Results 1 to 5 of 5
    nimble biker
    Reputation: Picard's Avatar
    Apr 2005
    does body geometry affect by flat vs. low rise handle bar?
    Does the flat bar help body in climb?
    Is there difference between the two handle bars?
    YES there's a difference, and NO, there is no correct answer to your question ... It is a fit you properly and personal preference thing.
    nimble biker
    Apr 2005
    does anyone else have comments?
    Reputation: J.B. Weld's Avatar
    It depends on where you want your bars in relation to your saddle. Flat vs. rise is meaningless, some frames may demand a bar with some rise (or stem with rise) while another frame might use a low rise or flat bar to get the same rider in the exact same position.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by Picard View Post
    If you are trying to attain a particular position on the bike, a high stem with flat bar will put you in the same place as a low stem with a rise bar.
    Also see here:
    Riser bar vs. riser stem and flat bar
    The bike should not dictate your position. YOU should determine the layout of your bike.
    -F
    It's never easier - you just go faster.
  1. SRAM Rise 60 freehub body
    By jdigdog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2014, 08:25 PM
  2. Truck Cap - Rise vs Flat
    By norope in forum Cars and Bike Racks
    Last Post: 07-05-2013, 06:37 AM
  3. Geometry questions - how they affect ride quality
    By dansMTB in forum Frame Building
    Last Post: 11-06-2012, 06:33 AM
  4. high rise handle bars angle?
    By drivengsxr1000 in forum All Mountain
    Last Post: 12-09-2011, 11:05 PM
  5. Handle Bar Sweep and Rise discussion
    By Pandora's Box in forum All Mountain
    Last Post: 06-07-2011, 10:03 AM
