Results 1 to 54 of 54
    Mar 2014
    Idea! Easy way to clean cassette!!!
    Today I found out an easy way to clean out your cassette without taking it apart. Simply get pipe cleaners and run it in between each section. Hope I helped someone out
    Dec 2010
    Check out Finish Line's Gear Floss, fantastic product for cleaning tight spots anywhere on a bike.
    Mar 2014
    I got this plastic thing meant for that in a thrift store. It looks like an outside BB wrench that has dull teeth and it goes between the cogs. You rotate the cogs and this thing eats and pulls all the grime, weeds and grass out of your gears. On the opposite side it has a brush which works good.
    Thanks for the tip.
    Ride Instigator
    Reputation: Ricko's Avatar
    In the dishwasher when the wife's not around...sparkly like new.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Quote Originally Posted by Ricko View Post
    I own you dude. I can tell your wife whenever you step out of line by not doing trail work or sending advocacy emails. Sorry; it's what I must do.
    I don't rattle.
    Thanks for the tip, I use something similar. I use old toothbrushes and dish brushes.
    Aug 2014
    This may be frowned on by many, but I go to the car wash. Tip the bike upside down and hold the nozzle very close to the cassette. Do same with the chain as it runs through the rear derailleur wheels. Just be very careful not to aim the nozzle at paint you care about or possible entry path to bearings.
    If there is a little time left I might give my car a rinse
    Reputation: Central Scrutinizer's Avatar
    Aug 2005
    I use a wire brush - push it into/against the cassette, then touch the cassette on the pullback to rotate the cassette a bit, and repeat. Quick, easy, and clean enough for me.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Grimmrider View Post
    Seriously!
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Keep rockin' that novel idea and get back to us down the road when the lovely results start to rear their ugly head. Take some pics, too...we like lots of pics.
    Aug 2014
    Honestly, I've been doing this on the same to bikes for...well they are 90 92 models. Maybe i'm just a good aim
    Oct 2000
    That would explain your user name.
    The death of bicycle parts. R.I.P.
    I use old t-shirts and other tattered clothes for most of my bike cleaning needs. I cut them into squares. My clean the cassette I just fold a piece in half and stretch it out and get it into the cassette.. And I just pull and let it freewheel and rotate the cassette a few times and move to the next gear. It works really well and I just throw out the piece of cloth after.. Been doing it this way for 15 years now.. Its simple and makes them shiny. If they're really dirty I squirt some rubbing alcohol on it.
    Sent from my 831C using Tapatalk
    Reputation: Mr Pig's Avatar
    You guys are coming up with easy ways to clean a cassette without talking it off which are actually harder than just taking it off!..
    I think using a t-shirt is pretty easy.. No need to break out the chain whip just to clean some grease and sticks out of it
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Easy way to clean cassette!!!
    Quote Originally Posted by Mr Pig View Post
    But once you take it off you still need to use similar methods to clean the cassette, and it is harder to spin.
    Easier to clean on the wheel.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    But it's a lot quicker because you can slosh it around in solvent without worrying about it getting into your free-wheel or bearings. That's the biggest issue with cleaning it on the bike, removing the oil on the cassette without removing the oil you need.
    Take it off, shoogle it around in a tray of white-spirit using an old paint brush or something to get between the cogs, two-minutes and you're done. No risk of getting solvent in the bearings, splashing filth all over your wheel and tyres, it's just a better and quicker way of doing it.
    I can't say that I've ever used more than a squirt of alcohol on my cassette ever.. If you're soaking it while on the bike you're going it wrong
    Quote Originally Posted by ou2mame View Post
    It depends how dirty it is. If it's really manked up the easiest thing to do it take it off.
    I use dry lube so mine doesn't really gather much.. I guess if I was using some sticky **** I might want to.. But a little simple green on a piece of cloth would work too
    fRIDEday makes me happy!
    Reputation: FullBladdy's Avatar
    For quick cleaning in use a tooth brush and/or a cloth between crevices. For a more thorough clean I will take the cassette off for a good soak then hit it with a brush . I do agree that it is easier and more effective to take the cassette off. One trick to remember is when you remove it use a zip tie or something to keep all the cassette pieces in the same order.
    Mar 2011
    I borrow an ultrasonic bath from bubbleheads at work, throw the whole drive train in there once every 6 months or when it's filthy with a liter of biox and it comes out like new. Otherwise just wipe it down with isoprop and a one of those cassette brushes
    Reputation: J.B. Weld's Avatar
    I think it's faster and easier to clean it with it on the wheel unless it's really disgusting, I use a rag and floss between each cog.
    Reputation: velo99's Avatar
    Apr 2014
    Use a shoe string. It wraps almost all the way aroung the cassette while your spinning. The lube on your chain will transfer to the cassette. I was using way too much lube which attracts dirt. Less is more with most lubes.
    The bike doesn't make you go fast.
    You make the bike go fast.
    Oh yeah, that dry lube like they use in car engines.....oh no, hang on! ;0)
    Brackish
    Reputation: carbuncle's Avatar
    Dec 2005
    Grab shop rag, fold over in half, slide between cogs, rub back and forth, repeat. When rag gets dirty, fold in different place, continue.
    Reputation: Zomby Woof (MCM700)'s Avatar
    I was washing my bike today so I thought I would give that a try. It worked great. I couldn't believe how filthy that pipe cleaner got.
    Dec 2013
    Air compressor and a dollar store dish brush...150 psi thru a 5mm nozzle tip,been doing it for years...I use it on the chain too,removes ALL dirt,sand whatever that works its way in to the small crevices .....
    Reputation: thickfog's Avatar
    Oct 2010
    Quote Originally Posted by billyrayeast View Post
    Hell yeah. Works like magic. Just be careful not to force dirt into bearings etc. Never had an issue in 10 or so years.
    CRAMBA Chairman
    Reputation: OldZaskar's Avatar
    Oct 2007
    ^this^
    While the cassette is soaking, clean the rest of the bike. If you're up for an additional 90 seconds, drop the chain in there too. And, then wait for "Dude, new drive train or just the cassette and chain?"
    Mountain bikers who don't road ride are usually slow.
    Roadies who don't mountain bike are usually d***s.
    Dec 1998
    I can not remember the last time I have used any solvent, other than just a bit on the rag, to clean a cassette or chain, and I only use wet lube. May have been 20 years ago.
    mtbtires.com
    Quote Originally Posted by OldZaskar View Post
    Once the chain gets really full of crud this is how I clean it. Wash in solvent, rinse in water with a little detergent and dry in the oven! I then oil it on the bike but I think I'm going to try soaking it in a thicker oil then wiping off the excess.
    Reputation: sgtjim57's Avatar
    Pipe cleaners
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Reputation: AngryElf's Avatar
    Feb 2014
    I used to soak my cassette and chain in solvent, but then I had all this dirty solvent around in bottles. Does anyone out there filter and re-use their solvent? Does anyone out there have a parts washer set up at home?
    I just use simple green for that stuff.. Its cheap enough to dilute and dump
    Redcoat
    Reputation: Brockwan's Avatar
    Aug 2013
    taking it off really is the easiest way and most thorough way. 5 minute job if that. No need for shortcuts if at home/in the shop.
    Redcoat
    Aug 2013
    and what oldzaskar and Mr. P said.
    Feb 2014
    I'm not sure if this is true, but it may be a good percentage of riders don't have a chain whip in their tool box. I agree it is a 5 minute job if you have one.
    Redcoat
    Aug 2013
    Quote Originally Posted by AngryElf View Post
    Yeah true that, for the sake of keeping your cassette in good nick twenty bucks ain't much and IMO should be one of the first tools you buy.
    Well, that's a different discussion but considering that just about every bike tool kit comes with one, even the cheapies, it's a tool every cyclist should have.
    Moderator Moderator
    Reputation: Harryman's Avatar
    I use the hems from old Tshirts as floss. Tear them off and and they're just the right width .
    I just use an old chain and vice grips.. Never bought a whip changed many cassettes lol
    Mr. Buck E. Fikes
    I didn't own a chain whip or cassette tool till 3 days ago. Got by with a neighbor's tools. He bought an old, old kit from an old timer and they've all been passed around our 'hood like a dirty whore. Got to a point when I needed it, I had to ask 3 different neighbors for it since a couple of them are bad about returning the sh*t they borrow. So much for spontaneous bike projects that relate to the cassette so I tripped up to Art's Cyclery the other day and invested in a Park SR-11 whip and the FR-5G tool. Together they were about $30. I also have a solvent tank. My cassette is now gleaming!
    Reputation: Tripower's Avatar
    Jan 2011
    All you really need is an old chain and a pair of visegrips.
    Quote Originally Posted by Tripower View Post
    All you really need is an old chain and a pair of visegrips,
    Yip, anything will do. You could nail a bit of old chain to a piece of wood too. Heck of a lot easier than getting the old screw-on free-wheels off! Man, they could be a nightmare. A few months ago I had a real battle with one, it was solid and would not budge. In the end I crushed the gears in a vice until they broke off then crushed the free-wheel body until I could get a bite on the inner spindle with the vice. Yeah, free-hubs are pretty good.
    I use a single drop of ATF on each chain pivot after the thick lube wears off a new chain. After a little soak time I wipe of the excess. I use socks, cut lengthwise to spin the hub to clean the cassette. Rain, dust, or mud can cause me to up my maintenance schedule occasionally, but I only clean and lube a few times during the life of the drive train. I don't own enough solvent to even start to soak a cassette, and I don't want to own it or use it. Chain whip, or not, I only remove my cassettes when I am replacing them or the stuff they attach to.
    I must be old, cheap, and grumpy. Socks are free. My $6 quart of synthetic ATF has lasted 6 years and its still heavy. Parts washers? Power washers? Solvent? Pipe cleaners? Soaking time? How much to come to my place while I'm at work and do all this fancy stuff to my bike?
    Quote Originally Posted by adaycj View Post
    White spirit works fine. Very cheap. You don't need to immerse the cassette, just some white spirit in an old paint roller tray and brush the gears with an old paint brush. It literally only takes a few seconds.
    Next time I clean my cassette I'll take a video.. It will take me under 5 minutes, no disassembly required lol
    No point. Even considering that logical means you loose! ;0)
    But why? So it will be cleaner? I already get multiple years out of a cassette anyway.
    Maybe beer will work
    But why? So it will be cleaner? I already get multiple years out of a cassette anyway. Maybe beer will work
    Why is your problem. You don't need to clean your cassette at all. I'm just describing an effective way of doing it, should you want to.
    Cleaner than what? If you wanted to get it spotless using your saliva and a toothbrush I guess you probably could. I'm just describing an effective way of doing it, should you want to.
    Maybe beer will work. Let us know how you get on with that. I'm just describing an effective way of doing it that doesn't use beer, because I'm not an idiot!
    There is more than one effective way to get the job done. I had the opportunity to practice on several thousand bikes over the course of a few decades and for a couple of those years I went the route of removing parts and dunking them in the solvent tank or ultrasonic. Eventually I came back around to the conclusion that leaving parts on the bike for cleaning (including cassette) was generally faster, easier, and produced similar end results.
    Do you mean "what is my problem?"? My problem is that i clearly stated that I don't own, and I don't want to own solvent to clean a cassette. If you don't want my continuing dialog on the subject, then don't respond directly to my posts.
    No one said you are an idiot. But since you brought it up, I don't understand why it is necessary to buy and use awful chemicals to clean a chain or cassette. Bike don't burn petro chemicals directly so we should soak the parts in it? The OPs idea was spot on, and so is using repurposed cloth stuff. Yes, I can understand taking the path of least resistance and using the nasty stuff if you already own it, or if your boss insists, or your shop already has an aqueous washer. But I'm not buying it specifically for the purpose, no matter how cheap.
    But I already own Beer ...
    Bicyclochondriac.
    I'm supposed to clean the cassette?
  1. Best way to degrease and clean rear cassette/drivetrain
    By bikeman1 in forum Beginner's Corner
    Last Post: 04-07-2014, 11:12 PM
  2. easy way to clean a cassette?
    By nauc in forum General Discussion
    Last Post: 09-06-2012, 06:46 AM
  3. White Lightning Easy Clean...
    By radials in forum General Discussion
    Last Post: 06-27-2011, 02:26 PM
  4. how do you keep your cassette so clean!?
    By Gilly32 in forum Passion
    Last Post: 06-13-2011, 10:15 AM
  5. White Lightning Easy Clean
    By TheDoc46 in forum General Discussion
    Last Post: 05-24-2011, 07:02 PM
