• 11-06-2012
    shibiwan
    Dropper Seatpost Recommendations?
    (crossposted from the Beginner's forum - figure I'd get recommendations from more experienced riders here)
    I'm looking around for a dropper seatpost and was wondering what recommendations you guys had.
    I'm leaning towards an infinitely adjustable post like the Rock Shox Reverb, Crank Bros Joplin or Kronolog. Not sure about the Specialized Command Post or Fox DOSS with the intermediate "cruising" position - their violent upwards spring motion gives me the heeebee jeebies (i.e. smacking into the family jewels) although I suppose we're supposed to be seated on them during the adjustment.
    Anyway, let me know your experiences and recommendations - it'll help me a ton in my decision.
    -S
  • 11-06-2012
    michael1
    I've used the the crank bros joplin and I currently use the rock shox reverb. I prefer the reverb because it has less play, functions more smoothly since it's hydraulic, has an extra inch of adjustment, and I prefer the black color. Also, the reverb has an adjustment that lets you set the speed with a wide range between fast and slow if that's something that matters to you.
  • 11-07-2012
    birmy
    I also like my reverb. I really like the looks of the Thompson that will be coming out in March?
  • 11-07-2012
    Spinning Lizard
    I have used almost everyone out there, The only one I have found to be durable and long lasting is the Gravity Dropper.
  • 11-07-2012
    High Side
    If you want it to work, Gravity Dropper is the only option. I've been running mine with no boot for a year with no problems.
  • 11-07-2012
    ncfisherman
    Not true.
    Look into Kindshock as well.
  • 11-07-2012
    MrMatson
    Rockshox Reverb is awesome
  • 11-07-2012
    lloyd braun
    I just ordered KS Suspension Lev-3. new technology, tested.
  • 11-07-2012
    ojelijb
    Kronolog is tha only one ive tried but it is awesome so far. Good deal at cambria bike w coupon codes
  • 11-07-2012
    cr500taco
    -S
    Good timing, I was just about to post this same question! :thumbsup: If you get one before I do, post with what you went with and how you like it. I'll do the same.
  • 11-07-2012
    shibiwan
    Based on the feedback I got and reading the AM forums, it looks like the Rock Shox Reverb has an edge. Both Crank Brothers Joplin and Kronolog have quality/design issues that plague some users.
    Some recommended the Specialized Command Post but my issues with it are the fixed drop positions as well as the upward snap motion hitting my crotch at the worst possible time. LOL (check out the videos of the Fox DOSS and Specialized Command Post on youtube)
    I'll definitely post my opinions when/if I get it. I'm out on the bench this week with trail rash and a giant aching bruise on my left hip after taking a nasty spill on Sunday.
    -S
  • 11-07-2012
    cr500taco
    -S
    So far, I've been seeing that the Reverb is the way to go, as well. But it's also one of the more expensive ones with good reasons, it looks like.
  • 11-07-2012
    cr500taco
    I just realized that the Reverb won't work on my bike, because my seatpost is 27.2mm. Reverb is only available in 30.9mm and 31.6mm, which sucks.
  • 11-08-2012
    Repack Rider
    I have a Joplin and a Gravity Dropper. Joplin is released under the saddle, the G/D is remote,
    Joplin is lighter, but the saddle clamp (Bontrager) sucks. It seems to change angle the first time you hit the saddle hard, no matter how much you tighten it.
    The cable routing for the remote release on the G/D is stupid, and I broke the attachment once, but G/D repaired it for $15.
    Using the G/D now because the clamp is bulletproof next to the Joplin.
    I know there have to be better products now, but I've had these for several years and they are pretty pricey, so I'm keeping them.
    Anybody got any advice for the saddle clamp on the Joplin?
  • 11-08-2012
    shibiwan
    Hmm if its anything like my old Bontrager (the single bolt style) you have to tighten it, rock the seat up and down pretty hard (it WILL move a little bit) and tighten it again. Repeat until it doesn't shift when you rock it up/down.
    That is the issue with the single bolt Bontrager clamp design. The bushings have to seat properly before it holds tight. Every time you tighten it, you have to rock it to make the inside bushings seat in properly, tighten again, rock.... tighten... you get the idea.
    -S
    Sent from my DROID4 using Tapatalk 2
  • 11-08-2012
    cr500taco
    Besides the remote cable routing, how do you like the G/D? From what I have found so far, the G/D is the only one that will work on my bike.
  • 11-10-2012
    Structure
    I LIKE the preset heights on my Gravity Dropper. It's one of the best things about the system. I have the 100mm Turbo with two positions. One down an inch and then full bottom. Works perfect for me. Personally, I really like having everything at exactly the same spots every time. It takes away that feeling of "Did I get it just right...maybe need to add a touch of height...or maybe just a tad lower..." But each their own. Obviously, others love their set ups.
  • 11-10-2012
    kapusta
    If you want a truly proven performer over the long haul, get a GD.
  • 11-10-2012
    SpinDirt
    If you don't know the height of your ass at any given moment you may be a redneck. Different settings for height doesn't sound ideal. I would rather have an infinite adjustment to the height of my ass I don't know about you.
  • 11-11-2012
    AIDONN
    I have been looking at the looking at the reverb also it seems pretty expensive though:(
  • 11-11-2012
    kapusta
    I've got the standard GD (it is ~7 years old), and I've used plenty of others on demo / borrowed bikes. I think the infinite adjustment thing is not all that important. I pretty much run it up or down, I never even use the middle position.
    When other posts can claim to consistently last for over 5 years with no issues and little maintenance, I'll consider one if this one ever gives it up. However, the design is so easy to work on, and replacement parts are so reasonably priced, I don't see that being any time soon.
  • 11-11-2012
    SpinDirt
    I have been highly concidering that one as well. It has got nothing but good reviews in the short time it has been out. It may be worth spending a little more. The GD has good reviews and has been out forever. But it's the ugliest of the bunch. To me it looks like a Volkswagen shock absorber. Why would I ruin the look of my bike with that contraption. One thing all the others have going for them is at least they are all aesthetically pleasing to the eye.
  • 11-12-2012
    B-Mac
    Can't disagree with you about the GD's looks LOL. It looks like some kind of bizarre sextoy. Who uses a corrogated rubber boot anymore?? However, I'm just wrapping up my first season on a GD & it's been more or less problem free all season. Major gripe (not counting the looks) is that it's incurably noisy. The seat needs a certain amount of "give" for the magnetic pin to operate correctly, so if you're standing up while going over rough terrain, the seat will inevitably rattle. You can't (should say "I can't") adjust the rattle away. The post also creaks if you don't keep its internals greased. Keep in mind, I'm 6'5" 205 lbs, so lighter riders might not have this problem.
    Despite the problems, the GD provides such a huge benefit that I'm more than willing to live with it. Actually, I love the fargin' thing! Mine has a 2" or 5" drop - the 2" drop is perfect position for everyday DH & rocky/techy sections & the 5" is great for "OH CRAP!" sections (defined as "really, really steep stuff"). I'll usually drop to the 2" position now during any section where I don't have to pedal hard to keep speed. Amazing how much that 2" helps you to keep speed through corners!
    I actually like the set positions vs. an infinitely adjustable post b/c you never have to spend time trying to get the height right. It's either engaged and dropped or its not.
    Glad to see the OP looking at a dropper post. Great addition to absolutely any MTB!
  • 11-12-2012
    shibiwan
    OK... snagged an RS Reverb off ebay last night. Thanks for all the input. Lets see how it goes. :)
    -S
  • 11-12-2012
    billywhiz040480
    I have a CB Joplin 4 and luv it. I added a neoprene skin around the post so to stop crap getting into the body clogging it up coz the seals are not great, but after my little DIY iv not had to take it appart once and its now just over a year old!
  • 11-12-2012
    DIRTJUNKIE
    Despite the problems, the GD provides such a huge benefit that I'm more than willing to live with it. Actually, I love the fargin' thing! Mine has a 2" or 5" drop - the 2" drop is perfect position for everyday DH & rocky/techy sections & the 5" is great for "OH CRAP!" sections (defined as "really, really steep stuff"). I'll usually drop to the 2" position now during any section where I dyon't have to pedal hard to keep speed. Amazing how much that 2" helps you to keep speed through corners!
    Have you ever ran an infinite adjustable one? I have been running a Joplin for 5 years with no problem. But the infinite adjustable within it's range is awesome. And very easy to pick your desired height at any given moment. Mine is the remote model. So a flip of the thumb on the lever gets things rolling. You simply keep your ass against the seat to find the spot height you want. When the height is found you let go with your thumb and it locks in that position. It is "extremely" simple and quick to do. I personally would never choose one of these dropper posts that didn't have that infinite adjustable within it's range feature.
  • 11-15-2012
    kapusta
    In response to the clueless newb that neg repped this post with the comment that this was only an opinion (or, as he put it "opintion"):
    This is not "just an opinion". In case you only started paying attention to these things when you started riding last year, the GD has been around for over 8 years, longer than any other adjustable post out there (ever wondered why they are called "dropper" posts?). it was a couple years until any other company started making them, and a couple more until other reliable ones came out.
    So GD has over 8 years of a pretty solid track record. care to give an example of another post that has a reliable record for more than half that amount of time?
    I'm not saying there are not other reliable ones that in a few years will have the same track record. They have just not been out long enough. I'm reading good things about the reliability of a few other posts, but none of them have been out for more than a few years.
    Also not saying it is the best one to use, because it lacks some features that some folks care about. And some folks find it ugly (and care).
  • 11-15-2012
    net wurker
    Te hot set-up is a command post with a joplin remote.
  • 11-15-2012
    cr500taco
    I am going to get the Gravity Dropper Turbo. Going with the 350mm, 4" drop multiposition. Just not sure if to go with the 1" down or 2" down. My seat position is always either all the way up or all the way down and nothing in between, just because I've never really wanted to deal with it.
    Do you guys prefer the 1" down or 2" down and when do you use that position? I guess, I should start experimenting with the 1" lower or 2" lower to see which I prefer.
  • 11-15-2012
    ncfisherman
    I'd go 2"...found 1" to be almost useless when I had my GD.
  • 11-15-2012
    cr500taco
    That's what I'm thinking. Seems like 1" is not much and might be pointless. 2" will be half way down with a 4" drop, seems to make more sense, now that I think about it.
  • 11-19-2012
    VABikerII
    $199 Reverbs at Art's Cyclery
    Art's Cyclery has 2012 Reverbs on sale for $199, free shipping right now. pretty sweet deal
  • 11-19-2012
    Ponderosa
    -S
    I bought a bike back in May with a Joplin 4. It probably was leaking when I bought the bike because it lost oil and compression on the first ride. I called Crankbrothers and spent $15 for the re-build kit. This did not fix the problem. And there are several issues that you can have with this post that require it to be sent back to the shop. I then sprang for the $300 Kronolog and it worked great for about one month. Then it started to "creep" down from full extension about 1 1/2 " during my ride. And now the air seal is blown and it won't hold pressure. According to some forums there have been similar problems with this post with other riders. Check out some of the reviews on-line. Bottom line -- dropper seat posts are awesome when they work but for me (I'm not an extreme rider) I'm going back to a regular post-in-a-seat-tube-with-a-clamp!
  • 11-19-2012
    rogerfromco
    I've been using an old Maverick Speedball for 6 or 7 years and it's been bomb proof. Not even sure of they are made anymore, but sometimes simpler is better.
  • 11-19-2012
    natrat
    i got one of those way back just because i liked the name, it ended up being awesome only requiring service once after 5 years of use. With my new sworks stumpy i got a joplin 4,basically speedball v2, and it is even better, more refined, less jigly . I could not use one of these without the infinite adjustment as i like full extension for climbing and just below that for technical stuff.
  • 11-21-2012
    Captain_America1976
    There are several options for the 27.2 crowd. I use a X-Fusion HiLo on a 27.2 frame. There is also Gravity Dropper and Kind Shock. I have been on the HiLo for about 6 months, so far I love it.
  • 11-21-2012
    the-one1
    So you had 2 of the least reliable models and now you've shun dropper posts?
  • 11-21-2012
    DIRTJUNKIE
    No the Maverick Speedball isn't made anymore, at least not under that name anyway. Crank Brothers bought the design back in 2008'. They reworked what Maverick designed and improved it. They named it the Joplin. I bought the first edition of the Joplin in 08' and have been running it problem free ever since. I have never had it or needed it to be serviced or rebuilt. I know many have had issues with the Joplin but all I can say is mine has been bomb proof for 5 years now.
  • 11-21-2012
    rogerfromco
    Yep, my Speedball has never been serviced either. Reading about all the problems with dropper posts lately, I feel very lucky. :thumbsup:
  • 11-21-2012
    006_007
    that is not a bad price at all.....if I could find them on the site lol :thumbsup:
    EDIT - nevermind, found it. that $199 is for the 4" post.
  • 11-21-2012
    cr500taco
    I don't know about several, maybe a few. The Gravity Dropper turbo will work, just need to come up with some money.
  • 12-18-2012
    venture
    Over the past few years I have had a few droppers - love the ability to drop the seat, hate the reliability issues...
    I had a Joplin for a few years - this was my first taste and it was awesome. But it's Crank Brother, so you know it will have issues. First issues was with the clamp mechanism failed - Crank Brothers sent replacement parts. Then the seat post exploded on a ride - oil burst out of the junction between the lower and upper all over me and the trail.
    After the Joplin I took a break from dropper posts for a while due to the reliability issues...
    A couple years ago I got a Rock Shocks Reverb - it hasn't been all roses.
    First issue is the remote lever (plunger in this case) - it has a tendency to break off in a crash (particularly in a OTB situation)... I have had this happen twice in the first year. I moved the remote under the bars when I went to 1x9.
    Second issue, in the last few months I have had to bleed it 4 times. And when you don't have it bleed right, that seat ain't movin. I can't find a leak anywhere, not sure what is happening here - broke down a took it to a shop to bleed. Which emphasizes the issue with hydraulic seatposts - when the hydro system has problems on the trail - you can't adjust the seat up or down - you are just screwed.
    So now I am back to a mechanical system - the second version of the Command Post has gotten a lot of good reviews, so I am giving that a shot. I just installed it, so I'll see how it goes. But in the garage and driveway was impressive. The quick return of the saddle to height isn't that big a deal - there isn't much force behind it.
    As for infinite vs fixed position posts... I don't think it's a big deal - I think you get use to whatever you have. I generally use the dropper in 2 ways - a little down for trails, and way down for steep downhills. So now it will be 2 fixed positions - rather than an infinite choice of 2 positions.
  • 12-18-2012
    b-kul
    a reverb may fight you a bit but imo is the nicest feeling dropper out there. super easy to bled so it isnt a draw back.
