Results 1 to 5 of 5
    Jun 2013
    Disc pad spacers
    I am needing to bleed my disc brakes, I am looking at buying some spacers but need to know which ones to buy. My brakes are Shimano Deore brakes. Anyone advise me which ones to buy please. Or does it not matter as will either do ?
    Big Mac
    Reputation: mbmb65's Avatar
    Disc pad spacers
    Your local shop will know.
    Reputation: jearl's Avatar
    I would think you would only need one. I though about getting two, but then again I only bleed one brake at a time. It should not matter what kind you get as they all do the same thing. I went into my LBS asking if they had any I could buy, and they said "we dont sell them, and dont know of anyone that does, but we have plenty of them", and then he gave me one for free. Hopefully you have the same luck.
    "Ideal bikes are not bought, they evolve beneath you"
    You can allows approximate the space with something else and push the calipers back in when you install the pads.
    Reputation: Wishful Tomcat's Avatar
    From the Park Tool website:
    "Install Shimano® brake block #Y8CL18000 in place of pads. If blocks are not available, substitute a block of about 10mm wide block to prevent piston from extending. Substitute a clean 10mm hex wrench if the brake block is not available."
  1. Replies: 3
    Last Post: 02-05-2013, 07:59 AM
  2. Replies: 3
    Last Post: 12-29-2011, 06:14 AM
  3. SS cassette Spacers - need thinner spacers
    By ncj01 in forum Singlespeed
    Last Post: 07-21-2011, 08:23 AM
  4. Disc brake "spacers"---needed???
    By Porschefan in forum Brake Time
    Last Post: 05-25-2011, 08:11 PM
  5. 2011 Trek 3700 Disc vs 2008 Specialized Hardrock Pro DIsc
    By tavorh1 in forum Beginner's Corner
    Last Post: 05-19-2011, 08:52 AM
