Results 1 to 18 of 18
    To Frame Repair or Not Frame Repair
    Picture: A 2005 Turner 5-Spot frame that cracked on the top tube (all the way around) at the weld that holds the gussett to the seat tube.
    Imagine: Welding the frame up (known aluminum welder) and riding the heck out of it for four months afterwards.
    Picture: Carrying the bike off the trail, back to the truck, after a four mile hike-a-bike session and being thankful that my thigh or other body parts were not impaled.
    Synopsis: If you break it, dont fix it. Dont think you can fix an aluminum tube by simply having it welded. The heat treat is not performed and the tube hardness, along with surrounding welds, goes to ZERO once heated. Yep, lesson learned.
    Hope: Are there older Turner 5-Spots available here and if so, is it really worth consideration since there is a life limit on aluminum regarding stress fatigue. Hmmmm??
    A friend has a 5 spot broke the swingarm ,Turner replaced it for free.
    Plays with tools
    Reputation: customfab's Avatar
    I've seen aluminum bikes that have been welded back together go both ways.
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
    Reputation: gmats's Avatar
    Apr 2005
    Contact Greg at Turner. They're super cool. They've had history of some really amazing deals as far as frame replacement, purchase new with deep, incredible discounts. It's not specific to the original owner - ANYone owning a Turner frame.
    Bummer, good luck with that.
    Rep: to infinity and beyo
    Reputation: deke505's Avatar
    Glad you are alright and not hurt. Yeah re-welds don't hold well on bikes. When I was a kid I kept breaking the bottom tube of my bmx, My dad got tired of buying new bikes (I was only 8 or 9 at the time so I couldn't buy my own) so he took it to some industrial welders to weld it back together. Guess what I still kept breaking it until the welders got fed up and welded another flat bar on its side to the tube.
    Turner Dudes
    I've spoken to Greg in the past and called him again today. They do get older frames in for either replacement, rework or other. I should be getting a call soon (I hope) for him to let me know if they have any front triangles. Would be nice!!
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    You should heat treat an alu frame after repairing it. Some companies do it.
    Nov 2012
    is it a good way to welding a broken frame? please advise, i had a friend had a broken frame and he rather confusing to repair it or buy new one
    txs
    It depends most aluminum are heat treat ,when you reweld them you lose the heat treating making the frame weak. Most steel and Ti can be rewelded without a problem. What is the frame made of? Some bike makers have what they call a crash replacement deal and some of those will sell you a new frame for less than you could get one otherwise.Check with your LBS.
    YOUREGO ISNOT YOURAMIGO
    Reputation: GoGoGordo's Avatar
    Whats up Troll??
    Attached Thumbnails Attached Thumbnails To Frame Repair or Not Frame Repair-img_0968.jpg
    A pristine bike free of dirt, scratches, and wear marks makes me sort of sad
    No Rep
    No Problem
    Banned For Boobies
    Bad rep reply - To Frame Repair or Not... 11-28-2012 04:28 AM u got issues
    Yes I do.
    Thank you for noticing.
    GoGo the Deeoooosh
    Rep is up now!!
    Good bye Troll.
    No Rep
    No Problem
    Banned For Boobies
    Loving the Maxi Pad post. I just hope its the "large" size. Other than that, I dealt with Turner reps that found me a replacement front triangle. Its from an 05 RFX and yes, the rear triangle from the 5 spot will work very well with this frame.
    From the "suspension" forum, not sure who tagged me, or posted all the **** I saw with my name on it but, hey, this is the online world. TURNER RULES!! Back on trail soon after all parts from Chain Reaction.com arrive!! YAHOO!!.
    Forgot to mention that the rockers from the 5-Spot are going on the RFX. Can't wait to crash again!
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    i purchased a repaired 1997 ibis alibi frame from the factory knowing full well it had been repaired by the factory.
    the repairs were done at the bottom bracket shell/seatstay yoke.
    i rode and raced that bike on and off until recently. the frame is still whole.
    Dec 2012
    I've always wondered about this....interesting. I do not know the process but would any kind of shops be able to weld it more properly? Or is the heat treated process only really done at the bike factory?
    Heat treating can be done by any shop with a big enough furnace/oven. Call them if you have any doubts.
    That said, a weld is a stress riser. Like Customfab said, it can go either way.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    Heat treat
    If you have an aluminum frame welded, the HAZ ( heat affected zone) is weak. You need to strip the frame and have it properly heat treated. There are companies that do this. I had a C'Dale Jekyll welded and professionally heat treated. They brought the repaired frame back to T6 temper. It involved heating the frame to 1,050 degrees and then quenching it before baking in the oven at 400 degrees for 4 hours.
    This is not a process to be taken lightly. If you don't do it right, don't do it at all!
    I did it. I did research on welding and type of rod to use and what had to be done after welding. It can be done, but it is neither cheap nor fast. But if it is done right, no worries.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Reputation: supersedona's Avatar
    Dec 2012
    HTS-2000 welding rod is supposed to work well for that application(advertized but not personal experience). Reported to work at 300 deg to not affect any precipitous effects or extreme HAZ issues. Obviously not as neat as a factory replacement, but a good option for heading off an early detected crack in aluminum.
Hot Deals
Contests
Latest Mountain Bike Articles
