Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Favorite lube
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Favorite lube
    Not trying to start a pissing match here, but what is everybody's favorite lube? I assume everybody has a personal favorite; perhaps an old standby that has never let them down.
    Olive oil works great, but can stain. Usually I just use spit. Used to use Astroglide, but not anymore... and never use the warming kind. That ish will set your junk ablaze.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    tri-flow
    Feb 2012
    Lube for what? For example, for chain lubes it largely depends on your riding conditions. Do you ride in dry, dusty conditions or wet, muddy ones? It's like asking what type of tires you use. It's meaningless unless you know more information.
    Jan 2013
    The natural kind.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    "Back off, man. I'm a scientist."
    - Dr. Peter Venkman
    O.C.C. Maniac!!!
    Reputation: Hawg's Avatar
    Nov 2008
    Ask Tone's
    Sent from the communicator that I stole from Captain Kirk
    May 2012
    Seems as if astroglide is the main preference around here!
    Jk. I would like to know the answer as well. I have been debating on using some chain lube I use on my MX bike but its super tacky so I'm not thinkin it's a good idea
    beater
    Feb 2005
    I've gone back and forth between thin lubes like White Lightning and thicker ones like Dumond Tech. I've settled on the latter, applied lightly and to each link junction, rather than just squirted on a moving chain, and then wiped as clean as I can get it. Works well for me.
    - Dr. Peter Venkman
    B.Ike
    Mar 2011
    O.k. I want to change my answer. The best is milk induced flem (not the green stuff)
    Thread Killer
    Reputation: bucksaw87's Avatar
    Phil Wood Grease.
    I use that sh!t on everything.
    Dog Spit.
    '96 San Andreas
    '12 Santa Cruz Nickel LT
    '08 KTM 530
    '12 Toyota FJ TT
    '05 MiniCooper S
    '95 Honda HB Si
    '71 Dino 246 GT
    Quote Originally Posted by bucksaw87 View Post
    Phil Wood Grease.
    That might cause blistering!
    '96 San Andreas
    '08 KTM 530
    '12 Toyota FJ TT
    '05 MiniCooper S
    '95 Honda HB Si
    '71 Dino 246 GT
    grease for bearings: I use the stuff chainsaw dealers sell for bar tips and needle bearings. I think the formulation is very similar to the sticky bike lubes, but half the cost.
    Oils: industrial chain lubes. Contains Molybdenum Sulfide. They're all the same.
    Shimano hub oil (grit your teeth and apply personal lube).
    Reputation: markymark's Avatar
    real men don't use lube
    Frog Lube.
    Or Slip2000 EWL 30 if I'm lazy and don't want to remove the chain.
    Jan 2013
    mtb'er
    Reputation: Empty_Beer's Avatar
    I've been using a new lube called "Chain Brew" since Summer... it's been working great in dry and wet conditions. And it smells like root beer
    CHAIN BREW - TERRAIN CONTROL INDUSTRIES
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    WD-40 for sure!!!!!!!
    Wait a minute....
    Gigantic Hawk
    There's a lot of chain talk in here. Are you all saying that you are in to s and m?
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Totally condition and application dependent. When I lived in the NE, I used finishline wet. It's works awesome and lasts for ever. I couldn't understand why people used the wax based lubes like white lightning. Then I moved to the desert. Wet lubes gunk up everything here so now its wax based lube.
    For other applications, water based is the best.
    Rep power- More than Hawg
    Reputation: Tone's's Avatar
    Quote Originally Posted by ambassadorhawg View Post
    Ask Tone's
    Lube for what? for your bike, or for surprise butt sex?
    PARRAMATTA EELS R.L.C Life member- BLUE AND GOLD NEVER FOLDS..
    'Lifes not about winning or losing, lifes about choosing'
    Thread Killer
    Quote Originally Posted by Tone's View Post
    What ever happened to good
    good old KY?
    Reputation: TiGeo's Avatar
    uhuhuhuhuhh...you said lube.
    I ride in mainly dry conditions and use White Lightning..no complaints. Keeps chain v. clean, just doesn't last more than few rides is the only real downside. I have considered trying Dummonde.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2012 Specialized Stumpy EVO 29 HT
Hot Deals
Contests
Latest Mountain Bike Articles
