• 08-08-2012
    Guerdonian
    Dropper Posts need a re-direction.
    Here is my rant, I thought it would be a good conversation.
    Why are dropper posts so heavy, complicated and expensive? I was really hoping that after a few generations the simplicity and reliability would increase, but they are continuing to trend toward more complex and expensive. I really don't understand why they have to be so dang fancy or so freaking expensive.
    I don't see why two telescoping tubes, with a lightweight mechanical spring, and a wiper seal, with a locking up and a down position cant be done. I don't want the hydraulic lever, or the air spring, or the infinite positioning, or any of the frills.
    I just want a post to go up and down about 3" reliably, and not be a brick with a wiggly head!
    I don't get it, please educate me why?
  • 08-08-2012
    Uncle Six Pack
    Such simplicity would clearly cost 3 times more than whatever is on the market now. ;)
  • 08-08-2012
    skullcap
    ...I don't get it, please educate me why?
    Because what you are suggesting makes far too much sense. It will never happen.
  • 08-08-2012
    Joules
    sketch out a design and have someone fab one for you. Find someone who knows solidworks to make you a pretty graphic, and take it to kickstarter - if you could sell a reliable dropper post for $100, people would be lining up, I suspect.
    in this day, if you really do have a better or cheaper idea, I don't see what's stopping you from making it happen and making some money in the process.
    It could be you are onto something. It could also be that the problem is more complicated than you realize.
  • 08-08-2012
    Strafer.2
    Wait til Apple claims the patent on dropper post.
  • 08-08-2012
    Guerdonian
    I am a mechanical engineer, I work in Solidworks 90% of my day. I guess I am too busy with my current job, hobbies, and general life to do it. That or i am just a lazy ass.
    I also think if someone like me; a small fry, designed it and got it rolling, then tried to patent it, it would be eventually copied somehow, or muscled out of my playing field by one of the big contenders. Best case would be if I made it and sold off the design.
    My main question is why the heck haven't they done this for me already?
  • 08-08-2012
    TwoHeadsBrewing
    I think the price has less to do with the materials or complexity of a dropper post, and more about the type of rider that uses one. It's only just now started to come stock on some bikes, but those are still in the $2000+ range. If you're spending 2K on a bike, chances are you have $200-500 to spend on a post.
    The price of a product isn't the cost of production plus a "fair" markup. The price of a product is what the market can bear and still provide a sustainable return. I think we'll see droppers continue to drop in price until you can easily find one for $100 but it may take a couple more years to catch on.
  • 08-08-2012
    Guerdonian
    Thats just it though, they haven't dropped in price. They used to be in the $250-$300 now they are #350 to $400+ range retail. This is now something that is almost the same price as a Fox Float RP23, which has substantially more complicated internals, damping, rebound, pro-pedal, etc....
  • 08-08-2012
    Structure
    What you are describing sounds a lot like a Gravity Dropper. Maybe they're over-charging and over-weight, but I suspect that they've refined the two tubes and and spring with pin idea pretty far. They could make it titanium but then the price skyrockets. They could maybe have it made in Asia for cheaper? but then perhaps take a hit to quality?
    I like my GD turbo just fine. *shrug*
  • 08-08-2012
    Guerdonian
    I do agree with you, and i have not tried a gravity dropper post. I have heard that they function great, they are the cheapest post on the market, and the are durable. The two things that don't work are looks, and weight. But they are using a simple mechanism. Why aren't more companies working on improving this design rather than going the other direction?
  • 08-08-2012
    HrznRider
    I'm an owner of an older Joplin 3 and currently also a 2012 spesh command post. The Joplin was bought 2nd hand from a friend and surprisingly has almost problem free. The inifinite adjustment has pros and cons. The 2012 command post has only been through one ride so far and still needs a bit of tweaking but it feels super solid and well made. I'll give a more thorough comparison (old infinite adjustment hydraulic driven with current model 3 position mechanically driven model) after a few more rides. The command post cost me 250 which I think is acceptable but should still be down in the 150.00 area. The joplin was bought used and dirt cheap.
    Bottom line, I agree... dropper post should be cheaper but the business allows for higher prices right now.
  • 08-08-2012
    Wombat
    Here you go, a Gravity Dropper knock off for $100. Let me know how it holds up as I'm interesting in buying one:
    New TMARS Adjustable Seatpost Seat Post , 27.2X400mm | eBay
    The Forca Sports version is a little different, and a bit more expensive, and you can buy a rubber boot for it:
    Bike24 - Forca Sports SP350 Vario Seat Post 27,2mm
    Tim
  • 08-08-2012
    Spinning Lizard
    Gravity Dropper posts already fit exactly what you want. I have had mine for 6 and 4 years. The 4 year old one still works great and I have never done any maintenance to it. The 6 year old one was rebuilt 1 time for $20. Seems like a great value to me.
  • 08-08-2012
    mimi1885
    While I agree that the price and weight can be improved but they are several brands and models available now for every one who wants it. Light weight option,up to 9" travel, fixed /infinite travel, integrated remote, mech/ hydro, more affordable models, etc. Choice is good there's something for everyone.
    I had a cheapo ks: 4" infinite adj, lever operated, suspension post for only $40 from pricepoint. Sure it weights 2.lbs+ and the suspension part is annoying but it's cheap.
    In a perfect scenario an adj post should be super reliable, up to 6" travel, ergonomic remote, weight 250g and cost about a hundred bucks, oh and made in the US of A :)
    Sent from my iPhone 4s using Tapatalk
  • 12-16-2012
    702Biff
    So... Has anyone tried one of those "2013 New TMARS Adjustable Seatpost " off ebay. I assume its junk but found a youtube showing function. Just checkin...
  • 12-16-2012
    kapusta
    Sounds to me like you are describing the Gravity Dropper post. It's the oldest one on the market, been around for something like 8 years. Very reliable, too.
    As far as the weight, I don't think they are that heavy for what they are. An extra half a pound is not unreasonable when you consider a mechanical spring, extra post (one sliding inside the other), switching mechanism, lever, and cables. How much weight does a suspended fork add over a rigid?
    At $220 I do not think they are overly expensive. That the price of a pretty low end fork. Heck there are hydraulic brakes that cost that much per wheel.
    It is ridiculous for people to expect a dropper post to weigh or cost close the same to a regular post. It's an entirely additional component. It would be like expecting the same of a suspended fork or frame over rigid.
  • 12-16-2012
    J.B. Weld
  • 12-16-2012
    MendonCycleSmith
    Originally Posted by J.B. Weld View Post
    Thank you. I come here just to post that.
    What was, is often the best. What has become, is most often in the best interest of the manufacturer. Correcting the imbalance between is left up to the marketing team.....
    About 3 ounces, simple, zero maintenance, no extraneous parts, fluid, air, saddle never wiggles, and it worked flawlessly.
    See? Ask the marketing folks why you need the newer option. ;)
  • 12-16-2012
    Eazy_E
    I use a Kind Shock i950r. It's not the most high speed/low drag thing out there, but it only cost about $250 and it's been about as reliable as a hammer. Worst thing that happens is sometimes the cable is a little sticky or the cable pops out of the actuator lever. The actual mechanism of raising or lowering it is reliable. And I'm raising or lowering it almost constantly.
    Like the other guys said, if OP thinks that a dropper should be $100 with three parts, he should design one and capitalize on that great idea.
  • 12-16-2012
    kapusta
    So, I assume this means you have one that you still use?
    It did NOT work flawlessly, and there was no remote (without which I really don't see the point of a dropper post). That is why it flopped.
  • 12-16-2012
    kapusta
    I donít get why suspension forks are so heavy, complicated and expensive:madman: It's just one set of tubes telescoping into another set with a spring and some fluid going through holes. What gives?
    My rigid fork was $80, weighs 2 lbs, and is incredibly stiff.
    All Iím asking for here is a suspension fork with good damping that is as light, cheap, and stiff as my rigid. Is this really that hard?
  • 12-16-2012
    zebrahum
    It's cute the way you pretend you don't understand why this mythical dropper does't exist already. No mechanical engineer could possibly mistake an incredibly complex device intended for one of the most nit-picky groups of consumers as somewhere where the bicycle industry is sandbagging development.
    Here's what you should do:
    Write down what don't you like about your post.
    Fix it.
    Sell it.
    Failing that:
    Stop complaining about something you refuse to change yourself.
    If there was a better solution it would be out there. If the better solution was out there everyone would be doing it. If you disagree, get to work and prove us wrong. Personally, I'm anticipating the Thomson dropper. If they execute to the level they normally do it's going to be the one to own.
  • 12-16-2012
    J.B. Weld
    I've played with a bunch of them and as long as the seat post fit was good and the frame was smooth and free of burrs my experience was that they worked just fine.
    My understanding is that at least part of the reason for a dropper is the ability to adjust seat height without dismounting. Yes I understand that a remote makes a big difference but the OP was asking about a lighter, cheaper, and simpler solution and I think that for some folks this old school technology might still be a viable alternative.
    I don't use one, but only because I don't feel the need to fiddle with my seat height during a ride, or maybe I just need to get off these woosey trails I've been riding. ;) To each his/her own though and I wholly support anyone who feels that it improves their ride experience.
  • 12-16-2012
    Guerdonian
    Fix it.
    Sell it.
    Failing that:
    Little aggressive dontcha think?
    as any GOOD engineer knows its easy to make something complicated and expensive, its much more difficult to make something simple, and cheap. The old school design shown above is something that looks simple and reliable. The Thomson post you mention will be upwards of $400. As I stated above, I do not understand why this "up and down" mechanism is more expensive than suspension shocks with very complex valving, lockout, and air springs. I don't think they are sandbagging, I think they are headed down a path that is the wrong direction. Why do they need to be infinity adjustable, hydraulically actuated, air sprung, etc.....Give me an up, and a down position. Am I alone in wanting just up and down?
    Its also easy to tell someone "if your so smart just do it and STFU" In this instance you seem to be inferring that I should invest into my own company to produce a product to compete in a very aggressive market, against large companies. Unfortunately at the moment I don't have the determination to do so or the money to invest. Sure I am making excuses, but i was hoping this would be a friendly discussion of why droppers are so pricey and complicated.
  • 12-16-2012
    Guerdonian
    I can see this point as well. Though I think the suspension is a little more justified as it directly inputs the ride feel of the bike, and due to different rider weights, trail conditions, and preferences, I can see the justification of the adjustments. A dropper post just needs to go up and down, and stay up when someone is sitting on it.
  • 12-16-2012
    kapusta
    Unfortunately, this is often not the case. At least not with many of the bikes/pots I've owned.
    Seriously, if these work so darned well, they would still be for sale.
  • 12-16-2012
    dwyooaj
    RASE | Black Mamba Rapid Adjust Seatpost...The Ultimate Adjustable Bike Seat Post
    not light, but simple reliable design that works well; with up to 8" of drop (nice!) the new model with better seat clamp look like it will be available soon. Not cheap...but not the priciest one either.
  • 12-16-2012
    Guerdonian
    The Gravity dropper will probably be my replacment for the reasons you mentioned. I also think that $150 to $200 is reasonable, but as i mentioned above the trend in these components is moving well past the $350+ average. This I do not understand, especially when you can get an RP23 for $350ish that has all of this going on inside: (seems like A substantially more complicated mechanism)
    or a DHX
    or DHX Air
    Compared to:
  • 12-16-2012
    MendonCycleSmith
    Yep, works great. And I am the sort of guy that eschews a remote lockout switch for their fork too, must just be how I'm wired. :D
  • 12-16-2012
    kapusta
    I hear you on that one:thumbsup:
    You are definitely not going to see me defend $400+ posts that are not even proven reliable.
  • 12-16-2012
    kapusta
    Nice, that must make at least three of you that find it worth owning.
  • 12-16-2012
    shibiwan
    Agreed... they are overpriced IMO. Then again I picked an RS Reverb on special form Art's Cyclery at $199, which was way more reasonable.
    -S
  • 12-16-2012
    Zuarte
    I have a Gravity Dropper, and I got it because of its supposed simplicity, reliability, and GD's service reputation. It really is more or less what you first described, which is a telescopic post, two key-ways for alignment, a strong spring, and two divots (or three as an option) in the telescopic shaft for the position switch. But it is heavy, and my guess is they've worked in a large margin of safety for worst case loads. Perhaps their design requirement wasn't only for the load of the rider (which can easily be a 200+ cyclical load), but instead for impact loads when the bike goes tumbling down a hill.
    You can remove the boot of the GD for more elegance. It's spring operated, so no air will leak from a scratched shaft.
  • 12-16-2012
    kapusta
    I hear you. When I bought mine in 2005, I could not believe that such an item could cost over $250:eek: It's just that I had wanted something like this since I started riding in the late 90's, and this was what it cost.
    Thing it, it's really easy to think something should be sold for cheaper. It's a whole 'nuther thing to develop and produce it. Especially something that is going to be sold in relatively small quantities.
    Whether or not the product is actually worth it is up to the individual.
    I am guessing as droppers get more and more common, the prices will come down as manufactures see lower production costs due to volume. Right now the prices seem to be going up because they keep trying to make them slicker, with infinite adjust, which is a little trickier.
    The Gravity Dropper itself has actually gotten cheaper since it first came out, and that's not even adjusting for inflation.
  • 12-16-2012
    kapusta
    Good point. The original version (which I got in 2005) had a different inner shaft that they needed to beef up in subsequent years.
  • 12-16-2012
    J.B. Weld
    Get back to me in 20 years and we'll see who is still using todays drop post technology.
  • 12-16-2012
    Eazy_E
    You know why a dropper post is over $250? They know you'll pay it.
    Look at anything that's cycling specific, complete hose job, guaranteed. Why does a cycling jersey cost $80? I use breathable polyester shirts from Walmart or Target or under $12. Same for socks. I wear some merino wool hiking socks I got on sale at REI for $7. Why do cycling socks cost $20 a pair? What goes into a pair of baggy shorts that warrants $50 to $100?
    Bicycling is a hose job and they charge rape prices because they know you'll line up to pay it.
  • 12-16-2012
    kapusta
    Point? :confused:
  • 12-16-2012
    J.B. Weld
    Point? :confused:
    There is a general consensus that the posts available are top notch and work really well. So when you say "Seriously, if these (Hite Rite) worked so darned well, they would still be for sale" I am asking if you think today's top of the line Gravity Dropper will still be for sale in 2032?
    Of course it won't, and that has no bearing on whether or not it worked well. I have no Idea where technology is headed, and it may well come full circle. Wouldn't be the first time. That is my point. ;)
    Now, back to the problem of finding a simpler, lighter drop post!
  • 12-16-2012
    kapusta
    The difference is that the Rite-Hite flopped. Not because a better one came along (the GD did not come out until many years later), but strictly on it's own merits and how those lined up with what people were willing to pay for.
    I was responding to the claim that the HR is/was a cheap, light alternative that does the same thing as these new, expensive, heavy posts. It doesn't. I'm not saying the HR was a bad product, (it IS light and cheap), but it is NOT in the same league in terms of functionality.
    I remember when the GD first came out. It was panned by everyone (who had not tried one) as ridiculous. But as more people tried it, it caught on. Not from hype (this was a tiny company, not some industry behemoth) but because it worked.
  • 12-16-2012
    Zuarte
    Sad to say, but I think putting large mark ups on a product gives the illusion of legitimacy from a marketing perspective. Fox's dropper post is a huge price step above the others in the same way that their forks are a huge price up from others. Whether or not their forks have earned such a price tag is a different discussion, but they have cemented themselves a certain exclusivity in the industry. To sell their new dropper post at anything less than a high price would make it look like they didn't believe in this product. The thing might only cost them $100 to make for all we know, but they have their trademark's reputation to uphold.
  • 12-16-2012
    b-kul
    simple as two telescopic posts? no, arguably the nicest feeling post on the market (reverb) has pretty complex internals. overpriced? probably, but in this game you pay to play.
  • 12-16-2012
    mimi1885
    I think this is spot on:thumbsup:
    My first GD is still on one of my bike spread the $$$ I paid over its service (including overhaul charge), came out to less than 50cents per ride not per day. Similar cost per ride is approaching my other posts. We are all have our way of approaching products purchase. This is my approach:thumbsup:
    I hear people b!tchin' all the time about the price of mountain bikes while they are gulping $30+ a gallon of redbull, chase it down with $7/gallon of bottle water;)
    I like what b-kul said too
    Originally Posted by b-kul View Post
    ... arguably the nicest feeling post on the market (reverb) has pretty complex internals. overpriced? probably, but in this game you pay to play.
  • 12-16-2012
    womble
    If you do that and then ride in wet weather, you end up with grit inside the tubes which interfere with operation. (I've tried, and then had to regrease it).
    Anyway, another +1 on the GD option. Fugly but super reliable and not crazy-expensive. Mine's been working well for ~5-6 years. I simply regrease it once every two years.
  • 12-16-2012
    scrublover
    I'll add to the Gravity Dropper love pile. For what you request, it's the best one going. Sure, it may not be the most refined looking product, but it just plain works.
    You going to ride your bike, or just have it on display as a garage queen?
    You want it lighter? Be prepared to pay more, or have it break more. You want it lighter with the current (or better) durability? Be prepared to pay even more.
    You want all that and cheaper? Be prepared to have its production move overseas, or quality and CS suffer.
    I have two GD posts (one remote, one non-remote) and two Reverbs. The GD wins in the long term durability department. Even though the hose on the Reverb moves with actualtion, I love its remote and infinite adjustment - enough so that those tow bikes are sticking with Reverbs even though they could run a GD instead.
    I rode many years with my non-remote GD posts, and love them - moving to remote setups is even better. They get used a lot.
  • 12-16-2012
    Zuarte
    Thanks for pointing that out. I've never ridden with it in wet conditions before. I always have the boot on, because I always choose decreased maintenance over looks.
  • 12-16-2012
    1niceride
    Here is a redirect..I keep looking at the thudbuster and how the seat travel is controlled with links. Reconfigure those links with a floating spring or air pushrod/locking mech. The links control rotational and axial loads much better than a spindly shaft. Or maybe some sorta plate inside the links with stops or holes and a lock mech. Just throwing some ideas around..
  • 12-17-2012
    kapusta
    Interesting. :thumbsup:
    The issue I see is that the seat moves back as it goes down, so unless it drops really far, it would be in the way as you try to get behind the saddle.
    Of course, the main limit of how far a saddle drops with the current models is the length of exposed seat post, and the design you are describing would not have that limitation.
  • 12-17-2012
    b-kul
    *and just to add to my original post, i dont think getting the post to move up and down is the issue, suspension companies have that pretty well sorted. its getting the post to lock in place and stay there. nearly every brand has a diffeent design for this, once that gets sorted i think we will start to see some nice droppers.
  • 12-17-2012
    1niceride
    Yea, the links could be reconfigured to move the seat slightly forward if one wanted to design it that way.
  • 12-17-2012
    shiggy
    I still use Hite-Rites a couple of bikes, and use them on the fly. I also have the IRD remote seat clamp for use with the Hite-Rite. Worked great on a frame designed for use with the H-R (precise seatpost fit, smooth seat tube, braze-on seat collar, H-R braze on), but the remote clamp does not have enough throw for current frames with separate collars.
    I do have a dropper post and its only advantage is the remote.
    I think H-Rs stopped selling because riders stopped changing their saddle height during rides. This was the same time QR seat collars disappeared.
  • 12-17-2012
    shiggy
    ...and not bend or break, not wiggle side to side (much), move smoothly...
    There are rigid posts that bend and fail. Given the diameter limitations of seat tubes you have to beef up the dropper shafts to reduce failure. That adds weight and complexity.
    Brings me back to the elegance of the Hite-Rite.
  • 12-17-2012
    kapusta
    I was trying to think who else would use one, I can't believe I did not think of you, Shiggy:D
    If someone makes a Hite-Rite with a remote than can reliably work as advertized, and give at least 3" drop. and sell it for even close to what the original went for (adjusted for inflation), they will make a killing.
    The market is wide open to this right now, and plenty of incentive to try. If it does not happen, I believe it is because it can't be done reliably.
    I do think that the remote is the key to a dropper post's functionality, much as the bar mounted shifter for a derailleur.
  • 12-18-2012
    owensjs
    Just like anything...if you want lighter weight, it comes at a higher cost. When it comes down to it, I don't think dropper posts are all that heavy. I certainly don't regret adding the weight of a command post to my bike. It would be nice to see more options available in different price points, but that will come in time, I'm sure.
  • 12-18-2012
    Snfoilhat
    Economics
    Gravity Dropper Turbo LP
    Lower profile unit for clean cable routing
    Upgraded to 2024 aluminum
    900% increase in strength
    New flexible housing for better cable routing
    Same reliable mechanical design
    45 grams lighter than the GravityDropper Classic
    Unit now bolted to post instead of bonded
    $325
    :lol: :lol: :lol:
    You wanted simple, here's a company that is listening to you.
    Now with higher quality materials (we could have sourced all along!)
    MSRP $14 less than a Fox DOSS! Weeeeee
    I believe when you take into account all the overhead, selling one $300 post is better than selling two $150 posts. So for a company to swoop in and take over market share with a low cost, high volume approach, when the major players get to charge $300+ no matter what their product is made from or how well it works*. What cheap post is going to come to market and outsell Reverb or Lev or GD by 3X? I don't anticipate a lot of investment happening on that front.
    edit: *all the big names seem to meet (and together, establish) a sort of threshold quality. I mean more that no company has really nailed it yet
  • 04-23-2014
    ianyuk
    i'm up for trying hite rite, where can i get my mits on one?
