Results 1 to 3 of 3
    May 2013
    Forge Sawback 5xx or Airborne Sabre? Noobie needs help deciding.
    Hey everyone,
    I'm just looking for a cheap starter bike. I'm going to do a lot of road riding with it, but take it on some light trails also. I've narrowed it down to an Airborne Sabre for $249 or a used Forge Sawback 5xx for $200 (talked him down from $350) $250 is my budget for a starter bike, then I can upgrade if needed. I'm leaning toward the Forge because it has slightly better components but the Airborne would be brand new so I'm torn on which to go with. The Forge is about 4-5 years old but was only used minimally on roads, no trails, so it should be in good shape. Here's the setup for both if you are not familiar. I would just like some opinions if there is one that is better than the other. Thx!
    Forge Sawback 5xx
    • All-aluminum, double-butted lightweight frame with WTB SpeedDisc XC rims, saddle and grips for real quality
    • Shimano Deore 27-speed derailleur and Shimano Deore shifters
    • AVID BB-5 mechanical disc brakeset for ultimate stopping
    • RockShox Dart 1 100mm travel with preload front suspension
    • Truvativ ISOflow aluminum triple crankset
    • Manufacturer's Suggested Age: 18 Years and Up
    • Gear Speeds: 27
    • Bicycle Frame Height: 19"
    • Bicycle Frame/Component Features: Suspension Fork
    • Bicycle Frame Material: Aluminum
    • Suspension Type: Front
    • Suspension Features: Front Suspension Travel
    • Seat Features: Ergonomic
    • Brake System: Disc
    • Front Brake System: Disc
    • Rear Brake System: Disc
    • Derailleur Manufacturer/Type: Shimano Deore
    • Shifter Manufacturer/Type: Shimano Deore
    • Bicycle Chain Material: Aluminum
    • Wheel Features: Quick Release Front Wheel
    • Rim Material: Metal Alloy
    • Front Wheel Height: 26"
    • Rear Wheel Height: 26.0 "
    • Tire Type: Knobby
    • Tire Width: 2.10"
    • Includes: Water Bottle Mount
    • Maximum Weight Capacity: 250.0 Lb.
    • Care and Cleaning: Wipe Clean With a Damp Cloth W
    • Dimensions: 110.0 " L x 110.0 " H
    • Weight: 30.0 Lb.
    • Warranty Description: 1 Year Limited Manufacturer Warranty
    • Battery: no battery used
    • Bike Type: Mountain Bike
    Airborne Sabre
    Frame 6061 Aluminum Hardtail MTB
    Fork Suntour XCT with 80mm travel
    Headset Ahead Sealed Cartridge 1 1/8"
    Brake Levers Shimano ST-EF51
    Brakes Tektro Novela Sport Mechanical Disc
    Rotors Tektro 160mm Rotor
    Shifters Shimano Acera ST-EF51 EZ-Fire Plus, 21-Speed
    F Derailleur Shimano TY10
    R Derailleur Shimano Tourney TX-51
    Cassette Shimano TZ31, 7-speed, 14-34
    Chain Taya 7speed
    Crank Prowheel MC-A321 Alloy
    Bottom Bracket Cartridge Type
    Pedals NONE
    Rims 32H Alex C1000 alloy rims
    Hubs KT-SP5F 32H Alloy
    Spokes Black 14g Stainless
    Tires KENDA 26 x 2.1" Front/Rear Specific
    Handlebar 31.8mm Diameter Alu oversized 640mm wide
    Stem 31.8mm clamp alloy
    Saddle WTB Speed V Saddle
    Seat Post 30.0mm dia x 350mm EN-R alloy
    Extras Owner's Manual, Clear Coat, H20 Bottle Mounts
    At least with the Forge you could test ride it ,and if it fits go for it.
    You're looking at pretty similar specs here and likely comparable weights/ build quality. Go for the Forge if it's in as good a shape as you say and put the leftover scratch toward component upgrades down the line.
    Ever been to Mountain Bike Tales Digital Magazine? Now if only the print rags would catch on!
  1. Forge Sawback 5xx Still a Good Deal?
    By Ace5high in forum Beginner's Corner
    Last Post: 05-21-2016, 04:47 AM
  2. Forge Sawback 5xx 17" Silver
    By JRSCCivic98 in forum Bike and Frame discussion
    Last Post: 06-04-2014, 09:39 PM
  3. Pricecheck on beginner bike: Forge Sawback?
    By epik in forum General Discussion
    Last Post: 06-27-2012, 05:36 PM
  4. Forge Sawback back on sale.
    By austanian in forum Beginner's Corner
    Last Post: 04-25-2012, 03:57 PM
  5. Forge Sawback 5xx with Dart1, can I swap on a Fox F120 RL?
    By JapanExpress in forum Beginner's Corner
    Last Post: 03-05-2011, 01:39 PM
