside power-source you can't really pulse the brakes. If you open & close a valve between the lever and the caliper you will just trap the pressure in the caliper & not affect the braking. If you close the valve & bleed the pressure on the caliper side your lever will sink towards the bar every time the valve opens again.
    You'd need a hydraulic pump to provide an alternate source of pressure. You could probably created a small piston pump powered by a cam off one of the hubs & use it to keep an accumulator charged. If you run the ABS off the accumulator & only power the pump when needed to recharge the accumulator you might be able to make it work.
    There will be a weight penalty. No-doubt the pros wouldn't use it because they can probably activate the brakes more precisely and adjust to changing trail conditions better than a computer & if the pros don't use it good luck selling to anyone else.
    That said - for your course it won't need to be marketable and it's an interesting design challenge!
    Check out the 3rd braking system from the top on this page, hmmmm
    http://www.blackbirdsf.org/brake_obscura/mtb.html
    crazy Italians eh
    Quote Originally Posted by Brown_Teeth
    Ferrari comes to mind...not so crazy
    michael
    michael
    I'll second your assertion, based on personal experience. I like to drive off road, fast, in any car. I don't care the make or model- just have to find the right road and you can have some serious fun. Several years ago as my family grew we bought a Nissan Xterra, and in short time I had it off road, and in two instances the stupid anti-lock brakes about killed me. First off, when driving or riding fast, you have to be able to predict what your vehicle will do with what inputs you give it. The first case was this fun S turn on some dirt roads I know like the back of my hand. The first left was slight, and I nomally (in my Toyota PU) entered the corner in third, and to pitch it into the right hander I'd brake, downshift, and pop the clutch to kind of lose traction a bit so I could back it in to the right hander. When executed properly, it's a blast. The first time I tried it with Nissan, the moment I downshifted, which slowed the rear wheels, temporarily skidding, the anti lock brakes kicked in and I nearly lost control of the car. I lost all braking at that moment. I blew the turn, shot off into the weeds, but luckily there was nothing on the outside of that turn to hit.
    The second time the antilock brakes almost killed me, I actually had my kids in the car too. I was doing some easy off-roading. Go up a hill, down a hill, etc. Kids were having a blast. Nothing to steep, it's only 2wd. Well, I was going down this one particular hill that had a right hand turn half way down. It was kind of gravelly over hard pack. As I started to go down, on tire started to skid, just ever so slightly but this was enough to make the anti lock brakes let go of the brakes on all the other wheels too. So now, I've got my foot on the brake pedal as hard as I can thinking, "Oh sh*t- I'm going to be on my roof in the middle of the desert with my kids in the car!!!"... Luckily I made it through ok.
    Let's just say I've learned my lesson.
    BM
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    What exactly do people think anti-lock brakes are going to do?
    They are to maintain directional control while when the brake would otherwise lock up. It will keep you on the road and straight. So the question is, are people locking up the brakes and riding off the trail? If not, there would be no use. You would actually be able to get better braking and modulation without ABS, no question.
    On a different front, some folks go to bigger disks for big downhills. How about twin disks up front? Doubles the sweep area and the cooling ~ roughly. Different caliper and disk materials to run hotter?
    Indeed modulation is where its at on controlled braking and ABS just does it for you. I like the boost idea better but then again these days hydros are so good forearm burn is a thing of the past. Oh well so much for this thread
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    ABS on a MTB would suck. What about when you want to lock it up to slide the rear end around or something? How do you toggle ABS on and off? It would only be valuable for the rear anyway, if you're locking up your front tire you're in trouble.
    Bicyclochondriac.
    Quote Originally Posted by Jim311
    Guess you'll have one less torn up switchback.
    Self Appointed Judge&Jury
    Oct 2000
    "Build a better mouse trap"
    Weight penaltys and maneuverability penaltys. It would never fly in the biking world.
    This thread is just ignorant.
    I agree that ABS is not really a good pursuit for the reasons mentioned above: weight penalties and loss of maneuverability on a machine that already has a steep learning curve. Plus, part of the appeal of bikes in general is that they are easy to work on; sensors and outside power sources aren't going to catch on very quick.
    How about designing a "better" floating brake system?
    Quote Originally Posted by DIRTJUNKIE,
    I never implied that I am building something that will revolutionize the entire biking industry. I just wanted an idea to get started on a school project... once I turn the project in, get the grade, I wont give a sh!t about it. the way this thread is going, its very interesting, since people are genuinely debating the idea of ABS- which is great in my opinion.
    I just wanted to work with something I already like- which is bikes, and I am fairly decent with brakes. Hence I asked for a couple of suggestions, and I have received tons of them- thanks.
    So if you think this thread is ignorant, just dont click on this thread.
