Results 1 to 6 of 6
    Oct 2012
    How to choose bottom bracket for specific frame?
    I'm curious as to how I can figure out which type of BB I need for a frame. It's a new frame being built on. The frame is a 2017 rocky mountain thunderbolts MLS BC edition. Looks like it will be press fit but do I just measure the width and circumference to find out the rest? Is there going to be compatibility issues with crank arms from Shimano to SRAM? Or possibly any other compatibility issues I might not foresee? Thank you in advance!
    Reputation: jcd46's Avatar
    Maybe look for the specs on a complete same bike? That might help..or google add mtbr to search. That's all I got 👍
    2016 SC Heckler R build
    2012 CX Kona Jake
    Giggity!
    Jan 2009
    disappointing that they don't have the specifics on their website, but should be pretty easy to track down with the help of your LBS or by calling them Thunderbolt | Rocky Mountain Bicycles
    you might also have better luck on the Rocky Mountain forum- Rocky Mountain - Mtbr.com
    Get off my lawn!
    Feb 2006
    I looked too. It's weird the spec isn't listed. They use BB drop too - no mention of height.
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    You need to know the BB shell type and the actual spindle diameter and length. Current common ones are 30mm, 24mm, 24/22mm GXP, there's probably a few others. Several 24mm BB's have GXP adapters that basically is a 1mm shim to accommodate for the 22mm non-drive side of the spindle.
    WTB: Med Bontrager Ti Lite, PM Me...
    I see:
    BOTTOM BRACKET
    RACE FACE CINCH BB92 PRESS FIT
    Pick your crank then pick the matching press fit BB.
  1. Bottom bracket frame
    By H3r4cl3s in forum 29er Components
    Last Post: 11-21-2016, 02:27 PM
  2. Will a new Shimano bottom bracket fit my frame?
    By TheAvo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2016, 10:56 AM
  3. What do I need to know to choose a bottom bracket?
    By Honda Guy in forum Beginner's Corner
    Last Post: 08-11-2014, 08:25 PM
  4. Bottom bracket/frame question
    By Dr.Mushy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2013, 01:31 PM
