Results 1 to 90 of 90
    Reputation: CaptDan's Avatar
    Jun 2013
    Front-end TUCK - Has anyone experienced it? What to do about it?
    I may be using the wrong word to describe it, but while turning a bike through a corner, the front end (bars/fork/wheel) suddenly turn more than desired until the front wheel is 90 degrees to the direction of travel... at which point the bike stops moving forward, and the rider is usually tossed over the bars.
    I've also heard it called Knifing or Oversteer.
    A friend of mine has found himself on the ground a couple of times recently after going over the handlebars -- once so quickly he still had the bars in his hands as he lay there wondering what happened.
    He suspects the front end tucked, but he's not sure.
    What causes tucking? How prevalent is it? How do you cure it?
    Thanks in advance...
    live long and huck
    Reputation: Optimus's Avatar
    Never experienced it, never heard of it, so I would say not prevalent at all. Perhaps build some upper body strength.
    Low and slack.
    Quote Originally Posted by CaptDan View Post
    Broadly speaking, it happens when the steering angle, lean angle, and front/rear weight balance isn't right. It tends to happen when the bars are turned too much, the bike isn't leaned over enough, and the weight balance is too far to the front. The front wheel wheel starts catching and slowing down the bike which transfers weight to the front & compresses the fork, which does wonky things to the steering geometry of the bike and makes the front wheel dig in hard and spin sideways. The bike comes to a sudden stop and the rider gets dumped.
    How prevalent it is depends on the trail surface, bike type, and the rider. Trails with lots of soft spots in the middle of corners can cause lots of knife ins as the front tire slides out and then catches traction again. XC bikes with shorter wheelbases and steeper angles are also more prone to tucking under than a long and slack AM/Enduro bike. And finally, riding style, people who steer mostly with the bars and don't lean the bike much are more prone to having the front wheel go sideways on them in a turn.
    Prevention comes down to awareness, practice, and undoing bad habits. If you see a patch of sand in the middle of a corner you might want to be prepared to make some fast corrections or think about taking a different line to avoid it. Then there's training out bad habits. A lot of riders will turn the handlebars in more when the front tire starts sliding and they think they're going to go too wide on a turn. Problem is when the bike bleeds off enough speed and the front wheel regains traction it'll bite in hard, spin sideways, and flip the bike. More advanced riders will countersteer and lean the bike more which puts the arc of the turn where they need it while pointing the front wheel close to the direction of travel so that it can't catch wrong and start the crash sequence.
    Reputation: SoCal-Rider's Avatar
    I thought I was the only one experiencing this! I have had this happen numerous times on my Tallboy. It happens mostly in tight downhill switchbacks, usually when I haven't quite judged the apex right and I have to steer a bit more...then bam! I'm on the ground. It's the one thing I don't like about my Tallboy.
    I call it a "flip" of the steering. It's like it passes over some pivot point and all of a sudden the steering acts different.
    I'm not sure if it's a 29er thing or the steeper head angle that contributes to it. I don't seem to have the issue on my Mach 6.
    Oct 2014
    Happened to me just 3 days ago! Riding my rigid 29r on a very skinny section of single track with a 15' drop to my right and a bunch of large, angry-looking rocks to my left. I approached a narrow spot that looked like it was collapsing/washed out and I tried to navigate around it and…well, honestly it happened so fast I can't really explain it. I was on the ground and my front wheel/bars had turned almost completely around as the bike lay there. I landed about 4-5 feet away from the bike - pulled off a decent tuck and roll unwittingly. Luckily I landed smack in-between the rocks and the drop-off. Crazy. Barely a scratch on me. Counting my lucky stars still...
    Fat-tired Roadie
    Nov 2007
    I sometimes have that problem, more on my older bike. Which is a 26" hardtail, so I don't see it as a 29er problem.
    The worst time for me is in a compression. I think that implies that rolling something too big is a bad idea too. If I don't think I can get off something in the right attitude for landing, I just walk it.
    If you think about a bike's steering geometry, it makes a lot of sense. Having some angle in the top tube puts the front tire's contact patch behind the steering axis. So the force that turns the wheel makes it "want" to stay straight and if the wheel's turned a bit relative to the bike's direction of travel, there's going to be some force restoring it to being in line.
    With a super steep angle or if something else moves that contact patch forward of the steering axis, it's going to want to slam around the rest of the way. So if you combine a steep head angle, a compressed fork making it even steeper, and maybe the ground at an upward angle, like in a g-out or coming out of a compression, that's a pretty toxic situation.
    It's certainly something that can be reduced with good technique. If I'm centered over my pedals, lightening my front end over stuff, floating it and doing push manuals over doubles, etc, it's not a huge issue. If I've set up my bike with a lot of drop, I've got my head down, and I'm leaning on my bars, I'm putting myself at major risk for some weird front wheel behavior.
    Reputation: Ducman's Avatar
    I happens when you turn your handle bars into the turn while leaning the bike over, instead of counter steering. If you stand next to your bike, lean it over then turn the handle bars into the lean, what happens if you turn them to far... the front wheel rolls backwards
    Reputation: KevinGT's Avatar
    Dec 2012
    Been riding since the late 80s and never had that happen. In fact, I've never heard anyone else tell me that happens until today.
    Oct 2014
    Quote Originally Posted by AndrwSwitch View Post
    Interesting about the upward angle--I was actually on a slight upward incline when it happened the other day--hitting it fast with a lot of momentum, but nonetheless, going up…
    At the end of the day though, in my case, I chalk it up to operator error
    Reputation: Mudguard's Avatar
    Can also happen if your front fork is a bit soft.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    Only happened to me once, which was a month or so ago. Tight lower speed downhill turn over roots and some rocks, I wasn't back far enough on the bike and I didn't pick a good line through the turn. Got into a bad position on the trail, tried to hard over the bar to salvage the turn, and over I went. At the time, I thought it was totally the result of me daydreaming or something. Never happened besides that one time, but like you said, it's all over in a hurry. I think this is 100% rider error when it happens.
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    I only know tuck in from street motorcycle riding which is a form of front end slide out.
    Flying over the handle bars is normally considered a high side but I also heard that term only in relations with motorbikes but who knows.
    Quote Originally Posted by Mr Pig View Post
    Avid is spelled wrong, there should be an 'O' in there.
    Reputation: elcaro1101's Avatar
    If you do it right, you almost feel like you are catapulted into the ground!
    Intense Spider29 / Motobecane FlyTi29
    Evolutionsverlierer
    Oct 2010
    Quote Originally Posted by elcaro1101 View Post
    I wonder if they teach that in riding clinics, if I would try to lean that I would wear one of those german army spike helmets, that would add some fun factor for sure.
    Aug 2013
    It happens when you turn rather than lean. You should have pressure on your inside grip (i.e. left grip to turn left). If you have pressure on your outside grip you'll end up with your front wheel pointing inside the curve of your corner.
    In my experience slacker bikes are more likely to push the front wheel in this situation resulting in nothing or maybe a lowside crash whereas steeper bikes are more likely to end up with the front wheel at 90 degrees to your direction of travel resulting in a huge OTB.
    I've ridden from 72 deg head tube to 67 degree, all kinds of variable speed AZ chunk, hard, soft, soft over hard, up, down, stiff fork or cush fork, fs, ht, SS, can't say as I've ever experienced anything even close to this.
    The question isn't who's going to let me, it's who's going to stop me.
    Reputation: DethWshBkr's Avatar
    ALL THE TIME here. I never had it on my Y33, nor my old '08 Fuel that I can think of. However, when I went to a 29er, I started getting it a lot.
    Now, I believe it is from not weighting the front wheel enough. I saw someone earlier thought it was having the front weighted too much, but I thoroughly disagree with that. The front loses traction, and begins to knife (or tuck) in.
    One way I have begun to compensate, is to change my cornering style to a more forward style as opposed to my old school "over the back" style.
    I have also started to use more front brake in corners, which is extremely difficult in loose situations, but biases the weight more towards the front wheel, and compresses the fork, and unloads the rear slightly. This should add traction to the front tire.
    Now, if the tire is locking up, due to too much front brake, it will immediately turn as far as it can. This would happen to me all the time on the MX bike. Hammering into a corner, slam the brakes, and I would start to knife the front end. That's actually one reason I wanted to go moto style brakes. My right hand is far more sensitive to the braking forces, and I can respond to a front wheel locking up. Nevertheless, if the front locking up is causing your knifing, then obviously backing off the front and biasing more rear brake is what you need.
    Reputation: Robg68's Avatar
    Oct 2013
    Quote Originally Posted by acer66 View Post
    I also know this as a "high side" back from my motocross days back in the mid to late 80's. I had this happen to me last year, I dove into a corner and ran out of talent and next thing I know I'm over the bars and my bike landed on me. Hurts a lot more when you get older.
    A "high side" as has been mentioned, is when the bike (front or rear, but usually rear) is skidding out. You feel like the bike will keep laying over until you hit the ground, but instead of doing so, (which is a "low side") the tires bite again. Unfortunately, usually you are now probably getting closer to perpendicular to your travel direction, and so you get launched over the bike.
    If that rear was breaking loose, the WORST thing you could do is chop the throttle. Stay on it, even if it means you are laying the bike over. It's far better to slide out than to high side!
    If the fornt is washing out, the best thing you can do as well, is to crack that throttle as hard as you can.
    Of course, that's impossible on a mountain bike.
    Evolutionsverlierer
    Oct 2010
    Quote Originally Posted by DethWshBkr View Post
    What about e-bikes?
    Jun 2013
    Wow, some excellent responses from those of you who have experienced "tuck".
    My friend had been trying different stem heights. Could this be contributing to his dilemma?
    His bike is a DeVinci Wooky -- new to him this year -- so he's still sorting-out his 'fit' on it.
    Many thanks to all contributors.
    I'm not sure if I've ever experienced what you're talking about, but is this just wheel flop, perhaps exacerbated by the terrain?
    Jun 2013
    Yes! Very similar, Geralt. The concept is the same; the front end starts turning more than the rider desires or is expecting.
    The difference is Flop can be recognized and corrected-for early and easily, whereas Tuck sneaks up on you, generally when there is a lot of steering angle on the front end, rider's body weight is forward, and the forks are compressed.
    Think tight, low speed, downhill switchback. (Thank you, Ladmo.)
    In that sort of specific, critical situation, some degree of unhappiness from the front end is pretty much understandable, but when it happens in somewhat moderate situations it's an indicator that something is not quite right in the geometry or setup of the bike.
    There is a myriad of possible contributing factors, so I'm hoping someone here has dealt with Tuck successfully and offers some possible cures.
    Trail Ninja
    Reputation: Varaxis's Avatar
    Happens when I want to take the inside line with more speed than I'm comfortable with and give it a bit too much angle. I don't "only lean" or "only countersteer" when I turn; I try and swing my weight around, when I have momentum I need to carry around a bend in the trail. My "swinging" movement incorporates a countersteer, lean, weight shift/body position, AND a handlebar turn, to theoretically offer the max ability to carry myself around turns that are practically 90 degrees or sharper.
    When the highside/tuck happens, I basically end up either cartwheeling, outside hip first, over the bars, or the front just bogs down enough, maybe even to a stop where it digs in, and the rear overtakes it and swings around to the front.
    I figure I just need to tweak my lean angle, and tweak my positioning a bit to be more centered between the wheels and have even pressure on the front. Just need to be on the front long enough to get past this critical point, then I can shift weight more to the rear to follow through on the corner.
    Processing a couple videos in which I caught it happening, so I can post them here as examples:
    Both are Specialized bikes (top SJ FSR Evo 26, bottom Enduro 29), both are running Pikes with higher offset (27.5/44mm on the SJ, and 51mm on the 29er), both are on 2.4 Maxxis tires up front and relatively low profile rear tires.
    (Click the 2nd pic if you want to see the source for the higher speed example. It happens at around 6:05. Seems like the sudden "jolt" from the "tuck/highside" was enough to tweak my GoPro's aim)
    Binned
    Nov 2008
    Less brakes and lean the bike into the turn while you, the rider stays in a more vertical position. Or, put a foot down when needs at slow speeds.
    Another possibility is a poor match of tread design over a given terrain.
    2nd video was all worth it for the spandex ninja at the end!
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Hawg View Post
    I thought about the tread issue as well but that would just cause a wash out [a slide].
    I'm thinking it may be a 26"-29" carbon frame aluminum frame dropper post non dropper post long stem short stem wide bar narrow bar issue. Any combo there of can certainly cause a front end tuck.
    Quote Originally Posted by WHALENARD View Post
    No way man! The great Vans debate of 18 was epic!
    What about e-bikes?
    I'll stick to my original statement!
    On those things - when in doubt, gas it!
    I didn't do it
    Reputation: Mookie's Avatar
    What the hell? I've never ever had this happen to me and I've never even heard of this phenomenon before. Right angle to the direction of travel? Wow that ain't good. OTB ya go!
    Let's eat Ted
    Let's eat, Ted
    Remember, commas save lives
    That's the start of a front end tuck.
    Irrelevant to HOW it starts, the front wheel will NOT tuck under unless it loses traction.
    Whether that loss of traction is due to tire pressure (too high causing poor bite, or too low, causing sidewall flex or insufficient tire pressure pressing into the dirt), tire compound/tread, rider position, too much braking force, or poor dirt traction on it's own, the front wheel MUST lose traction to knife.
    Again, with me, I was always a "grab the saddle with my thighs and lean back" to keep the front wheel nice and light. The newer bikes just do not like this, and I have struggled to change my riding style to put more weight over the front.
    Professional Crastinator
    Reputation: Fleas's Avatar
    In my world, the definition of "front end tuck" is when you get into an oversteer situation. Everyone I know attributes it to a too-soft suspension fork.
    When you enter the turn, braking or not, if the fork compresses too far as you load it for front traction (or just due to g-forces), the head angle changes enough that the fork trail becomes too small/short. Beyond a certain threshold, esp. with steeper headanlges, the fork trail causes an increase in oversteer even as the bike is already oversteering.
    It can be corrected most simply with an increase in fork pressure, with wider bars, or maybe a higher offset fork, or maybe a longer fork if the bike frame will tolerate it.
    I ride rigid so I NEVER have that problem.
    -F
    PS - I just got back from a weekend of riding where we reminisced about crashes at that trail system (they love to remind me how I hit most of the downhill turns too hot and ride off into the forest). One of the worst was a guy on a FS bike who oversteered through a g-out and got stuffed into the wall when his bars practically ripped out of his hands. The combination of high speed, possibly low tire pressure, really high g-forces through the turn, and narrow bars resulted in a wicked crash. Essentially, the bars crossed, the bike stopped, and he got stuffed into the turn, shoulder-first.
    It's never easier - you just go faster.
    Loves moped riders
    Aug 2013
    Front washes, you overcorrect, hook up, and crash, and that's called a 'tuck'?
    Learn something new every day...
    Oct 2000
    As you and I both know this so called "front end wheel tuck" has been given the wrong name. In the motorcycle world we call it high siding.
    "Did you see Bob high side as he was entering that berm"?
    Prior to this jump I did a front end wheel tuck [high sided] but saved it at the last second.
    High Side compilation
    Evolutionsverlierer
    Oct 2010
    Autsch, I crashed quite a few times on a motor bike but fortunately never had a high side.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I know the phenomena, but it has never made me fall.
    Everyone knows wheel flop, right?
    And everyone knows that there's only so far the wheel will turn when it flops?
    This "tuck" thing happens past that point, when the wheel is turned further than it would flop. It feels like the head tube wants to head straight and past the contact patch of the front tire.
    "Tucking" can be initiated on almost any bike by turning the bars with the bike upright. It can be avoided by leaning the bike more (a good feeling to look for is to push the grip down on the inside turn) and keeping a solid control to the bar.
    Sounds like we may actually be talking about two different things.
    Here's MX video of two of my front end knifes that I actually got on video!
    https://www.youtube.com/watch?v=RufTGiEH_bI
    First video, my first time on the bike. Bought it used, and it had a crap front tire on it. Came into the corner, was not quite familiar with the bike, and locked up the front. You can see the "jerk" when the front end knifes in, and I end up low-siding it. Ooops.
    Second video, entering turn two, someone starts to crash right in front of me (also a front end knife). As soon as I grab my front brake, you can see my front wheel lock up, and knife under. Both instances, low sides. I only went over the bars because of impacting his bike.
    I ran it slow motion too.
    The street video above is indeed high sides. Rear wheel usually breaks loose, you so sideways, and down you go. Street bikes usually high side MUCH quicker than an MX bike.
    Jun 2013
    DethWsh, those dirtbike vids indeed look like classic front end slides, AKA Low Side. The front end starts to push, it never hooks up again, and the bike (and rider) slide to the ground on the inside of the turn.
    A Tuck is when the front tire hooks up, slams the fork to the stops (on a motorcycle), and pitches the bike & rider to the outside of the turn.
    The lower speeds of a bike usually (just?!) has a rider going over the bars, but the higher speeds on a motorcycle wind up sending the rider into the air -- a classic High Side.
    Some great discussion here, and the videos are a bonus!
    Reputation: Mr Pig's Avatar
    I did this years ago while trying a friend's bike. Later realised that it was because his bike has a much longer stem than mine. Personally I feel that shorter stems give you much more stability in corners.
    May 2015
    If you put your bars in neutral position, in 95% of cases, if you are turning them past about +/- 30 degrees, you are likely to be oversteering and at risk for an endo.
    The usual argument here is super narrow trails at low speed and then switch backs on top. The problem is when someone is in a negative angle, they are likely front loading their suspension, likely on their front brake, and then they wrongly twist their bars to steer through the turn. The result is a nice endo.
    In this situation, should either A) Lean the bike into the turn and counter-steer, or B) lock both brakes into a track stand and hop the bike into a better position.
    Problem is many people don't know how to perform option B, and option A scares a lot of people. The result is people struggle their way though it and hope not to endo.
    I agree with this. More bike lean, less brake
    OK, so it sounds like I am interpreting things differently. Both of those clips of me, the front end started to slide, which then makes the bars go to the stops. (Or in the case of a bicycle, just push out. )
    Yeah, if you're not ready on the bars, they will turn to a point which the front wheel will not roll anymore, but instead "stuffs" and pretty much could make you go OTB, since you are really "slamming on the brakes" to the front wheel.
    Still should be a lack of traction to the front wheel. I have gotten a lot here (again, since going to the newer bike) where I'm just cruising a corner, and the front end DOES start to turn a lot more than I'm expecting. Usually I am able to just clip out and stab the ground with my foot. One time I couldn't save it, and went down (it was a slightly slippery day).
    Now I'm wondering however...with as tight as most trails seem to be, if this issue isn't made worse because the front wheel is breaking loose, it just goes straight. As a result you hit something at the edge of the trail (or the trail edge itself). Since the front wheel is no loner rolling along the terrain, but instead skidding, it just stops, and boom. You're flipping.
    MTB B'dos
    Reputation: LyNx's Avatar
    Curious if any of you guys experiencing this are running Ardent tyres on the front??
    Oct 2014
    Huh, I'm running Ardents--2.4 in the front. Well, in my case I think it's still 99.9% operator error!
    If it keeps happening to him, then you can bet that it's user error. The dude needs to overcome whatever gut reaction he is following when he is in those situations. the cause is simple, breaking the habit may not be.
    Evolutionsverlierer
    Oct 2010
    Quote Originally Posted by Flucod View Post
    Maybe, I raced Pro for 20 years and it ONLY happened with that tire (many times). IMO its the tire, lol!
    Sorry mate, this is the internet so real life experience does not count only hearsay.
    SP Singletrack rocks
    Nose wheelies.
    Oct 2000
    T
    Nice vids but neither one of those were high sided crashes. When I brought up the topic of motorcycle high side crashes I meant turning and having the front end stick and the rider flys in the direction of the momentum and the bike flips. Been there done that but never on vid.
    Back to the front end tuck phenomenon.
    Front end tuck is when your front breaks traction, you can watch the forks unload, typically go to full lock and your face and shoulder typically go straight to the ground. Very common when trail braking hard into the corner.
    http://youtu.be/7cZKaBN-qP8 Great example at the end. Still trying to find a pic or vid from off a bike
    Next point of view of another front end tuck http://youtu.be/qCwcDMsLUpI
    T
    Nope. I haven't high sided in 15 years!
    Killer b.
    Reputation: The Understater's Avatar
    Yes, but only with the 2.25 on 26". It doesn't hook up and washes out.... not to be confused with tucking. The solution was to fit a 2.4 which is a totally different beast with proper edge blocks.
    Got it on video too. Caught me completely by surprise and I wasn't even pushing it.
    How not to ride Corners, Rotorua. Video - Pinkbike
    I used to tuck the front on my Amp B4 with 90mm stem and somewhere in the neighborhood of a 70 degree head angle. I would turn into a high speed corner and the ground would reach out and grab the wheel and twist it inwards, throwing me over the bars. Part of it was bad technique on my part. Standing too upright on the bike and steering it too much instead of leaning it. The long stem and poor geometry just made it worse.
    By the way, talking about high-siding a motorbike is not helpful. Tucking the front on a road-race bike is when you go into a corner too hot on the front brake and it loses traction, tucking in in the process. Mortals like me then low-side it and chuck it down the road. Legends like Colin Edwards can save it with their knee.
    https://www.youtube.com/watch?v=37sl4YI-aYE
    Tucking the front on a mountain bike is a different beast and what I used to call jack-knifing.
    Posting on the basis that ignorance shared is ignorance doubled.
    Killer b.
    Deathwishbiker, I would seriously not recommend the technique you were espousing to turn your mountain bike. Don't reach for the front brake to put more weight on it in a corner.
    Watch some videos, like this:
    https://www.youtube.com/watch?v=gF5K9V2w6W8
    One thing that will help:
    Heavy feet, light hands.... Stand on your outside pedal, drop your heel, and allow your knee to bend slightly, preferably in toward the frame. Physically lift your outside elbow, push down on your inside grip to create lean angle, and twist your hips to stick your ass outwards and your upper body in.
    Do NOT lean on the outside grip! This mucks up your front tire's ability to track the terrain and loses you a lot of traction. Your weight should be centered on the bike, not leaning on the front.
    And braking in a turn adds an extra axis of force on your front tire when it is already fighting for grip. Don't do it.
    Sep 2014
    This is similar to the turning technique I read about (I forget where) but it has improved my descending greatly - especially on smooth gravel / dirt where grip is really hard to find.
    Basically you always have the inside pedal at 12 o'clock, outside at 6 o'clock, light hands, heavy feet (centre your weight on the bike), push down more on the outside foot than the inside, lean the bike into the turn, turn your hips into the turn too and let the bars find their natural attitude (don't lean on or turn the bars more than they want to).
    This should allow you to use your entire bike and body to steer and harminise between the lean angle and the angle of the bars, rather than just relying overly on any one component to turn.
    When I first tried it, I was cornering at my usual pace and felt that I was in danger of toppling over into the turn - apparently a sign that you can take the turn faster.
    Oh, and never NEVER use the brakes once you are committed to turning. Always adjust our speed beforehand. A light drag on both brakes are fine to scrub off some speed but if you try to grab a hand full of brakes (front, back of both) in a turn you are asking to eat dirt.
    Oct 2012
    One way to look at it is trail: normally trail is positive and indicates the distance between where the steerer axis is pointing (forward) and tire contact patch (rear).
    A slacker head tube angle means the steerer axis is pointing further forward -> fork offset is increased to prevent trail from increasing. When suspension compresses, the head tube angle steepens, and trail is reduced. Effectively if your bike was handling quickly at sag height, it will steer even more quickly when compressed. Even if the rear suspension compresses as well, trail is still reduced because head tube height is lower (steerer axis can't point that far forward).
    When you run into a bump, the tire has a new contact patch much further forward than normally. The contact patch could be in front of the point where the steerer axis is pointing, and you get effectively negative trail. If the front wheel is straight, no problem. If it was turned to either side, it will try to turn further.
    Again, leaning helps against this movement and having a solid grip on the bars will stop any surprises. Leaning a lot means you must counter-steer, and counter-steering helps against tucking.
    Quote Originally Posted by Saul Lumikko View Post
    That's what I said...
    Quote Originally Posted by Fleas View Post
    When you enter the turn, braking or not, if the fork compresses too far as you load it for front traction (or just due to g-forces), the head angle changes enough that the fork trail becomes too small/short. Beyond a certain threshold, esp. with steeper headangles, the fork trail causes an increase in oversteer even as the bike is already oversteering.
    -F
    Quote Originally Posted by Ghost_HTX View Post
    ^^^That's a very understandable way of saying it.
    -F
    To reiterate the "tuck" or "flop" I'm referring to is not a front end washout or really anything related to traction. It's more of a geometry thing. I think Saul's relating it to steering trail hits upon what is going on. I've thought about it that way too.
    Another way to think about it is the steering reaches an inflection point where the tire wants to reverse rolling direction. I can feel it just riding on the street and doing tighter and tighter slalom turns. You'll reach a point where the steering kind of catches.
    I don't think the cause is rider error necessarily, but better turning technique keeps you away from that inflection point.
    I've tried to think about what I could physically change on the bike to help avoid this. It would be interesting to only change fork offset to see whether more or less offset helps.
    Sep 2014
    Actually, referring to what Fleas wrote; I only ride rigid too - so compression of the front suspension is not really an issue for me either
    May 2015
    Quote Originally Posted by SoCal-Rider View Post
    Everything is rider error.
    Some things can be made worse, made better, improved upon, or prevented based on a gear swap, but not knowing how your bike is going to operate in different circumstances I still claim as operator error. The bike didn't cause the rider to wipe out. How the rider was riding it caused the rider to wipe out.
    Just like driving a car in snowy/icy conditions. When you blow a turn and slam into a snowbank. Was the car at fault? Was the conditions at fault? I am sure you would love to say so, but it was your driving too fast, braking technique, or a combination of the two that caused the accident.
    If you had a failure on your bike, such as a tire pop, catastrophic frame/fork break, etc? Ok, that is potentially out of your realm of control. If you are riding, the bike operates as intended, and you lose control of it? Sorry, but that is you.
    I am not perfect either. I have wiped out. My pedal kicked a rock or stump and shot my bike sideways with me still attached to it. I was on the ground before knowing what happened. I could start investigating different cranks, different pedals, different geometries, and whatever else. That or I could watch my lines better to know what is coming and how to handle it.
    Right. Unless you've got a leaky front tire, it never happens on a rigid bike. Well, maybe in a really tight turning g-out I might get a little ahead of myself once in awhile and induce it via weight transfer, but the fork is pretty constant.
    -F
    Oct 2000
    I've never experienced "front end tuck", although I'd like to. Anybody know where I could attend a front end tuck beginner training course? And are they pricey?
    May 2015
    Look for a turn, sit upright, flip the bars 90deg to a side and enjoy the ride. A helmet and/or jockstrap may be desired.
    While you are airborn, say "Supermannnnnnnnnnnn"
    No. PayPal me £100 then ride round your garden with your phone in your pocket. I'll call you and when you try to answer you'll do a front-end tuck ;0)
    Jun 2013
    This is exactly how I crashed bad and took a bunch of skin out of my forearm this summer. I went into a loose corner with some lean but the front wheel started washing out, so I stood up on the bike and turn the bars and then I'm sliding on the ground as the bike flew to the opposite side of where i fell. Sounds like a lame excuse but the Fox CTD fork with crappy mid-stroke support was partly to blame for me not able to recover the initial slide. The thing brake-dove like crazy even in Trail mode and I felt I couldn't load the front tire well since it blew through travel so quickly. I ended up selling that fork after I crashed and now I have no issues (knock on wood).
    This guy teaches front end tuck classes:
    He IS pricey though... It might cost you a small dog or part of your lower intestine.
    -F
    May 2015
    -F
    ...or a bottle of lotion.
    Jun 2013
    I have your dog, mister!!
  67. #67
    Quote Originally Posted by The Understater View Post
    Same principal with the front end tuck, that vid is a save kinda of, really he crashed and got lucky. Saving a front end slide is easy to me now, to bleed off corner speed w hen racing I would purposely slide the front end. Takes some balls to learn, and it did cross over to mountain bike riding.
    The big difference in the way we crash vs a motorcycle, steering lock, mountain bike don't have one , bars go further and can odd fun to the way you crash.
    We can even high side a MTB, heavy brakes into a corner, skid the rear, let go of brakes, catch traction and time. For a ride.
  68. #68
    Quote Originally Posted by terrasmak View Post
    I am getting OT a little, but I have gotten a weird feeling from the front end of my Yamaha FJR from time to time when leaning hard. I am wondering if it is going to push, or just flop over on its side. It feels like it will push if I go harder without getting out of control - which sounds like what you can do on purpose. I know I have done this on our tandem MTB in slick conditions. That bike seems to not want to tip over, even when the front tire is sliding. It has to slide a very long way to actually lose it. Maybe the wheelbase is what forgives the tuck in those cases.
    -F
  69. #69
    I think so. That and the shear weight of the bike. If you think about the stalled front wheel is trying to throw the bike, either sideways or up in the air. The length and weight on the tandem will make that very hard for it to do.
  70. #70
    I experienced the tuck for the first time in a long time. Was trying to "force" a downhill switchback with lots of loose rocks and roots.
    '15 Giant Anthem SX - '01 Schwinn Homegrown Comp - '12 Giant Defy 1 - '14 Kona Jake the Snake
  71. #71
    -F
    Weight, traction ( tire comp and surface) head tube angle , wheelbase , body position and even suspension will effect the outcome. Basically everything
  72. #72
    That's just it... on the tandem, the weight (~370#), a loss of traction (2.3 Nevegal up front), HTA= ~70 , the wheelbase, the static body position, and no suspension, and it won't fall over. It's crazy! It seems the overbearing variables are the weight and the wheelbase, when compared to all other bikes. Same with the motorcycle.
    -F
  73. #73
    Reputation: DaveRider's Avatar
    Jul 2014
    "Front end tuck" sounds like when you've been on a long ride & you get "turtlehead" from your crotch going numb. Like the cyclist's version of the famous George Costanza "shrinkage."
  74. #74
    Feb 2006
    Stay Off The Front Brake!
  75. #75
    Oct 2000
    Quote Originally Posted by DaveRider View Post
    Similar but George had an excuse. It was cold the water was cold.
  76. #76
    Reputation: ColinL's Avatar
    Feb 2012
    I didn't see this discussion the first go-around, but someone linked to it from another discussion today... Good stuff.
    Cool vid of your ride, bummer that you crashed. It happens pretty fast, but it appeared to me that you caught some air while the bike was cranked over, and you didn't have enough weight on the front after landing. You had a pretty classic lowside, not this 'tuck' and then highside that others are attempting to describe.
    One thing that is missing from the previous discussion is that this doesn't happen often, or possibly at all, on a motorcycle because of the remarkable difference in center of gravity. The rider is a huge proportion of the weight of a MTB+rider combination, and typically a rider is about roughly half of the weight of a dirtbike+rider, and less than 1/3 of a sportbike+rider. On average.
    So, when the the MTB tire loses traction, then gains it, physics are all too eager to launch the very high CoG of the rider right over the top. The ability of the bars to turn to 90deg helps, but isn't necessary for being ejected.
  77. #77
    Nat
    Nat is online now
    Reputation: Nat's Avatar
  78. #78
    Oct 2000
    I almost experienced this on today's ride and this thread came to mind. Excuse me if it hasn't happened to you but trust me in saying, it will if you ride with careless abandon.
  79. #79
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Nat View Post
    Ok DJ...Nat threw the bait...and you took it.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  80. #80
    Oct 2000
    Quote Originally Posted by Cleared2land View Post
    Seven months later.
  81. #81
    Dec 2016
    I am now on alert DEFCON 5 for the Front-end Tuck. I'm sure if I am missing something, but I can't make myself turn the bars 90*.
  82. #82
    Nat
    Nat is online now
    Seven months later.
    Ha ha, what did I even say?
  83. #83
    Oct 2000
    Nothing, I wasn't replying to your post like C2L lead us all to believe. I almost had a front end tuck yesterday on my ride.
  84. #84
    Magically Delicious
    See...you took the bait.
  85. #85
    I didn't do it
    About a week ago I saw some old dude, looked to be about 70 - 75 years old, riding an older style e-bike down a hill (urban setting, he was on the sidewalk). He came to a crosswalk and he obviously wanted to cross. The problem was that when he turned left to get into the crosswalk he had a near front end tuck and almost dumped the bike. He tried like hell to get the thing straightened out. I thought for sure he was going to end up just shooting out into traffic. But at the end of the day the geezer got the rig straightened out and into the crosswalk in one piece. Whew!
    Let's eat Ted
    Let's eat, Ted
  86. #86
    Nov 2016
    Quote Originally Posted by MozFat View Post
    That's what bites you, you don't turn the bars, physics does.
    The same phenomenon can be seen on loose and steep downhills where the rider doesn't have their weight far enough back. The front wheel breaks loose and then catches hard. This does potentially, almost certainly really, does two things, yanks the handlebars, even just slightly, in one direction and slows the bike suddenly causing the rider to put even more weight forward. Now that the bars are off center that weight shift is going to naturally put more weight on the outside bar and continue turning sharper and sharper. The wheel crosses the maximum perpendicular threshold, the end starts to lift and gravity, and momentum, do the rest.
    The same thing happens in corners but gravity really isn't in play, just forward momentum. Ever heard of someone trashing a wheel in a smooth, flat corner. The same forces likely happened whether they managed to lay it down or went over the bars.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  87. #87
    Oct 2000
    Quote Originally Posted by Mookie View Post
    So a front end tuck doesn't age discriminate.
  88. #88
    I didn't do it
    Oh yeah. It can happen to anybody at any time. Often without any warning.
    Let's eat Ted
    Let's eat, Ted
  89. #89
    Jan 2009
    Quote Originally Posted by Geralt View Post
    This. It's called wheel flop guys.
  90. #90
    Reputation: Deerhill's Avatar
    Dec 2009
    This is true. I saw some geezer tucking his front on the dh once, was a bloody mess. Poor sob
  1. Ccdbair cs xv experienced help please
    By AaronJobe in forum Shocks and Suspension
    Last Post: 12-26-2013, 05:19 PM
  2. Tuck and roll
    By slide mon in forum California - Norcal
    Last Post: 01-27-2012, 05:16 PM
  3. Experienced help needed please?!
    By MWillis in forum Beginner's Corner
    Last Post: 06-28-2011, 09:18 AM
  4. Tuck and Roll
    By brad72 in forum All Mountain
    Last Post: 05-02-2011, 01:57 PM
Members who have read this thread: 13
