Results 1 to 8 of 8
Thread: Fox 4.0 DHX
    Jul 2013
    Fox 4.0 DHX
    Hi ye all - does anyone have a table for PSI (bar) to weight for the air pressure configuration?
    Txs
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I bet fox does It comes down to frame design as well. Find fox's recommended settings and then adjust either way to get it right.
    Jul 2013
    Fox actually recommend a range 125 to 200psi and thats the end of it. Txs anyhow
    bikeaholic
    Best way to determine appropriate air pressure is to measure sag. This will vary depending on shock, frame, and riding style/terrain, but shooting for 20-30% sag is generally a good baseline:
    Measuring Sag
    Reputation: Bemiller's Avatar
    Jun 2013
    I looked far and wide for this elusive chart and my conclusion - it doesn't exist. Best bet is to measure sag. At 160 lbs w/ gear I have my main chamber at 160 and boost chamber at 165 psi right now after doing minor adjustments for past 3 weeks on new bike.
    Jul 2013
    Thanks a lot guys - adjusting it via the sag makes perfect sense. Ended up with around 25% sag at 150psi (I'm a bit lighter than you it seems).
    cheers and happy rides this w-e!!
    Jun 2013
    Quote Originally Posted by Uzzi Man View Post
    You're referring specifically to the boost chamber.
    Main chamber is 50 to 300 psi
    I ride bikes
    Apr 2013
    Also, I have used a DHX air 4 and had nothing but problems with it. Not a very great shock IMO. I upgraded to the DHX air 5 and it was a huge improvement.
