Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 78
  1. #26
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    Quote Originally Posted by claydough001
    According to my April 2011 issue of MBA "Mountain Bike Action Magazine" they do.
    Not new, they've run the same story in the past. Bunk then as it is now.
    Say you bought a bike in April of 2011 then you would need to replace the......
    Seatpost: Al- 2 years
    CF- 1 year
    Adjustable Height- 90 day rebuild
    If I was running the absolute lightest, then maybe I'd worry about fatigue. All of the seatposts I've got are all older than that.
    Derailleur Cables: 6 months
    Replace when shifting starts to suffer.
    Rear Derailleur Loop: 6 months
    See above, or when fraying.
    Saddle: 4 years
    When torn, or for whatever reason no longer comfortable. I might replace some sooner than four years.
    Pivot Bearings- 1 year
    Inspect before replace, and it'll depend on who made the bike. Something like a Turner, probably will get a bit more than that.
    Front Derailleur: 2 years
    Nope. When it starts to act up.
    Chain: 4 months
    When it starts to show wear, buy a chain checker or measure the thing.
    Rear Shock: 1 year
    REALLY?!?! Replace a $300+ part once a year? Inspect, rebuild as necessary, replace when I want.
    Cranks: 2 years
    Same stuff. Inspect. Replace rings first, only replace when it is toast.
    Pedals: 2 years
    Because XTR and Eggbeaters are the same. Replace as necessary, not before. Think I'll replace cleats a few times before the pedals.
    Frame: Al- 4 years
    Ti- 5 years
    Steel- 7 years
    CF- 3 years
    They've just discovered that steel frames can get tired? If the frame is in good shape, why would I replace a Ti/Steel or even CF frame? Aluminum - if it is a lightweight racing frame, there may be some merit to it, maybe.
    Stem: 1 year
    Because these always fail without any indication at 12 months and 1 day.
    Brakes: As soon as pads wear past mf's limit (durrr)
    Bars: Al- 1.5 years
    CF- 1 year
    Inspect, inspect, inspect. If I'm running a 80g bar, yeah, it has a lifespan. If the bar is 300g+, it should last a little longer.
    Grips: As needed
    Headset: 1 year
    This should be news to HS that have warranties that are much longer than that.
    Brake Cables: 6 months
    As needed.
    Fork: 2 years
    Rebuild it first. A newer fork probably will work better, but what about the A-C measurement you can't find anymore. Or that the new fork now weighs a pound more. Not always a good idea.
    Wheels: 2 years
    Where there any ads by wheelbuilders/Easton/DT Swiss prominent in the magazine this month?
    Tires: 6 months
    Again as needed.
    Of course it goes on to say this is an estimate based on you riding 10 hours per week year round and where and how hard you ride but you get the picture. What are your thoughts? What are some of your longest lasting components and how did you maintain them? Since pictures are worth a thousand words can those of you who have exceptionally long lasting components please share them?
    Some parts are wear items - tires, tubes, cables, brake pads and chains. They are expected to be replaced as needed. But their schedule looks to be assuming that I beat upon my bike every ride, and don't maintain it. If we all had to use that schedule - we would have drained our trust funds by now.
    MBA is in the business of advertising. The stories are just longer, and nicer ads. The advertising sales probably account for nearly as much as subscriptions and newstand sales.
    They rant about online sites like this - hmm wonder why? Because there is a diversity of opinion where the reader has to think? Because I won't recommended the latest tested bikes or part to solve your dilemma when fixing the old one will do for a lot less $$?
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
  2. #27
    SS Convert.
    Quote Originally Posted by JmZ
    JmZ
    Yeah, in the March 2011 issue, in the article about choosing the right bike, there were 10 tips. Two of them were:
    "Read our tests" and "Don't read blogs"
    In order words:
    "Buy from our biggest advertisers" and "Don't listen to objective opinions"
    -Brett
  3. #28
    Reputation: Fix the Spade's Avatar
    It's Mountain Bike Action...
    Assuming proper maintenance and discounting crash damage, I expect any component to last at least 5+ years. Consumable parts (bearings, seals, chains, jockey wheels) replaced as and when.
    For steel or Ti parts I expect the lifespan to be longer than me, my road bike is steel and from some time in the 1970s. It's ten-ish years older than me and still going strong. Everything but the rims, brake pads and consumable are original and it's probably covered 100'000 miles plus in it's life.
    Having said that, in two years of riding a fork would be stripped down 3-4 times and have the wiper seals replaced with the oil changed a bit more often than that.
  4. #29
    Reputation: jmmorath's Avatar
    Some of that is just funny...
    I came from BMX and granted they were bricks and short, but the only part left standing after years of seriously ridiculous bike molesting abuse was your stem. One year?
  5. #30
    Quote Originally Posted by jmmorath
    No kidding. I worked as a bike mechanic for 5 years and I've only seen 2 broken stems in all that time. One was an ancient steel stem on a bike that the owner must've left in a pile of slush & salt and the other was on a roof rack mounted bike where the owner had a brainfart and drove under a low bridge at highway speeds. Actually there was a 3rd guy who used an air ratchet to tighten the bolts on his stem and stripped all the threads in the process.
  6. #31
    Rep Power: Infinity
    Reputation: NateHawk's Avatar
    BS, no doubt.
    Let's see, I ride a 2003 Stumpjumper FSR and I have a few original parts on it.
    Of course, the frame - it's about 8yrs old now.
    Front and rear derailleurs
    shifters
    fork and rear shock - but both have been serviced to keep them functioning like new
    Of the parts I've replaced, the brakes are the oldest. I put Magura Julie disc brakes on it about halfway through 03. The pads aren't worn out, but I think I'll replace the pads and bleed the brakes this year just because.
    Everything else has only been replaced either because it was a wear item (chain, cassette, tires, cables, saddle) or because I felt like upgrading it (pedals, cranks, wheels, stem/hbar/grips, seatpost).
    I have replaced the pivot bearings a couple times on the frame, and it seems like they're about due for another replacement. however, since I don't trust my lbs with that job, I'll be buying the tools to press bearings myself and while I'm at it, I'll service my bb and hubs.
    Quote Originally Posted by shawnt2012
    ...the other two morons are bellowing like wookies in a bush waiting for a response back
    The GPS Geek
  7. #32
    Open letter to MBA:
    Dear MBA,
    After careful deliberation of the facts, personal experience, mechanics and physics of bicycle component maintenance and failure, we at mtbr.com have come to the consensus (without getting snarky with one another for a whole day!) that you are full of it (emoticon).
    Sincerely,
    mtbr.com
  8. #33
    Rebmem Rbtm
    Reputation: claydough001's Avatar
    Open letter to MBA:
    Dear MBA,
    Sincerely,
    mtbr.com
    Im in. Where do i sign? I wanted to start this thread in hope of everybody joining in to say that that is a crock. If it were true i would have to give up the sport. After all.....that is why i gave up golf. My country club dues were too much!
  9. #34
    Rebmem Rbtm
    I really want some people that have old bikes and components to start posting pictures of their stuff. I want this thread to last and i think that pictures make that happen.
  10. #35
    I guess in the age of the troll, the art of the practical joke is lost.
    APRIL issue. Lol
  11. #36
    Reputation: bikewagon's Avatar
    So what is the expiration date on a good 'ol Thomson SP or Stem? Those dates are killing me.
    Bikewagon - Hop on!
    www.bikewagon.com
  12. #37
    trail addict
    Reputation: Uncle Six Pack's Avatar
    I haven't read the whole article yet, but a quick glance definitely gave me a chuckle.... they are obviously pandering to their advertisers by trying to convince readers to spend money when they don't have to.
    I have a 2006 Specialized HR that came with not-top-shelf components.... while I do suffer from upgraditis at times, the wheelset, headset, and bb/cranks are all stock.... hub bearings (loose ball) were replaced.... otherwise, I just clean and grease once or twice a year.... derailleurs, shifters, and levers last forever as long as you don't smash them... handlebars and seatposts will only need to be replaced if they are severely fatigued.... and that generally doesn't happen from casual trail riding...
    The only wear items most riders need to worry about are tires, cables, and chains... and even those do not "expire". Everything else just needs to be maintained properly and inspected. Putting expiration dates is just an idiot-proof way to remind people to spend money when you don't do proper maintenance and inspections. MBA thinks their readers have no common sense.
    You better just go ahead and drop that seatpost down to the reflector... the trail gets pretty rough down there.
  13. #38
    Quote Originally Posted by bikewagon
    For the post, about 30 seconds after you see someone with a ti one...
  14. #39
    I bought that issue, thinking that it might actually have some kind of useful, objective information. I must be optimistic.
    The last sentence in that "article" says it all: If you are a true mountain biking fanatic, chances are you will have moved on to new and improved equipment before coming close to our expiration dates. Nothing like implying that riders are poseurs if they don't buy new components every year or two.
    I also like how MBA tends to gloss over or omit information. In the same issue, the RM Altitude test omits "Descending" as a heading in their testing. I can only assume that the RM therefore is a shitty at going downhill.
    I'm giving up on that rag, and like others have mentioned, buying Cosmo.
  15. #40
    2 tickets to the gun show
    Reputation: coiler-d's Avatar
    Sep 2004
    So according to this article, I should only need to spend about $2k per year on parts, and a new frame every couple years? Hum, I wonder who thrives on a budget made from advertising?
  16. #41
    FKA Malibu412
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by coiler-d
    Yeah but, this is what you spend anyway, a two biker family and all
    Hey, any ride plans this weekend? I'm heading out to the HS team race in Lakewood with the gang.
    No matter how slow you go, you are still lapping everyone on the couch.
  17. #42
    Quote Originally Posted by Mr. Blonde
    MBA is possibly the $hittiest magazine on earth. I'd rather read Cosmo.
    Why do you say that?
    Because the rides in Cosmo are better, duh!
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
  18. #43
    Yes, I ride...
    Reputation: Kona0197's Avatar
    Good point. Some of us can't afford such luxury.
    My Bike: '96 Balance AT-250
    My Blog: http://http://kona0197.wordpress.com/
  19. #44
    Wow, you guys are too sensitive, keep in mind it's the "April" issue... April Fools !!!
    2011 Specialized EPIC Expert Carbon
    2012 Cannondale Flash 29er 1 (on order)
  20. #45
    Reputation: XJaredX's Avatar
    Quote Originally Posted by K-OS
    Yeah but the thing is, that's such a crappy magazine that I wouldn't know if they are joking or not.
    Dirt Rag for me.
  21. #46
    Yes, I ride...
    Well it wasn't such a crappy mag with RC at the helm. Just seems to have gone downhill in the last few years. If it was me I would have promoted Zap to be editor instead of Jimmie Mac.
  22. #47
    Bicyclochondriac.
    CF- 1 year
    Saddle: 4 years
    Chain: 4 months
    Rear Shock: 1 year
    Cranks: 2 years
    Pedals: 2 years
    Frame: Al- 4 years
    Ti- 5 years
    Steel- 7 years
    CF- 3 years
    Stem: 1 year
    Bars: Al- 1.5 years
    CF- 1 year
    Grips: As needed
    Headset: 1 year
    Fork: 2 years
    Wheels: 2 years
    Tires: 6 months
    Is this for real? Did they really say all that? What do these people do? Dunk their bikes in saltwater after each ride and leave it out in the snow all winter?
    Yet another reason why I don't ever read that awful excuse for a mt bike mag, other then for the train-wreck entertainment value. What utter crap. I am not even going to bother answering any of it. Just forget you ever read it, along with anything else those clueless idiots print.
  23. #48
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    I'm glad you posted that info, I had no idea my bikes were so expired but they're all going straight in the trash before I get salmonella or even botulism from riding them.
  24. #49
    Reputation: bloodyknee's Avatar
    I couldn't afford to ride if I followed their replacement schedule, or I'd have to go with the lowest end, last year's bargin bin sale items. What fun would that be?
  25. #50
    Rebmem Rbtm
    you should see this months issue. they are pushing a 10,000 dollar specialized kissing some major Specialized A$$. It is a cool bike tho.
Hot Deals
Contests
Latest Mountain Bike Articles
