Results 1 to 10 of 10
    Mar 2013
    how much to shorten a stem for a wider bar
    I appreciate this is very subjective but I'm looking at using a wider handlebar and am trying to decide how much to shorten the stem to keep the steering the same. As a rule of thumb does 1cm off the stem for an extra inch on the bar sound about right?
    thanks.
    undercover brother
    Reputation: tangaroo's Avatar
    10mm shorter stem for every 20mm of bar width. Of course, this should be taken as a general rule of thumb.
    I would follow you into the mists of Avalon if that's what you mean.
    If all else fails, I blame it on my tiny wheel size
    Reputation: Snfoilhat's Avatar
    May 2010
    Hiyo,
    I think that short stem / wide bars is an arm-shoulder-chest ergonomics thing and a center of gravity relative to the bike thing, more than geometry. I know people are sensitive to steering 'speed'. So I did the trigonometry in a crappy python script. If I had all alfternoon I would look into getting it to work in HTML somehow so it would be interactive in the thread(??). Also, this is flattened to 2D.
    Sample output using numbers I think are common to XC setups looking for their first wide-bar experience:
    Enter handlebar width in millimeters.
    > 680
    Enter stem length in millimters.
    > 90
    Steering coefficient is:
    351.710107901
    The following table shows stem-bar combinations with the same steering coefficient.
    35 699.928567784
    40 698.856208386
    45 697.638875064
    50 696.275807421
    55 694.766147707
    60 693.108938047
    65 691.303117308
    70 689.347517585
    75 687.240860252
    80 684.981751582
    85 682.568677863
    90 680.0
    95 677.273947528
    100 674.388612003
    I was really surprised to see how little bar length goes up as stem length comes down to retain the same leverage (what I called 'steering coefficient'). That's where the ergonomics issue comes in. Percieved steering speed and overall handling are going to take your body's position relative to the bars into account, not just force on a lever like some robot in a test rig. Wide feels good! But It looks like it slows your steering considerably, even w/ a short stem.
    code follows if someone wants to check the math. Cheers!
    # Handlebar calculator
    import math
    def calculate_lever(bar_width, stem_length):
    lever = math.sqrt(pow((bar_width * 0.5), 2) + pow(stem_length, 2))
    return lever
    print "Enter handlebar width in millimeters."
    bar_width = int(raw_input("> "))
    print "Enter stem length in millimters."
    stem_length = int(raw_input("> "))
    print "Steering coefficient is:"
    lever = calculate_lever(bar_width, stem_length)
    print lever
    print "The following table shows stem-bar combinations with the same steering coefficient."
    for stems in range(35, 105, 5):
    s2 = pow(stems, 2)
    lever2 = pow(lever, 2)
    b2 = lever2 - s2
    b = 2 * math.sqrt(b2)
    print stems, b
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Nice list.
    I think the 20mm for 10mm is a fairly good method to follow.
    Personally, I feel that too short a stem can cause the rider to be more prone to OTB's. A wider bar won't keep keep your reach in front of you like a longer stem will. That said, I currently have a 70mm stem with a 750mm bar (which will get cut to 730mm soon.)
    Reputation: Rojo Grande''s Avatar
    Oct 2012
    So I went from a 685 to a Havoc carbon fiber 750 bar with my original 100 stem. People told me I had to go to a shorter stem because it couldn't work. I'm 6-3, riding an xl Tracer vp. I like the ride/love the wider bars, but I have noticed a little bit of front end dive in some tight turns. I was thinking about going to an 80mm stem but I wonder about the overall stability over the tight corner dive? It's only 1/2" difference but is it worth the try/expense?
    "El Cajon?, that's the anus of San Diego"
    Mar 2013
    snfoilhat - I was thinking it would be useful to try something like this but also include head angle so you could also think about stem / handlebar combos to compensate for going with a longer fork. Can't help feeling your results from your script look a little suspect, am not really too sure about the maths behind this. Would be interesting to look at what other people have done on this, there must be something out there.
    Dubthang - I think when going with the shorter stem approach you really need to give it some thought when buying the bike so you can get something with a longer top tube, the wider bar only gives you so much (or you go with a layback post if you're not concerned about maintaining the saddle position relative to the bb). Otherwise yes, if you just put on the short stem when your sat in the saddle I think it will screw up your weight distribution.
    Rojo - I think to say "it wouldn't work" is a bit dramatic but you are missing out on some of the possible advantage of the short stem, its my understanding that the short stem makes the bike feel more stable on the descents as you're further behind the front wheel. I guess it all depends on how much of a bike geek you are, whether tinkering with these things is part of your interest in mountain biking or just a distraction. I'd certainly give it a go, I think the head angle of the tracer vp is 68 or 69 degrees so an 80 stem with a 750 bar would sound fairly standard, perhaps even a hair shorter, although that might be a bit much change in one go. Why not just buy a cheap stem and see how it feels.
    Gigantic Hawk
    Quote Originally Posted by floyd View Post
    Correct. I was thinking about it in the terms of riding while standing. Should have stated that.
    Aug 2010
    Wow I never knew people put so much math into their cycling! I bought some wider bars and a shorter stem. I figured out the math like this bars 29.95 + stem 19.95 (plus postage) the first time I rode it I knew I got the right ones!
    Reputation: RipRoar's Avatar
    780/65 here
    @Rojo - 1/2" is a big change on stem length. If I had to guess on the "front end dive" I would say it was more fork related, unless you mean the front end is washing out or pushing...
    Aug 2005
    Interesting. I was using a 70 mm stem with a 785 mm bar. I just swapped out the 70 mm stem out for an old 50 mm so I get that short cockpit feel of a gravity bike. I'm curious to ride it now.
    2013 Transition TransAM 29er - up and down.
    2011 Yeti 303R DH - just down.
    2005 Trek Bruiser
  1. Wider bars and a shorter stem...
    By markersniffen in forum Beginner's Corner
    Last Post: 11-20-2012, 04:37 PM
  2. Calculating stem length when getting a wider bar
    By Bjdraw in forum Bike and Frame discussion
    Last Post: 09-16-2012, 06:45 PM
  3. wider bars but what length stem?
    By kotajack in forum All Mountain
    Last Post: 03-20-2012, 05:00 PM
  4. Wider bars = shorter stem
    By vizsladog in forum 29er Bikes
    Last Post: 12-21-2011, 05:06 AM
  5. Switch to even shorter stem and wider bars?
    By Whip Chop! in forum All Mountain
    Last Post: 08-24-2011, 08:34 PM
Hot Deals
Contests
Latest Mountain Bike Articles
