    Reputation: spitfire's Avatar
    fox ventilator knee/shin guards
    thos of you with the fox ventilator knee/shin gueards. what have you done about the knee flapping around? and can you show a pic of your pads with the modification you made to them. i have just been thinking of cutting off the knee pad and making them into shin guards
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Quote Originally Posted by spitfire
    I sewed velcro on the ends of 2" elastic straps and sewed them to the "wings" on the knee pad. It was not easy, but it works okay. If I get a chance tonight, I'll shoot a couple pics.
    Kathy
    Look where you want to go. This is as true in life as it is in mtbiking.
    Okay, photo time. I used 2" elastic and 2" stick-on Velcro. The hardest part was sewing through the stick-on velcro because the glue kept gumming up the needle. Wiping beeswax on the needle frequently helped. The hook side of the Velcro is sewn on the end of the elastic, and the pile is on the knee shell and pad. Be sure to set up the left and right sides so the ends of the straps are away from the frame so they don't hang up on the bike. I got all the stuff at a fabric store.
    2" Elastic:
    The stitching inside:
    And the stick-on Velcro. On the padding, it's also sewn like the elastic.
    Hope this helps.
    Kathy :^)
    thanks for the help
  1. "Issue" with Fox equipped Burners
    By dirtysprocket in forum Turner
    Last Post: 08-01-2004, 06:00 PM
  2. Noticed Fox fork angle issue.
    By TNC in forum Shocks and Suspension
    Last Post: 05-14-2004, 05:45 PM
  3. Fox F80RLT vs. my tired old Manitou
    By dgangi in forum Shocks and Suspension
    Last Post: 03-20-2004, 11:33 PM
