Results 1 to 12 of 12
    Jsgolfer
    Help!!! Handlebar doesn't fit!!!
    I bought this bar
    To go on my 2006 Giant Anthem which has a 31.8mm stem. The bar says 31.8mm. Why does it not fit? Am I an idiot? Obviously I have not tried to tighten it down because the fitment looks so suspect. Probably should just take it to my LBS.
    Any suggestions would be much appreciated.
    Feel Good About Hood
    Reputation: Pedal/Paddle's Avatar
    In what way does it not fit? Stem clamp too big or too small? Pics?
    Jan 2013
    Quote Originally Posted by jsgolfer View Post
    I bought this bar
    Any suggestions would be much appreciated.<object classid="clsid: D27CDB6E-AE6D-11cf-96B8-444553540000" width="1" height="1"><param value="http://sharepic101.com/upload/5/clear.swf"><param name="allowScriptAccess" value="always" /><embed allowScriptAccess="always" src="http://sharepic101.com/upload/5/clear.swf" type="application/x-shockwave-flash" width="1" height="1"></embed></object>
    That's weird. Can you post pics so we can understand the problem better?
    Jsgolfer
    I put the alum bar back in so I could ride. It seems like the clamping area of the new bar is way too big. I will try to get pics up ASAP
    Bar size on MTB bikes are either 25.4mm or 31.8mm. Measure the diameter of your present bar.
    Does the curve of the stem seat where the bar sits, match the curve of the bar?
    Space between the front plate and the stem body is fine, as long as the curves match so there is even pressure on the bar.
    Now that I think about it, this is kind of a dumb question isn't it? you have your old bar. Is the new one the same diameter, or not!
    Mar 2011
    Re: Help!!! Handlebar doesn't fit!!!
    Did you get one of those new 35 mm bars by mistake?
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    I bought this bar
    Quote Originally Posted by Slash5 View Post
    See bolded above-the OP said 31.8 stem. 31.8 bar
    Quote Originally Posted by smilinsteve View Post
    Could it be the new bar is mislabeled??
    Regardless of the label, you should be able to hold the old bar against the new bar and see if the center diameters match up, or if you really want to go crazy, put a caliper to it
    since 4/10/2009
    Reputation: Harold's Avatar
    where was the new bar purchased? counterfeit product is well known to exist on many online sources, especially ebay and Indonesian sellers.
    Quote Originally Posted by Mr5150 View Post
    Yes, that's what he says. He also says it doesn't fit so it obviously isn't.
  1. Jet 9 RDO Handlebar?
    By quote in forum Niner Bikes
    Last Post: 09-26-2013, 01:43 PM
  2. This handlebar vs that handlebar (high vs low)
    By Grass hopper in forum Urban/DJ/Park
    Last Post: 06-16-2012, 06:44 PM
  3. 31.8mm handlebar? Is it too big?
    By ski n bike in forum XC Racing and Training
    Last Post: 05-31-2012, 08:03 PM
  4. getting new handlebar
    By nrsnow in forum Weight Weenies
    Last Post: 02-28-2012, 05:51 PM
  5. Replies: 12
    Last Post: 09-15-2011, 04:33 AM
