DIY chainstay protector
Printable View
  • 11-24-2012
    bigfruits
    what are you guys using to protect your chainstay? brands and type of tape used would be appreciated. (search did not work out)
    i have a steel frame with a cheap chainstay protector i bought that i am not happy with.
    also, i plan on using Rustoleum protective enamel to patch up the nicks. would you recommend something else?
    thanks in advance,
    -z
  • 11-24-2012
    Dion
    Cut an old tube about the width of road bar tape, wrap it like road bar tape, finish with black electrical tape.
    booyah.
  • 11-24-2012
    Scrub
    3M 2228 mastic tape @ Home Depot, works and looks great. I use the 1x10" and you can do multiple bikes and its very flexible for tight curves and it wont peel off easily.
  • 11-24-2012
    pulser
    3M Electrical Moisture Sealant Tape from Home Depot.
    3M Electrical - Product Catalog - US:*Scotch® Electrical Moisture Sealant Roll
    You can make it conform to different tube shapes. And its easy to remove and replace when you need to. I put it on the top and bottom of my my chain stay and on the bottom of the non-drive chain stay to protect it form rock strikes.
  • 11-24-2012
    deke505
    silicone tape. It is easy to apply
  • 11-24-2012
    GhostRing
    free old inner tube.
    wrapped correctly, you only need to secure the very end of the wrap with tape.
  • 11-25-2012
    Dougie
    This is all you need.
    Take the wheel out. Start on the BB end of the chainstay and work your way back only overlapping a little bit each turn and keep it as taught as possible. When you get to the end just wrap it a few times with electrical tape.
    Innertubes work really well because they have a natural bend to them, so they curve naturally while you're wrapping them.
  • 11-25-2012
    DIRTJUNKIE
    Definitely some good ideas here. But Bigfruits you of all people should know about the Orange or Grapefruit Peel trick. Just add zipties.;)
    Trust me it works in a "squeeze".
  • 11-25-2012
    MrXC
    Road bar tape works well.
    Sent from my VS910 4G using Tapatalk 2
  • 11-25-2012
    006_007
    Sticky backed velcro.
  • 11-25-2012
    customfab
    I get scraps of the 3M stuff they use to protect cars. I get scraps of it for cheap at a local retailer/installer. It's the same stuff they package and sell as bike chain stay protectors without all the fluff.
  • 11-26-2012
    HappyMTB.fr
    +1
    couldn't be easier...
  • 11-26-2012
    marpilli
    1" wide gorilla tape. Still there and holding up well two years later.
  • 11-26-2012
    .WestCoastHucker.
    same here, except substitute 'mr. tuffy' tire liner for the innertube and a ziptie for electrical tape and work from the rear wheel to the bottom bracket. so all in all, not so "same" really...
  • 11-26-2012
    firebike7
    I used to use old tubes but I never liked the way it looked and wanted something I could clean easier. So I took some thermoplastic, a heat gun, pair of gloves, and a sander and made a removable, cleanable chainstay protecter. Works so well I made them for all my bikes and friends too.
