Results 1 to 22 of 22
    '11 Opus Strat
    Reputation: shawnt2012's Avatar
    Jun 2012
    I hate noise! But can I escape it?
    Hey all,
    To put it all quick and update, Got a X7 crankset on, everything is freshly greased and lubed, all tightened up etc... BUT, I am still experiencing a creaking noise when pushing power into the down stroke. Is this just a normal thing? I have had/used lower end bikes that do it to, and have heard high end bikes do it as well. Is it just a noise that can't be worked out? I am a 190lb guy, is it just the chain stressing while doing a rotation? Again, nothing is rubbing, everything is tight and lubed but all fairly new. 80km tops put onto new parts ( crankset,chain,cassette ).
    Quote Originally Posted by dubthang View Post
    I'm surprised you could hear her complaining over the sound of the vacuum.
    Reputation: J.B. Weld's Avatar
    There are a hundred places a creaking noise can occur and all of them can be fixed, though sometimes you may have to replace a frame to do it. I can not tolerate them and will hunt them down mercilessly.
    First step,
    Does it happen when seated and standing ?
    I've read many stories of people attempting to track down a creaking noise, only to find that it is their seat or seat-post making the noise, so start there.
    '11 Opus Strat
    Jun 2012
    Yes. More so when I am standing.
    Just looked at seat yesterday, there was a small creak coming from it, but solved that with a little chunk of rubber. Sound was still predominate noise from the crank.
    Sound can travel in funny ways through a frame ... Check the bars/stem.
    If that doesn't fix it, then..................
    Take the crank back apart, recheck the seating of the bearings, re-torque everything as you put it back together, make sure everything is in it's proper location and seated properly, and test ride it again.
    Over-tightening something that is not seated properly will only result in long-term problems ... That's my suggestion.
    Best of luck ... Waiting to see what you resolve.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Grease the pedal threads and see if the creak goes away.
    Quote Originally Posted by Dirty $anchez View Post
    Good One !!!
    Totally slipped my mind.
    Reputation: Chillout's Avatar
    Re: I hate noise! But can I escape it?
    Try removing the crank and add some Teflon tape the the crank shaft threads, then grease and reinstall. Then grease pedal threads.
    '11 Opus Strat
    Jun 2012
    I am going to try this one right away. As for removing my crankset and stuff... I would have to go to the LBS ( I REALLY need to invest in a tool kit ). But if continues that will be next step.
    Thanks for the suggestions guys!
    All you need is a crank puller which is around $12 on eBay. It's a very useful tool to have. Just make sure you buy the right one.
    '11 Opus Strat
    Jun 2012
    Quote Originally Posted by Chillout View Post
    Yea, I know.. terrible excuse lol. Just the zero downtime I have I want to bike, not fix it. haha. So if I can get them to do it while I work, then have the time to maybe get out for a ride!
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    One time I had a creak like you describe and it ended up being a loose water bottle cage screw. Loose chain ring bolt will do it. The bottom bracket can do it (you most likely need a bb tool and not a crank puller). However If you are soliciting advice on how to check and fix these things but don't want to fix them your self, best advice: drop it off at the LBS.
    '11 Opus Strat
    Jun 2012
    Quote Originally Posted by ElwoodT View Post
    I will check the chain ring bolts, never thought of that! Durr..
    I can fix the small quick things, but pulling off a crank is a bit more time consuming for me ( work a lot, kids, etc. ). So would try to weed out every little thing so I can pinpoint the issue, then bring it to the LBS if it's something out of my range. I understand your suggestion and is a smart choice indeed, thanks man!
    Reputation: JoeDougieDouglas's Avatar
    Jun 2013
    I had this exact problem on one of my old DiamondBack bikes - turned out to be a small crack in the frame at the top tube / steerer tube joint. Check the frame.
    2013 Giant Revel 4.
    '11 Opus Strat
    Jun 2012
    Ding Ding Ding!, And the winner goes to..... Loose chain ring bolts!
    I have never had to tighten them up before.. Just tighten until tight? ( not over doing it obviously )
    B.Ike
    Mar 2011
    a little grease and tight until tight+, this isn't scientific, but I usually estimate how tight by the size of the bolt (its a big bolt).
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Was going to suggest the same, we usually forget about the pedals.
    sometimes you can be too heavy for a bike.
    i lost weight once and creaky noises went away.
    roccowt.
    rocnbikemeld
    ^ Zarr, where have you been? Good too
    hear from you.
    Quote Originally Posted by shawnt2012 View Post
    If you are tightening with the proper sized wrench (no more than 5" long or so) you'd have a pretty damn hard time stripping a chainring bolt. If you do manage to do it, you'll know, as the nut will buckle and pop.
    You'll likely need a chainring nut wrench, as well.
    '11 Opus Strat
    Jun 2012
    Quote Originally Posted by zarr View Post
    That is also a big possibility still. I had my younger cousin ride it ( 125lbs ) an he didn't hear anything, I am 184ish so maybe a little extra KM's won't hurt lol.
    I got the chain ring nuts nice and tight today. Just waiting for the rain to hold up for a bit!
    Reputation: Fattires40's Avatar
    Dec 2009
    If the chain ring bolt thing don't fix your problem, have the bottom bracket checked out. I've had to replace mine to resolve my noise problem.
  1. Found this, I hate the people who hate bikers
    By chaloopy in forum Passion
    Last Post: 10-04-2014, 08:54 AM
  2. Replies: 3
    Last Post: 08-04-2012, 08:51 PM
  3. I hate the LBS, I hate where I live
    By Drth Vadr in forum All Mountain
    Last Post: 02-20-2012, 11:05 AM
  4. The escape to SSedonalicious Day 3
    By Scott forty G. in forum 29er Bikes
    Last Post: 07-19-2011, 02:31 PM
  5. successful escape
    By egapal in forum Beginner's Corner
    Last Post: 07-10-2011, 08:34 AM
