Results 1 to 5 of 5
    DIY Parts washer
    Hi. Does anyone have any good recommendations on a homemade parts washer? I typically throw my chain in a jar of cleaner, but the chain just sits in the gunk that comes off it. I think I need a basket suspended in the cleaner.
    Any ideas?
    Reputation: caad4rep's Avatar
    How about a chopped up sponge at the bottom of the jar?
    Reputation: William_Cannon's Avatar
    simple green + tooth brush is what I do. If I need to soak something, I put it in a jar after I've clean the major gunk with a toothbrush and a rag.
    Plays with tools
    Reputation: customfab's Avatar
    Some of the auto parts chains will put a parts bath on sale once in a while for ~$45. Pretty good buy. If your goal is to save money keep doing it the way you are.
    I don't ever take the chain off the bike to clean it though.
    I use 2 big margerine containers that have lots of small holes drilled 1 of them. I use it to strain the part out and then empty the dirty solvent into to storage and then rinse again the same way and it is fine.
    I have a friend that made a washer using a tub and a metal screen from home depot that was for windows and it worked well.
    Limits are your imagination.
    I have also started using a coffee filer set up to reuse the solvents and it works great (ps I use mineral spirits, bit hard but it takes grease off anything, paint too if you are not careful)
    Yes its retro but IT WORKS!
    8 Speed is great and V-Brakes rock!
    Ex-wrench...have a Question just ask!
  1. Bench top parts washer
    By timberstone in forum Tooltime
    Last Post: 02-19-2010, 08:06 PM
  2. ok one more time on this parts washer :)
    By spooky612 in forum Tooltime
    Last Post: 12-27-2008, 01:36 PM
  3. have you used this parts washer?
    Last Post: 12-11-2008, 10:23 AM
  4. Ultimate Tooltray/parts washer shipping...
    By 2melow in forum Tooltime
    Last Post: 03-13-2004, 10:24 PM
  5. Ultimate Tooltray/Parts washer finally avail.
    By 2melow in forum General Discussion
    Last Post: 03-11-2004, 09:18 AM
