Results 1 to 9 of 9
    May 2012
    No good help new dirt jumper 1 harsh topout
    hello i have just got my new dirt jumper 1 2011 (though 2011 bought it new) fork on my bike and first ride i notice harsh top-out even when hoping up on a curb and when compressing the fork myself i notice what sounds like air bubbles running through the circuit tho no harsh topout when full rebound but no fast rebound either would this be due to a low oil level or something broken .. i would hate to bring in a new fork after 1 ride any help would help lol
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    rebounds fast with the valve open. rebounds slow with the valve closed. unless i am missing something, it sounds like your fork works normally...
    May 2012
    exept on high speed rebound it has a harsh metal on metal topout
    Pro Crastinator
    harsh topouts are pretty normal, but the clank isn't. check your oil heights...
    Pro Crastinator
    the dji is a simple ported damper, nothing fancy or complicated in the slightest...
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Quote Originally Posted by Mason8or View Post
    Have it checked out to be safe.
    There....Are... Four...Lights!
    May 2012
    yeah thats what im going to end up doing cuz it is a harsh clank kinda sound id tear into it myself (not the first time) but its still under waranty and yes it is the simplest of most marzy fork exept air in only 1 side wasnt a big fan of the idea being equal is strong but thanks ill go get em checked out
    Pro Crastinator
    unscrew your topcaps, compress your fork, remove the springs, measure the height of the oil. it should be 100mm down from the top of the stanchions. its as simple as it sounds and takes about 5 minutes...
    Pro Crastinator
    so... what happened?
