Results 1 to 5 of 5
    determining integrated headset angle?
    How do I determine if my frame takes a 36/45 (CK) or a 45/45 (campy) headset bearing???
    Plays with tools
    Reputation: customfab's Avatar
    If you go down to the LBS you can take a look at your current one and the replacement. I also want to say that Cane Creak has a data base of what common frames use what. But I could be wrong on that one. FSA also makes a go/no go style gauge that you can use to figure out what you need. Or maybe if you told us what frame it was somebody would know what you need.
    It is a Felt six race. The flanges are ever so slightly stretched- so someone suggested I try a campy spec'ed headset which is 42mm, over CK which is 41mm.
    http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
    Plays with tools
    Quote Originally Posted by OuterNational View Post
    If they are stretched it's most likely going to be in the fore/aft direction and the side to side is probably a little tight. Your best bet is to get some locktite 680 and install the correct headset in the frame and let it sit over night before riding it. If you haven't already bought that frame I wouldn't unless you could get it for ~$100 or so. Fighting with these kinds of problems is never fun.
    My initial thought was that they needed to be pressed in- but I found out they dont! I think I am better off now, maybe its not so stretched as I originally thought.....
  1. Which Integrated headset is the best?
    By Mr.SBC in forum General Discussion
    Last Post: 09-24-2010, 08:21 AM
  2. Replace Headset/Bearings on Integrated Headset?
    By iRoNeTiK in forum Bike and Frame discussion
    Last Post: 12-31-2009, 12:45 PM
  3. Determining seat tube angle...how and does it matter?
    By Tweezak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2009, 09:30 PM
  4. integrated headset std.
    By becik in forum Frame Building
    Last Post: 10-15-2008, 01:44 PM
  5. VT Integrated Headset
    By Dirtman in forum Giant
    Last Post: 08-24-2004, 07:05 PM
