Results 1 to 2 of 2
    Reputation: ssphoenix's Avatar
    Cutting excess carbon tubing
    What can I use to make a nice cut the excess carbon fork? Would a pipe cutter work on carbon?
    Thanks in advance.
    Oct 2007
    Do not use a pipe cutter. The compression force from a pipe cutter will mess up carbon big time. Use a fine hack saw blade (32tpi) . Tape the area you are cutting with masking tape to eliminate delamination. Ideally you would want to use a cutting guide to get a straight cut. Take it slow and easy. Once the tube is cut, apply epoxy or clear coat or nail polish to seal the end.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
