Results 1 to 15 of 15
    Nov 2013
    How to remove scuffs on frame
    I have a white Tallboy and I just put a big black scuff on the top tube, either from the sole of my shoe or perhaps pine pitch from leaning my bike on a tree.
    Soap and water and rubbing alcohol had no effect. Any other suggestions?
    Goo gone.rubbing compound,
    check your six
    Reputation: sodak's Avatar
    Goo Gone is some great stuff! A little stinky but very effective removing scuffs, residue, or stickers.
    "We can always find excuses if we want to find them, but if we really want to do something, we have to just go."
    Nov 2013
    I tried Goo Gone on another scuff but it removed the shine of the paint. Any ideas for restoring the shine after I get rid of the scuff with the goo gone?
    Reputation: 006_007's Avatar
    White out (quick drying formula)
    Or leave it. It gives the bike character.
    Reputation: TheDocTx's Avatar
    Apr 2013
    I have used Meguair's cleaner wax to remove scuffs with good results. There may be better things to use but that is what I had laying around the shop.
    check your six
    Quote Originally Posted by basso_ascot View Post
    huh.. I have used that stuff on about everything from my truck paint to kitchen counters. I have never had a problem with it effecting the finish of anything. Maybe try to use some sort of polish to bring the shine back?
    Good, green, Oregon.
    Reputation: Giant Chachi's Avatar
    Have you tried a Mr. Clean Magic Eraser? I would think that would do the trick in no time at all.
    *2016 Transition Patrol Carbon (aka: Sweet Pea)
    Reputation: Nakedbabytoes's Avatar
    Lighter fluid. Squirt on, set on fire(jk! DONT!!), wipe off with cotton ball. Gets rid of the sticky or scuff marks, leaves shiny finish alone. I use it to clean off crayon marks on my daycare table and sticky sticker goo off misc items my daycare kids think would be fun to put stickers brought from home on.
    Lighting it on fire would be fun though. But then you have bigger issues than a tiny scuff. So cereal, just rub it off after you squirt it onto your frame mark.
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Reputation: tysonnemb's Avatar
    Rubbing compounds and cleaner waxes work well on painted shiny bikes (having a clear coat). Surprisingly, WD 40 is a good cleaner as well. On painted bikes, I treat it like a car, and put wax on it. If you rub the goo gone too vigorously with a rougher rag, you can scuff it up a bit, noticeable on darker colors (of course). Cleaner wax will help that.
    “Think of bicycles as rideable art that can just about save the world.”
-Grant Petersen
    ^^^Probably your polyester rag contributes to the micro scratches reducing shine. White all cotton tee is better. Polishing compounds for foam pads like 3M Perfect-It 3000 or whatever you can get at a body shop that they use for final polish. You just need a dab and all cotton cloth.
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    I had a white KHS XC604 that had some scuffs on it, and I used a Magic Eraser on it. I would say that about 85% of the scuff marks came off with it, and it left no residue and you couldn't tell that I used it on the paint.
    The pedals turn, not just the left one, but the right one too.
    Reputation: sgtjim57's Avatar
    I have used Deep woods off with deet to remove tree sap from my vehicles, has not hurt paint so you might give it a try. Not sure if the deets necessary but it's what I had. Hate pine sap.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Meguires has a scratch x compound, which works great. Rub it ino the scuffs from a variety of angles, then buff it all out. If it's all from cable rub, cover the area with some clear shield tape...
    Todd
    Rudy Project Eyewear
    Reputation: JFalcetti's Avatar
    Mr Clean magic erasers are quite effective.
  1. Possible to remove decals from frame?
    By boo radley in forum GT
    Last Post: 10-28-2013, 03:27 PM
  2. yeti frame corrosion, any ideas or tips to remove it?
    By yeti575nut in forum Frame Building
    Last Post: 02-10-2013, 06:17 PM
  3. How to fix scuffs and abrasions on carbon frames?
    By RoxMDO in forum Bike and Frame discussion
    Last Post: 06-24-2012, 07:57 PM
  4. Replies: 2
    Last Post: 04-04-2011, 07:12 AM
  5. How to remove cables/housing from frame upper bar?
    By stardomains in forum General Discussion
    Last Post: 04-03-2011, 08:36 AM
