Results 1 to 14 of 14
    Do worn rear derailleur pulleys wear out your chain ?
    just recently installed new chain cassette and chain rings, wanted to know if i need to also replace the derailleur pulleys, they're not totally pointy but on their way and probably need replacing. my shiftings fine, no complaints, no noise... Do I even need to replace the pulleys or do they not affect chain wear?
    Fat-tired Roadie Moderator
    Nov 2007
    They're typically a resin material. I wouldn't worry about it. You can run into trouble if the teeth are so worn down that the chain drags across the pulley instead of turning it.
    Self Appointed Judge&Jury
    Oct 2000
    No they don't have to be replaced when you change out front rings and cassette. They just act as a guide for the chain. All the pressure that the chain gets is from the rings and cassette. Don't worry about them unless they are broken which is unlikely.
    Dude, I'm in Illinois. The only place anyone would come from that would say this area is hilly is Kansas.
    Reputation: carverboy's Avatar
    So I should be okay with this one?
    Attached Thumbnails Attached Thumbnails Do worn rear derailleur pulleys wear out your chain ?-photo-3-.jpg
    Oct 2000
    That's looking pretty beat and ready to be changed. It won't hurt your chain to run it. But you have all new rings and cassette you could use a change out of those as well. But if you don't they work fine with zero effect on wear of the chain. Like I said earlier they just act as a guide for the chain. It's up to you but now that it's on your mind you probably should get new ones. Otherwise it will constantly be in your mind like you should have.
    Reputation: Pollution Warrior's Avatar
    That pic looks like pics I've seen of worn pulleys. I'd replace them. Can't cost much.
    Quote Originally Posted by Pollution Warrior View Post
    And you would be wrong if you are looking for a OE part.
    Shimano XTR M970-M972 Derailluer Pulley Set
    The aftermarket alloy pulleys are noisy.
    Dec 2010
    I've had good luck with the blingy alloy pulleys. I was going to suggest them, actually. All you really get is bling-factor, though.
    Jun 2012
    $50 for pulley's, what a rip off.
    Quote Originally Posted by isignay View Post
    Worn jockey wheels will wobble and have side to side play....
    This when bad will cause slow and poor shifting.....
    This in turn will wear a chain out, that will then wear out the cassette and rings.
    I have run will over 20,000km on a set of jockey pulleys without problems.
    Reputation: Wombat's Avatar
    After replacing the drive train in the past I've then had to get new jockey wheels to get it to run properly. The ones I replaced looked like the ones you show.
    Tim
    Ride Instigator
    Reputation: Ricko's Avatar
    Quote Originally Posted by Learux View Post
    ....Exactly. I'd pop for a few more bucks and just pick up a new rear derailleur.
    Oct 2000
    Quote Originally Posted by sasquatch rides a SS View Post
    Squatch, Tell me again how often you are replacing these jockey wheels while riding a single speed.
    Bike shops usually have bent derailleurs laying around. If you're lucky, they'll let you pull some pulleys off one of those for free or little cost. My sram x.9 10sp has two 105 road derailleur pulleys on it as the stupid sram ones have cutouts that allowed them to easily break. Works great now.
