Results 1 to 33 of 33
    Reputation: IDkid's Avatar
    Oct 2010
    cornering technique - need advice
    During last Sunday's ride I was coming pretty fast into a left turn. Pretty sure I was doing everything right; outside foot in the down position on the pedal, leaning into it, etc... I felt the bike start to slide out and instinctively my left foot shot out and to the ground. (Before anyone goes after me for destroying trail, just know that I wasn't purposefully trying to skid and the trail was covered with newly fallen leaves.) It kind of jolted my leg as I made contact with the ground and my femur/hip joint is still hurting a couple days later.
    Should I have not shot out my foot so quickly or already had it out just in case? Or does this just happen sometimes? Is there something I should work on as far as where I'm putting my upper body weight? I've only been riding for a couple years so coming into turns fast enough for something like this to happen is new for me. Thanks in advance for any advice.
    no problem sticking out the inside foot....and don't worry about the skid etc....
    Worry about riding in control so you could stop before you hit someone who might be down...just after a blind corner.
    here are some cornering tips to try:
    first off - tires make a huge difference. the right tire lets you lean farther and rail a turn like never before.
    keep your body up, lean the bike, outside foot down, and, this might seem odd, but inside foot in, with your knee touching the top tube. it's a sort of "body english" move, it also lets you lean your bike much farther than you normally would, and make much tighter faster turns.
    Sounds to me like you did all the right things.
    You'll never learn to corner faster if you don't push it to the limit like that. And you'll become more comfortable with the back tire not always being hooked up.
    As far as technique... you did right with the pedals. The only other two bits of advice that helped me corner faster sound intuitive, but made a HUGE different.
    1. Look where you want to go. If you look at the outside of a turn because you're worried about going there, that's where you will wind up going.
    2. Point your inside knee in the direction you want to go as well. Helps with shifting your center of gravity and such. Also part of the mental aspects of committing to a fast learn (like step 1). I know this is opposite of what the poster above me said, and I am not saying he is wrong.
    I am by no means a pro or anything. Just trying to share what helped me out.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by IDkid View Post
    You were moving too fast for the conditions (the leaf cover). Nothing more.
    mtbtires.com
    since 4/10/2009
    Reputation: Harold's Avatar
    Shiggy nails it. Newly fallen leaves are treacherous. Wet leaves are like marbles. Slow down.
    Some trail stewards like to rake the leaves because of this. I say screw that. The leaves will break down on their own if people ride on them. I only rake if route finding becomes difficult because of deep leaves. And even then, only enough to find the trail. Leaves are like rocks and roots-part of the trail
    Dec 1998
    Quote Originally Posted by NateHawk View Post
    The other reason to remove leaves is they hold water when they break down. The added moisture can soften the tread and allow ruts and erosion to form.
    mtbtires.com
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Right around 3:24... (I recommend watching the whole series)
    <iframe width="560" height="315" src="http://www.youtube.com/embed/rm1ANkGUQI8?list=UUvT5KxCp2yatKI4DTbYRx7g&amp;hl=e n_US" frameborder="0" allowfullscreen></iframe>
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Oct 2010
    Thanks for all the input. In retrospect I probably was just going a little too fast but there are definitely some good points to be taken here and I'm going to make an effort to think about them and practice them next time I ride....which won't be for at least 3 weeks thanks to work.
    Reputation: B-Mac's Avatar
    I took a DH lesson at Whistler this summer. My instructor + 2 others that I spoke to recommended keeping the pedals level during a corner vs. dropping the outside pedal. I'd been dropping the outside pedal since reading the Lopes book. The thought is that putting the majority of the weight on the outside pedal makes it more difficult to get the bike leaned over & complicates setting up for the corner.
    YMMV, but I've been cornering with my pedals level since the lesson & feel it helps.
    By the way, not suggesting that your pedal position had anything to do with your slide-out, just seemed like an appropriate thread to mention this.
    Check out my You Tube Channel
    since 4/10/2009
    Quote Originally Posted by B-Mac View Post
    interesting. I use both techniques, depending on what feels right for the situation. I do the pedal down technique more often on my commuter, which has a short wheelbase and has a bit of toe overlap. I don't feel comfortable going pedals-level with my inside foot forward into a turn at speed to avoid the toe overlap problem, so I drop the outside pedal so I can keep my right foot out of the way.
    on my mtb, I'm usually pedals-level.
    Quote Originally Posted by shiggy
    That is true. though I treat that situation as a case-by-case basis doing spot removal in locations where the leaves would otherwise collect and cause that problem. I am not a fan of wholesale leaf removal on miles of trail in an entire system.
    Dec 1998
    Totally agree.
    mtbtires.com
    Maybe your technique isn't spot on. I learned a lot from a thread called Norcal cornering clinic.
    Just Ride
    Reputation: Cormac's Avatar
    I think the freshly fallen leaves may have had something to do with you front sliding out. Fall isn't my favorite time of year to ride for that very reason. Put your foot down to keep from sliding your skin on the dirt or don't and take the slide like your sliding in to home plate. Your choice.
    SS ==> Nut up or Shut up!
    If OP was riding with good technique the front and rear would slide at the same time. Fun!
    since 4/10/2009
    Quote Originally Posted by Huck Pitueee View Post
    Except when you start sliding on leaves you don't tend to stop until you are on your backside...esp wet, frosty leaves.
    www.derbyrims.com
    Reputation: derby's Avatar
    Yes, this.
    IMO, inside foot down off the pedal or just outside pedal down is only for slow braking switchbacks and sketchy slow gravely drop outs, or naturally recovering from a mistake like you experienced. Layers of leaves are treacherous, and no place to push the limits.
    What? Lopes said drop the outside pedal ....like a roadie with no tire patch?
    Always Learning
    Reputation: BruceBrown's Avatar
    Some good tips here...
    3 Steps to Faster Corners - Pinkbike
    Cornering Basics with James Wilson Video - Pinkbike
    How To: Cornering and Straight Line - Pinkbike
    Reputation: Jeff in Bend's Avatar
    Jun 2010
    Cornering feet level limits your range of motion so you'll end up leaning with the bike once you get to a certain point, you can get away with leaning with the bike on bermed corners. Cornering with the outside foot down will dramatically increase your range of motion and let you lean the bike as much as needed and stay centered over the bottom bracket.
    Reputation: Diesel8810's Avatar
    May 2012
    More aggressive tires for the season... Adjust speed for conditions... and like mentioned above learn to react and counter act the sliding at slower speeds until you are comfortable then take the turns faster...
    Think of trying to go around a turn in a car (any for that matter) on road in the snow or rain at the same upper limit speeds as you do on a warm Sunny day.. .. Disaster.. The remedy there is similar.. Proper tires and speed for conditions combined with experience and finesse..
    ready to ride
    Reputation: mattnmtns's Avatar
    LOL
    Good to know I was using good technique yesterday when I was trying to push the limits of a new Panaracer Rampage I put on the front for fall. I found out how fast is too fast. Me+terra firma=thud+sore shoulder
    Yep too fast for conditions.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Quote Originally Posted by Jeff in Bend View Post
    Cornering with the outside foot down will also dramatically reduce your ability to absorb bumps in spots where the trail is a bit rough.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Oct 2010
    Quote Originally Posted by perttime View Post
    Reduce is the key word. I do not think it hinders bump absorption enough to justify the lesser traction. However, I race XC, so there are considerably fewer bumps on a typical XC trail than a backcountry trail, but at the same time all of the corners on the XC courses are fast. Therefore, I corner like a roadie on dirt. Weight on inside hand, outside foot, looking through the corner with your knee pointed out.
    Something wrong with your bike? Blame it on super human strength and sleep well at night knowing you are more than a man.
    Tool
    Reputation: Pedalphile's Avatar
    Lots of good tips in here.
    One tidbit that I haven't seen in this thread (although I didn't watch all of each of the vids) is raising your outside elbow up and forward can help you get around a corner. I believe it helps to get more of your weight on the inside hand, however, it feels almost like magic when you get it right.
    -Pete
    I can barely get my mouth around it.
    Not really responding to your post b/c you make a good point & I'm sure that opinion on that issue varies - But your photo is a great illustration of another pointer my instructor gave me: Keep your weight over your outside grip. Keeps the weight over the bigger cornering lugs on the tire (vs. the center lugs) & helps you to get the bike leaned over.
    Quote Originally Posted by Pedalphile View Post
    -Pete
    Thanks! I'll add that in to the mix of.
    Lower outside foot
    Lower heel.
    Chin up near the head set.
    Lay bike over between legs
    look way ahead.
    Rotate body toward apex.
    bend elbows.
    did I miss one?
    Piece of cake!
    local trails rider
    Aug 2005
    Quote Originally Posted by ZXFT View Post
    I'll give you that outer foot down is usually the way to go in fast and smooth corners. In my area fast and smooth corners are really the exception. Also, with my proportions, having a foot down leaves very little bend in the knee, so it really does hinder bump absorbtion... and if I cannot absorb bumps, I don't have traction either.
    Whatever works for you in a particular corner. There is no one single way that works in all cases.
    Jun 2010
    I would agree, but not dramatically. When I drop my outside foot my leg is not straight and I do have the ability to absorb shock. Most bumps in a corner are at the entrance due to improper breaking, I would be feet level in this area and wouldn't drop my foot until after. If the corner's rough throughout it may be necessary to be feet level through the whole corner, but with my feet level my bike lean is limited and therefore would not be able to go as fast. One thing I've learned is there's never an always in MTBing.
    Jun 2010
    Do you have a dropper seat post?
    I love dry oak leaves with acorns under them, makes for "interesting" rides.
    local trails rider
    Aug 2005
    No. And I'm not planning to get one. A couple of reasons: I like simplicity in my bikes, and the ups and downs in my area are so short that I prefer to take whatever comes with one setup.
    When I was using adjustable height or ETA (remember that?) forks, I tended to forget changing the setting for the trail
    Mousey
    Lolz
    Quote Originally Posted by leeboh View Post
    that's funny
    Gravity ... is a harsh mistress
    Jun 2012
    Quote Originally Posted by jeffscott View Post
    Assuming it was just a kid he could always just bunny hop them.
