Results 1 to 35 of 35
    Binned
    Nov 2008
    Crank Bros pedal question: Half platform, half clipless?
    I may getting close to pulling the trigger on buying an urban commuter rig. Something that I can burn some calories with on a quick street grind from out my front door when I don't have the time to drive to the dirt.
    The bike will be used by myself and my wife. I want to equip it with CB pedals because that's what I ride on dirt.
    My question is:
    Are there attachments that will transform a set of Eggbeaters into a platform on one side so that my wife can ride it with confidence while wearing regular athletic shoes?
    I've seen these on Shimano pedals, just wondering if it's an option with CBs because I would like to avoid having to change the pedals out when she wants to ride it. Thanks for your input!
    IH, HYHT.
    Reputation: Forster's Avatar
    Sep 2013
    Hawg, you could make such a platform but it would be difficult to install and you would not be able to leave it when you use clip in shoes (it would fall out). The solution I would look at is buying a set of mallets and trying them unmodified first. If you need to modify the mallets for your wife you could probably cut back one set of beater wires (although I have not tried this). Alternately you could build a small riser for either the mallet or candy pedal to allow one side to be used sans-clip.
    IH, HYHT.
    Sep 2013
    Platform or Clipless (or both?)
    Here's a related thread. If your wife is riding with cycling shoes, having the cleat mount cover cut out might give her extra clearance. Although I never seemed to have a problem riding without cleats using mallets on my tandem.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I like turtles
    Binned
    Nov 2008
    Awesome, thanks guys!!!
    Reputation: Ronnie's Avatar
    Quote Originally Posted by NYrr496 View Post
    I hate those things. Also pedals with flats on one side and clips on the other. They always hang upside down and when you try and flip them over they spin to the bottom again.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Jan 2013
    Mallets work great as platforms for techy crap when you need a few pedal strokes before bothering to clip back in.
    As dedicated platform use? Not so much, they feel like a platform with a ball bearing in the middle.
    Binned
    Nov 2008
    Thanks BRG, looks like the best option is to simply change out the pedals for whoever is riding the bike that day. I already have both ready to go anyway.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Hawg View Post
    No way Hawg not you please tell me it ain't so.
    Go with TIME and choose the Z pedal for this setup.
    It's a perfect time for you to switch over anyway. Stop digging yourself in deeper and deeper. Go with a dependable setup. TIME pedals are One of the few thing's on your bike that you bolt on and forget about it.
    Quote Originally Posted by targnik View Post
    So I shoot off all full of bravado, hit this wee booter - grabbing some air, then I land - leading into a greasy rut.
    Binned
    Nov 2008
    You need some sleep buddy!!
    Those pedals would not work wearing running shoes. I'm very sorry, but you are out of line here and out of TIME. Now, go get some sleep!
    Oct 2000
    Go back and read my whole post. The Z pedal is perfect for running shoes.
    Binned
    Nov 2008
    What I'd need is a combo pedal that has a cage built around it that is higher than how high the clips stick up so that the clips are not felt by an average street/track shoe. To this day, I am unaware of any manufacture that offers such a thing. That's why I think I will just pull off my EBs and mount some flats for my honey when she want to ride. I have some uber-light weight flats already in stock in Hawg's Bike Closet.
    Besides, no way your monstrosity TIME pedals weigh less than my EB Ti pedals. Don't forget that I am a semi-weight-weenie. Weight does matter for us climbing monsters.
    And finally, the TIME pedals are u-g-l-y.
    Oct 2000
    The Z pedal with the platform is perfect with shoes. The clip sits below the platform. The other pedal is for your mtb weight weenie ride. It is a carbon titanium Titan XS Time pedal. It weighs 270 grams. Amazon.com: Time ATAC XS Ti Carbon Clipless Pedals: Sports & Outdoors
    And finally the TIME pedals scream sex appeal.
    Reputation: theMeat's Avatar
    Try Mallets for both, I hardly find it annoying, and less than one side platform one side clipless pedals. They have removable pins for adjust, and far less annoying than changing pedals on the reg. When the springs are brand new it's more noticeable. Plus with one pedal's threads reversed, and the crankset's soft aluminum, it's just not the best plan if you like your crankset.
    With that said I'd rather have pinned platforms paired with the right shoes on one bike, and clipless on another, just can make it more specific, not only in terms of shoes.
    My .02
    Round and round we go
    Binned
    Nov 2008
    Quote Originally Posted by theMeat View Post
    My .02
    Thanks, I will look into that.
    Binned
    Nov 2008
    The Z pedal with the platform is perfect with shoes. The clip sits below the platform. The other pedal is for your mtb weight weenie ride. It is a carbon titanium Titan XS Time pedal. It weighs 270 grams. And finally the TIME pedals scream sex appeal.
    My EB Ti pedals come in at 230 grams, thank you very much.
    And sex appeal?! Yeah if you like to have a pair of Cylon fighter ships from Battelstar Galactica at the ends of your cranks.
    Oct 2000
    I second the TIME pedals. A much way to go in terms of dependability. There's another recent CB thread with quite a bit of complaints. And I noticed in that thread TIME pedals are getting rave reviews.
    May 2005
    This isn't what you're asking but I would put platforms on it. You'll burn more calories and you can hit up jumps and urban stuff.
    Binned
    Nov 2008
    Quote Originally Posted by derekbob View Post
    We live in steep hills. The average grade is 10%-20% on pavement. I will get me workout simply riding a mile or five or ten from home. No jumps for this "roadie" bike that will have skinny road tires on it
    To have a better idea of what I'm talking about, check this link:
    KONA BIKES | 2014 BIKES | COMMUTER | DR DEW
    May 2005
    So your wife can handle the hills with platforms but you can't? JK
    I would swap pedals if I needed the clipless. I'm thinking hybrid pedals will have both you and your wife wishing for different pedals.
    IH, HYHT.
    Sep 2013
    So I emailed Crank Brothers today with the following questions:
    1. Have you considered building a version where the platform is biased or off-set on one side to allow flat shoes to be used without the eggbeater wires pressing on the shoe? i.e. 50/50 meets Mallet.
    2. Could one half of the eggbeater cage be ground off (to allow flat use on one side) or would the cage spin away from the shoe?
    Rich Garrett replied:
    1. At this point we are not interested in this type of pedal.
    2. I donít recommend do this for safety and you would cancel out the warranty.
    I recommend finding what type of pedal you prefer and go with that style.
    Binned
    Nov 2008
    My wife will pedal calmly. I will be out of the saddle hammering.
    Binned
    Nov 2008
    Quote Originally Posted by Forster View Post
    Oct 2000
    Did Crank a Brothers email you back and suggest going with TIME. Don't feel bad it wouldn't be the first TIME.
    Binned
    Nov 2008
    All right buddy, you're in TIME out! Go sit in the corner. Facing the wall...
    Oct 2000
    Do you know how many TIMES I've been told that.
    Binned
    Nov 2008
    TIME and TIME again, I fear.
    Oct 2000
    Hey I don't go in to your Crank Brothers thread and start spewing off how good TIME pedals are. I suggest this TIME you sit it out.
    Binned
    Nov 2008
    Ohhh! TIME out again buddy, back to the corner. This TIME stand on your head!
    IH, HYHT.
    Sep 2013
    Time won't give me time and apparently neither will CB.
    Binned
    Nov 2008
    DJ, now look what you did!
    You got poor Forster all tied up in your TIME thingy.
    Oct 2000
    Sorry for getting Cranky but this TIME I think I've fallen and I can't get up. Of course I was clipped into my CB pedals and they exploded sending me on my head. Good thing I had my helmet on this TIME. I think this exploding pedal thing has ran out of TIME. My next pedal purchase will be a pedal with an excellent reputation. This TIME I choose TIME.
    IH, HYHT.
    Sep 2013
    Hawg,
    Not a problem, DJ can't hurt the feelings I don't have. I'll just (sniffle) keep smiling and assure myself that "I'm good enough, smart enough and dang it, people like me."
    Oct 2000
    Plays with tools
    Reputation: customfab's Avatar
    Half platform or half clip less, they're 100% garbage.
  1. Crank Bros 19 vs 17?
    By cave12man in forum Tooltime
    Last Post: 03-25-2014, 07:25 PM
  2. Crank Bros. Pedal Bearings
    By pcxmbfj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-22-2013, 09:42 PM
  3. Big Thanks to Crank Bros!
    By cstem in forum Arizona
    Last Post: 09-13-2012, 07:38 PM
  4. Strange Crank Bros Cleat Question....
    By rpiontek in forum General Discussion
    Last Post: 08-04-2011, 04:18 PM
  5. Replies: 15
    Last Post: 06-14-2011, 05:18 AM
