Results 1 to 8 of 8
    Jun 2012
    How does C width translate to inch width in tires?
    What inch width would a 42 c tire be?
    The 'c' can be interpreted as millimetres.
    And so, take 42mm divided by the 25.4 mm to an inch and you get 1.65"
    El Gato Malo
    I always thought the 'C' was the abbreviation for the speed of light.
    Reputation: Gasp4Air's Avatar
    Quote Originally Posted by Trail6 View Post
    Depends on the rider. In my case, it stands for the speed of molasses on a cold day.
    Use it, use it, use it while you still have it.
    Reputation: cockroach's Avatar
    Just to confuse you even more, 26 x 1.5 and 26 x 1 1/2 aren't the same!
    Quote Originally Posted by cockroach View Post
    the important difference in this context is the required rim diameter. Width won't be much different.
    The c number, as in 42c is a marketing number, so it tells you what the manufacturer thinks you want to hear, which is probably going to be fairly accurate when interpreted as millimeters. Tires also have ISO numbers, and sometimes a tire will even list two widths, i.e. for the casing and the tread. these numbers begin with 559 or 622 for 26" and 29" rims, respectively. so 700x42c might have an iso of 622x42 or 622x42x41.
    Width depends on your rim's width, I'm sure ISO numbers are based on a specific rim width, though I don't know it or how it varies with the tire width, perhaps someone else can provide these details.
    In this case there's a big difference, 26x1.5 will fit your standard 559 ISO 26" MTB rim.
    26 x 1 1/2 is for an obsolete French rim size, 584 ISO.
    Interesting reading on Sheldon Brown's site.
Members who have read this thread: 12
