Results 1 to 24 of 24
Thread: Did I F&%# up?
    Reputation: l'oiseau's Avatar
    May 2015
    Did I F&%# up?
    Got my mitts on my first carbon frame today...
    Decided to check some stuff over before I start the assembly process. Looked over everything real good. Check how my seat post fit, etc...
    This bike a has threaded BB insert. I took a look at it, it's just some kind of 2 piece threaded shell with a window to help the internal routing. Looked clean, but not like it was machined shiny.
    Didn't know if it would need to be chased so I decided to lightly thread my BB in and see how it felt...
    Here's where I think I went wrong...
    Non-drive side went in easy, out easy. Drive side started to go in easy until I got about 3/4 the way in and then got tight. I didn't force it and I was only turning with my fingers, no wrench.
    Anyway, long story short when it hit that spot it stopped, didn't go forward and wouldn't come out. I wiggled around with it for a few minutes before I conceded that it was stuck and I was probably going to ruin something getting it out.
    I got it out, but destroyed the threads on the BB. The threads in the frame insert look OK, maybe? By that I mean I think if I run a tap through there they'll be OK, but I'm kind of pissed about the whole experience. I ruined a perfectly good BB and perhaps compromised this frame.
    WTF? I mean I can see this being a thing on a steel or aluminum frame that was welded and painted (and even then not so much if you just lightly thread it to see where it might bind up), but on a carbon frame... I wasn't expecting this.
    I'm actually kind of really wondering about the quality of this bike.
    Am I wrong?
    Life is too short to ride a bike you don't love.
    Reputation: EatsDirt's Avatar
    Jan 2014
    If threads in frame don't appear butchered you're prob ok. Chase it with a quality tool and plenty of cutting oil and try a new bb...?
    Aug 2005
    What is the frame?
    Did you thread the BB in the right direction? Most BBs have reverse threads on one side.
    If the BB shell threads are f'd, I imagine it would be repairable.
    Also, whoever made your frame may not have properly chased/prepped the threads so there may have been paint or something on there that prevented the BB from going in smoothly.
    Pics would be interesting. Good luck.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    May 2015
    It's a Transition Vanquish.
    The frame is raw carbon, but it likely has a clear coat on it. No visible paint. They looked clean but it's hard to describe, they didn't look like freshly machined threads. They looked almost like galvanized metal. It'd def aluminum and not a nice beefy, machined insert like I would have though but a two piece shell that appears to press together into the frame before molding.
    I'm pretty sure I can repair it - I can see a path all around and no cross-threading, it's just a little chewed.
    Well I def know I put the right side in because the other side went in very smooth (and I've taken BBs in and out a zillion times). Also prepped frames before, but I wasn't sure if I need to chase a carbon frame with an insert. I know I do now...
    Contains no juice.
    Nov 2003
    That's bizarre. I can't understand how you could have boogered the threads just by finger tightening them.
    Pics are in order fo sho.
    May 2015
    Quote Originally Posted by Finch Platte View Post
    That's bizarre. I can't understand why you would have boogered the threads just by finger tightening them.
    Pics are in order.
    I had to use a wrench to take it out. That's where the damage was done.
    Why it bound up and wouldn't come out when I was using my fingers is the mystery.
    Contains no juice.
    Nov 2003
    Quote Originally Posted by l'oiseau View Post
    I agree.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    The issue typically lies with the dissimilar metals. The BB was very likely stainless and the shell was aluminum. Stainless will gall without a lube of some kind. Anti-sieze is the lube of choice, but for trial fits, I've used vaseline.
    One gear is all you need.
    May 2015
    Did I F&%# up?-36915624_1936242476442870_8360308997357568000_n.jpgDid I F&%# up?-36898449_1936242506442867_2847936382402297856_n.jpg
    Best two shots I could get.
    There was some assembly lube still on the BB.
    It went in pretty far before it did this, and you can see it only hurt the first few threads.
    It tore the threads completely off the BB.
    Reputation: plummet's Avatar
    Take it to a bike shop. They should have a thread cleaning tool. If uou havent cross threaded it too bad it will be ok.
    May 2015
    Quote Originally Posted by chuckha62 View Post
    This is actually what I thought as well, but the BB I have claims to be aluminum for the thread portion. Looked like it too the way it tore to shreds.
    Haymaker MTB
    Mar 2018
    Did you thread the BB in dry without any lube/grease whatsoever? If so I vote as others mentioned you ran into galling. Lesson learned, clean up the threads and use the proper grease!
    Ariolimax columbianus
    Reputation: nativeson's Avatar
    Apr 2005
    install the drive side first https://www.youtube.com/watch?v=oi1Z0iOGwY8
    good luck!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I feel like only now, about 15 years later, I can admit that I chased the threads opposite of what I should have on a bike frame. I was actually able to thread the BB in like that and just changed out bearings as necessary, but since it was shimano it was pretty solid anyway. Eventually I cracked the seat-tube due to running too-long of a post, but the BB was solid, I think I used loctite and it held up just fine for 5 years or so and showed no signs of ever being a problem.
    It must've been dirty, then.
    Reputation: WHALENARD's Avatar
    Feb 2010
ID:	1207409Click image for larger version.
    Imo those threads will chase no problem. With that said your story doesn't make sense to me.
    It is no measure of health to be well adjusted to a profoundly sick society.
    I removed an XT BB for a RF BB that had really long threaded section. The RF went in smoothly to the point the XT had been but started getting tight. After a couple turns I decided to back out the RF BB - Too late it was starting to chew the threads. My LBS was able to chase the threads w/o any issue. The BB was secure though there were a couple ugly threads. LBS stressed having a threaded BB chased / faced on all new builds.
    Jun 2018
    Also, is this a "genuine" transition?
    I find it hard to believe that a reputable company that has USA standard QC protocols would sell you a "naked, clear coated frame" with an unchased BB shell.
    If its a copy, thats cool, but it would explain a lot. Those threads will chase fine. Theres enough uncompromised threads to engage most good BBs.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by keen View Post
    Quote Originally Posted by Asend2Desend View Post
    I've always chased/faced the bb on new builds, though I have only built 3 bikes from the frame up, and only 2 had a threaded bb. I was going to at least face the bb on the other, a BB121 frame, but the shop I bought it from insisted it was unnecessary, so I didn't. It hasn't been an issue. But the 2 threaded bb frames definitely needed both chased and faced.
    May 2015
    Hahaha - they sent it to me. If it's a fake, jokes on them I guess?
    Also, I'm going with galling. Never felt anything like that before though.
    Reputation: LargeMan's Avatar
    May 2017
    This is why PFBB are used mostly now and are superior.
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by LargeMan View Post
    Thanks, now my eye is twitching...
    Rigid SS 29er
    Hardtail 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Galling is always going to be worse on fine threads regardless of material. Any dirt at all has no room to displace. Hell, even paint overspray can cause it.
    May 2015
    Whelp - I'm certainly never putting a BB anywhere near a new bike until it's been chased. Never had before... lesson learned!
    Also I agree - I think it will clean up OK as long as the tap starts right. It's not cross-threaded. It just literally looks like it tore the material off the BB, and a little off the threads in the bike. I'll find out tomorrow.
  1. Replies: 2
    Last Post: 04-17-2015, 11:45 PM
  2. Did I actually get the bike I thought I did? 2008 Specialized Epic Expert
    By Central Cal Rider in forum General Discussion
    Last Post: 04-08-2012, 01:54 PM
  3. Just did my first 24 solo. What did I learn...
    By crazy_bikerdude in forum Endurance XC Racing
    Last Post: 08-04-2011, 08:24 AM
  4. Well I did not ride Green Mtn...but I did ride
    By 29or6to4 in forum Colorado - Front Range
    Last Post: 02-20-2011, 09:33 AM
Members who have read this thread: 202
