Results 1 to 20 of 20
    Oct 2012
    Hydraulic disks, help
    I saw a guy on craigslist selling Avid Elixir 5 system for $40, he said they just need to bleed. He's not including the disks. I have regular disk breaks..do I need to buy new disks or I can just put on the hydraulic breaks and keep my old disks?
    Big Mac
    Reputation: mbmb65's Avatar
    What are "regular" disc "breaks"? If they're broken, I wouldn't buy them.
    Oct 2012
    Quote Originally Posted by mbmb65 View Post
    Just regular disks breaks, not hydraulic ones. They're not broken, they just need maintenance I guess. The guys says they work just fine
    Dec 2010
    A bleed should cost around $30 per brake at your LBS, so factor that cost in. Can you post the link here so we can see the brakes and give you a better idea of their worth? To answer your question, you can use the same rotors for mechanical and hydraulic disc brakes.
    Dec 2010
    Also make sure they don't need new pads...a $45 brake set could turn into much more with $60 in bleeding and $50 in pads for both calipers. $45 would be a better deal if you could do the bleed yourself or if they had new(ish) pads.
    Oct 2012
    Quote Originally Posted by sasquatch rides a SS View Post
    Avid Elixir 5 Hydraulic disc Brakes
    Dec 2010
    He didn't give as much info as I thought he would lol I'd give them a shot. They're a couple years old, but I really like that era of Avid brakes. Talk to your LBS first and see what they charge for bleeding them and see if they've got some pads in stock. Let us know what you decide to do!
    Oct 2012
    ... and if we just ...
    Do you think they're worth it ? I'm gonna email the and ask him the condition of the pads
    Reputation: 006_007's Avatar
    They are not a bad set of brakes - and if you have poor hearing you will love them (reason I got rid of my Avid Elixer 5 was no matter what I did I couldnt stop the howling). For $30 plus maybe $70 of maintenance (less if it becomes a DIY project) and you are good to go.
    Oct 2012
    Quote Originally Posted by 006_007 View Post
    Ok thanks!
    You can do a search on e-bay to see what things are selling for. You could also look for something new that might not be a lot more expensive.
    Ouch, that much for bleeding? I'm new to disc brakes, on bikes, but I do my own cars/trucks all the time. Is this not something an average Joe can do? Is it similar to a car?
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    you should get new pads and a new bleed anyway when purchasing disc brakes second hand. yes, you can use your old rotors...
    Pro Crastinator
    Quote Originally Posted by Back-N-Black View Post
    ...Is this not something an average Joe can do? Is it similar to a car?
    pretty much exactly the same as a car...
    Sep 2012
    Not difficult to do.
    The tech docs will help.
    Service Resources - Avid | SRAM
    ...and I use the bleedbicycles.com bleed kit. (cheaper than Avid, but pretty good quality)
    -S
    Does it matter whether it is automotive DOT 3 or DOT 4?
    Sep 2012
    Depends on what your brakes call for. It's usually labelled somewhere on the lever or perhaps read the manual. E.g. Shimano uses mineral oil while AVID uses DOT 5.1
    -S
    High Quality and inexpensive bleed kits. Including Dot 5.1 fluid.
    BleedBicycles.com - Bleed Bicycles Cycling Products
    Duplicate post by accident
    Sep 2012
    Quote Originally Posted by Ev52 View Post
    I've used the bleeder kits from Bleedbicycles - they work well and the owner is continuously improving the product.
    They cost about 1/2 of the Avid kits.
    -S
