Results 1 to 69 of 69
    Anti-elitist
    Sep 2012
    Idea! Compromise: Mechs and Hydros
    Hi guys,
    I thought of something today. this isn't a fully developed idea, just a thought.
    I've noticed that people who are somewhat new to MTBing (myself included) are somewhat afraid of hydraulic brakes. The prefer mechs because they are familiar with cables, and they can use pliers and an Allen wrench to set them up. It's easy to see how they work. Unlike hydros, which are totally sealed off and are somewhat different(didn't say difficult) to adjust.
    What if there was a mechanical caliper that used hydraulics?
    As in, there would be a pivot arm, just like a mech, and that would push in a master piston, which pressurized 2 pistons, each one behind a different pad.That way, one would be able to use cables, but still have the two way pad movement. I realize that a major advantage of hydros is the silkiness of the lever, and this brake obviously doesn't achieve that. Also, this design sacrifices weight, because it has the moving parts of a Mech and the chamber/pistons of a hydro. But I think that some people would be willing to sacrifice a few grams for that little advantage.
    Really, all this is a mech brake that uses hydraulics to push pads onto the rotor from both sides. What do you say? Is it worth it?
    BTW: You saw it here first.
    It's pronounced "so pro and cool."
    It was an impulse decision.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by sauprankul View Post
    It would be an unnecessary complication that would cost and weigh too much.
    since 4/10/2009
    Reputation: Harold's Avatar
    I'm not sure about that. All that extra mechanical complexity transforming hydraulic pressure to mechanical energy which rotates the mechanical pistons would just make the calipers tanks. And plain old mechanical calipers are heavy as it is.
    You are right, though, about hydros being unfamiliar and a source of fear. That's just something folks have to get over if they want to use them. If not, they can use mechs.
    Anti-elitist
    Sep 2012
    Let me put it this way. Instead of putting the plunger in the levers, let's put them on the calipers. Then to use the plunger, you use a cable which is attached to a lever control. I don't think it would add TOO much weight or complication, would it?
    Feb 2012
    To me it sounds like you have just invented a design that combines the worst of both solutions. They would likely need bleeding anyway, you will have to deal with all the usual cable/housing dirt&wear&tear issues, you will have quite nasty cooling issues IMHO, the weight of your brakes is going to be sky high, etc.
    Btw. I am not quite sure whay you mean by "different" adjusting of hydors. Mechs are WAY more difficult to set up, hydros are "bleed and forget", self-adjusting along the way. The only problem with bleeding is that it can be messy and requires you to act fast. With a little bit of practice, it is not a big deal at all.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    cable actuated hydraulic calipers? welcome to 1998...
    Anti-elitist
    Sep 2012
    Quote Originally Posted by .WestCoastHucker. View Post
    Really? Links pls.(Has this been tried?)
    You guys are right. It was just a thought.
    Reputation: Joules's Avatar
    that was how they did it in 1994. Was glad to see that one disappear.
    Both those ideas seem to combine the worst of both mech and hydraulic brakes. I get that cables are more familiar, but honestly, does that stop you from using hydraulic brakes on your car?
    Pro Crastinator
    hayes made a set in the late 90's that they only produced for a couple years. there were most likely others as well...
    Diamond "safety" bike frame, welcome 1910.
    Rear derailleur, welcome 1923.
    So what.......
    Anti-elitist
    Sep 2012
    Hmm... So there's no way to get two pad movement on mechs? Does that even matter at all?
    Pro Crastinator
    Quote Originally Posted by Yogii View Post
    ...So what...
    some designs are scrapped for a reason...
    Anti-elitist
    Sep 2012
    Pro Crastinator
    i almost linked you to that thread...
    Reputation: roadie scum's Avatar
    Jan 2011
    So what.......
    Binet-Simon test in 1905.
    Anti-elitist
    Sep 2012
    But seriously, is there any advantage to having both pads move rather than having one "fixed" pad and one that presses? I know for a fact that it would make it easier to center a caliper and it would allow the rotor to not bend when braking. Would the latter cause any problems?
    May 2005
    IRD has (had?) a mechanical disc brake where both pads move. I never heard much about it and it seems to have gone away.
    I think it does matter, but not that much as long as you adjust your non moving pad to be as close to the rotor as possible.
    Anti-elitist
    Sep 2012
    I'm sure it matters, or else nobody would have bothered to make hydros have both dynamic pads. They too would be running with one fixed pad.
    Feb 2012
    I'm sure it matters, or else nobody would have bothered to make hydros have both dynamic pads. They too would be running with one fixed pads.
    Hydros are virtually maintenance and setup free. Pad wear is compensated with a gradual piston extension. You cannot achieve that with a fixed pad.
    Anti-elitist
    Sep 2012
    "Pad wear is compensated with a gradual piston extension. You cannot achieve that with a fixed pad."
    Is that it? Automatic pad wear compensation is the only reason why hydros have both dynamic pads?
    That would mean there is absolutely NO REASON for mechs to have that feature. So, my idea/thought has no purpose. Oh well.
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    I don't understand what you mean by "fear" of hydraulic brakes? Perhaps grabbing or clutching
    the levers so that you fly off the saddle? To me its like "fear" of power brakes on a vehicle.
    You learn to use it. Sure stomping on your car brakes will send you into the windshield but
    who does that? I am a fan of hydraulic brakes. Wait til electronic derailleurs start getting more
    popular.
    Anti-elitist
    Sep 2012
    Well, if anybody's interested, Thor29 was right. Dual Banger Disc Brake
    Interloc Dual Banger Mechanical Disc Brake Disc Brake System Reviews
    Apparently, its power and modulation rival that of the BB7 and some hydros, which is saying something. But it isn't well designed and has lots of flaws. And at $99 per wheel, you're better off with Deore's. That's what I got from the reviews. What do you say? To dual piston or not to dual piston?
    gran jefe
    Quote Originally Posted by StiHacka View Post
    Maybe, but when you see a post titled "Can't get my brakes to work right, about to quit", you have a pretty good idea which type they are using...
    gran jefe
    mechanicals could be build with slider pins, like the one-sided hydraulic brakes on most everyones car. prolly not worth the wieght and complication?
    Feb 2012
    Quote Originally Posted by Bill in Houston View Post
    I suspect in 99%, they have troubles bleeding them.
    Reputation: Brewtality's Avatar
    Quote Originally Posted by fatcat View Post
    I think it has more do with not understanding how hydraulic brakes work. Cable operated brakes are easy to understand. You pull a cable at the lever and it actuated the pads at the caliper. You can see it working. It's easy to figure out. Uneducated garage mechanics can work on them without special tools or knowledge.
    Furthermore, they can be repaired on the trail if needed. Break a hydro line 30 miles from the trail head and you are riding back with no brakes. Break a cable and its a five minute fix.
    Its all Shits and Giggles until somebody Giggles and Shits
    gran jefe
    mmm hmmm, i suspect you are 100% correct.
    Anti-elitist
    Sep 2012
    popular.
    People are, have been, and will always be afraid of the unknown. Beginners are more familiar w/ cables ON A BIKE and can easily see how they work. Hydros are mysterious, black magic to them and therefore, scary. Maybe not to you. But if something goes wrong people want to be able to tell right off the bat what it is. And they want to be able to fix it right off the bat. Seals, fluid, kits, nah. How about an Allen wrench and pliers?
    Electronic derailers sound fun. But they lack the "get on and ride"-ability. You have to charge the batteries. Of course, for pros, the zero effort shifting makes sense.
    That makes me smart
    Nov 2003
    And the other 23% are contaminated rotors/pads.
    That makes me smart
    Nov 2003
    Quote Originally Posted by Brewtality View Post
    If you have a spare cable. I remember those days carrying a couple of them around.
    since 4/10/2009
    Never managed to break a cable. I broke a fixing bolt on a cheap set of vees once. Spare cable would have done a lot of good. Not so many folks carry a spare set of calipers.
    I love the mention of failed hydro lines. Stop scaring the noobs. I am unaware of a single case of that happening.
    Anti-elitist
    Sep 2012
    Unless you totally wipe out, you would be hard pressed to a) break a line or b) break a cable. In which case those are probably the least of your worries.
    EDIT: Unless the hose catches on something or you haven't replaced the cable in a while. Hydro hoses should last quite a while and cable brakes should be OK if you snag 'em.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by NateHawk View Post
    ...I love the mention of failed hydro lines. Stop scaring the noobs. I am unaware of a single case of that happening.
    I think this used to happen in the early days of hydraulic MTB brakes. I know a 140# guy who melted the hose off his front caliper BITD (in GA). It was not his fault - it was bad heat management in the brake design. Things are much better these days.
    The only scenario that mech's probably endure better is the tree hit on the lever. If the cable barrel adjuster snaps off, you can probably still use the brake to some degree. While a broken hydraulic fitting kills the system. Other than that, they are pretty equal for durability.
    I'm glad the OP brought this subject up. I had been pondering it as well. I really thought the cable-actuated hydraulics would work out.
    -F
    It's never easier - you just go faster.
    Anti-elitist
    Sep 2012
    They might, just not with today's technology. One day, someone will create a hydraulic brake that appeals to beginners. I'll be first to get it if I'm not already running Shimanos.
    I have seen a few hydro line failures.
    One was an improperly set up line. The rider had attempted to shorten it and did not get it properly secured.
    The others were trail damage. One wreck and one grabbed by a tree branch.
    I have also seen a broken cable. It broke at the pinch bolt at the caliper. The rider had a spare in his pack. It only took me a couple minutes to replace.
    since 4/10/2009
    I have seen the pinch bolt cable failure before, but only in the shop. When I've seen it, it came from too many cable adjustments weakening the cable at the pinch bolt.
    Interesting about the hydro line failures. I wouldn't count the improperly set up line. Unskilled mechanics screw up all sorts of parts on their bikes and I wouldn't single out hydro brakes for that. Curious what kind of riding was being done in the other cases. Seems you'd have to be hauling serious a$$ to pull a hydro line out of the fittings by snagging a tree branch. I'd hate to see what the rider looked like. And in a crash, I suppose anything can happen. If the h-bars whipped around, I suppose a pulled hydro line could happen.
    I've been on hydros for 9 years, though, and have been riding with folks using them for a little longer than that (10 or so, I think) and have yet to witness a failure on the trail. Same with cable failures, except that amount of time extends a little bit longer to about 13yrs. I have never witnessed a cable failure (brake or drivetrain) on the trail.
    Lots of drivetrain problems, though. I've personally snapped a few chains, mangled a few derailleurs, bent chainrings and cassette cogs. Sometimes you gotta walk out, or improvise something and limp out. The broken cable fixing bolt happened on the trail. It was my rear brake. I limped out with just my front brake that day. Mangled derailleurs/hangers, bend it the best I can, set the limit screws and SS it.
    I suppose if you REALLY wanted to, you could also carry spares to repair a hydro line failure, if you were far enough out there. A spare length of line, a syringe, and spare fluid. A brake that uses mineral oil would be less toxic to do a trailside bleed. It wouldn't be a perfect bleed, but it'd get you at least a partially functional brake. Not as light as carrying a spare cable, but it'd work.
    Reputation: shiggy's Avatar
    Dec 1998
    It has been done, when MTB disc brakes were first being developed. Lots of cable operated hydro calipers. There was too little fluid in the system which would overheat, expand and lock the brake.
    In the best case, they would tougher to setup and maintain the either full hydros or cable brakes.
    mtbtires.com
    Anti-elitist
    Sep 2012
    I've heard of heat related lock ups with modern hydros too. I think it was something like "I drove with it in the back for a couple hours, and when I took it out, brakes were locked." Maybe he was using bad fluid?
    Dec 1998
    Not the same thing .I have not heard of current hydro brakes locking because of fluid expansion, especially just because it was in a hot car. the temp needed is MUCH higher.
    The old brakes could lock in use WHILE descending, bringing the bike to a sudden and unwanted stop. Could need to wait 1/2 hour to cool before the wheels would move again.
    mtbtires.com
    Anti-elitist
    Sep 2012
    OK lets get back on topic here. What are the advantages of a mechanical "dual Banger" design other than easy centering? Does having two dynamic pads on a mech make sense? I have yet to see a satisfactory answer.
    'Tis but a scratch
    I have hydro on 1 bike and mech on the other. I love the "set it and forget it" of hydro, plus the braking power and self-adjusting nature. I do think there is an exposure to catastrophic failure if a line breaks. Although it has never happened to me. I struggle to imagine a scenario where I wouldn't be able to trail repair mechs. They are easy to set-up but do require occasional tweaking. I don't like that you are somewhat flexing the rotor on mechs by only having 1 moving side. It would be nice to get the hydro features on a mech system, but it seems like the cost to accomplish that will put you right in the price range of some hydros. Hmmm. Interesting dialogue though.
    AZ
    AZ is offline
    I have not seen any better performing mechanical brake than BB7's,
    Anti-elitist
    Sep 2012
    :groan:... I just want to know guys. Does it or does it not make sense to have two way pad movement on a mech?!
    If something like the IRD Dual Banger can rival the power and modulation of BB7 and some hydros, can we conclude that it is because of the 2 way design?
    Anti-elitist
    Sep 2012
    Srsly... would anybody like mechs to have both pads move rather than have one fixed pad? Anybody at all? Please?
    AZ
    AZ is offline
    We the people ...
    This was answered in post #2.
    Anti-elitist
    Sep 2012
    That only outlined what was wrong with the design. The feature was never addressed. So far, nobody has said anything about how having two dynamic pads increases performance.
    Dec 1998
    It does not make sense to add to the complexity of a mechanical caliper when the BB7 works so well as is. I have been using the Avids on almost every bike I own since 2000 with no issues with performance.
    As always, setup is key. If the rotor is flexing more than a small fraction of a millimeter, it is not right.
    mtbtires.com
    I thought you had Tektro Novela mechanical brakes. You changed them out for shimanos?
    sauprankul's Motobecane Elite Trail Review
    Seriously though, I'm not really understanding this beginner's fear of hydro's you're talking about. Personally i got some BB7's but I got them because both calipers and rotors cost me $89 dollars total. If XTR's were that price I would be all over that in a second. If you're still running the stock tektro novela's that came with your bike, I'd suggest you change them out for something better. Once you do, you won't have any urges to come up with new brake designs, cause you're stopping power will be more than enough. And if you're still running the integrated shimano ef51 brake/shifters, change those out too. I started on those too, and ran those with my bb7's for about a week before my Speed dials arrived. Those brake levers really suck. The SD7's made a world of difference. There are brakes currently on the market, both mech and hydro, that have you saying "holy shiz" everytime you pull the lever cause they are just so badass at stopping. If Tektro Novela's are all you've ever experienced, I don't think you have enough experience yet with brake systems to critique their designs.
    yukonjak
    I feel the benifit of the hydros just the way they are is you don't get cable stick in the water and mud, the only problem I've had is a leak between the two halves of the caliper I noticed my lever getting farther in then normal and seen the leak, but I was still able to finish the ride and had to just replace the o-ring in the caliper been great ever since. They just work good and noobs will try them and not go back to cable.
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    Not afraid of hydros, like was said earlier, cars have had 'em forever -- the main reason I don't want 'em on my bike, I hate bleeding brakes!
    My BB7's are wonderful -- ceramic pads give me modulation AND power (one-finger braking, strong enough for OTB if I'm not careful), and I discovered that XTR CABLES can make 'em feel as smooooth as hydros! Self-adjusting pistons, meh; I have to adjust my BB7's maybe 3x/year. I'm going to replace the pads this winter, with ceramics again, and the old ones will have given me 4 years of flawless service. Jagwire cables aren't as good as XTR, but they'll do for another year.
    A bike is the only drug with no bad side effects....
    Jan 2011
    I remember my first mech brakes, purchased back in 2000, Formula mech disc brake. it was a right royal PITA. Around the same time Avid released their mech brakes, it was a big improvement, but it still required constant adjusting, same concept. Still in 2000, I bought XT hydro's (4 pot Grimeca knock off) and it was night and day difference. No adjusting, no maintenance, it was a no brainer. As for bleeding, I never bled the XT's for as long as I've owned them, same with the purple hayes I owned, same goes for all the Hydro's I"ve owned.
    2000 was a great year, I remember Stan debuting his Stans no tubes here at mtbr...good ol days.
    Jan 2011
    Oh really now, how the hell is it a 5 minute fix? Seriously, I need to know because you seem to be talking bs. YOU assume people carry spare cables with them while riding.
    I don't know anyone that just has a rear brake or front brake, so how would you be riding back with no brakes? (its rhetorical)
    I hate that name.
    Reputation: blunderbuss's Avatar
    Quote Originally Posted by shiggy View Post
    I don't know... it got really hot here this summer and we saw a lot of bikes coming in with pumped up brakes. Florida doesn't have any descents long enough to generate that kind of heat.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Anti-elitist
    Sep 2012
    Quote Originally Posted by JohnDoH View Post
    Ouch. I'm bleeding (bazinga! ). But you're right. I'm not SUPER xped. But I never criticized any design either. I just thought that it would be nice to have a mech brake with two way pad movement.
    Apparently it wouldn't be because so far nobody has said anything about how that affects performance. Let's see if people can FORGET ABOUT THE OPENING POST and answer the question I've asked at least 3 times in this thread, to no avail.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Magura built the Gustavs like this. They were crazy powerful, but overly complicated/heavy with the sliding pins.
    RS/Amp built the hydro calipers actuated by cables. Again, the worst of both worlds.
    I've never seen a valid reason for against hydros, but I have seen some companies with shoddy quality control making hydros. Avid has always been able to make very "grippy" brakes that stop you well, but I've had leaks, inconsistencies, poor ergonomics, and other problems, and that's just with mine. My avid mechs were even worse, overheating, pad adjustment backing itself out, extremely poor pad wear, etc. You don't need to spend a lot these days to get a decent hydro brake...but for a while at least, you did need to steer clear of avid. I suggest Shimano, Hope, and a few others.
    AZ
    AZ is offline
    My experiences with Avid hydro's has been the polar opposite, 3 years on one set with one bleed when I shortened the hoses. YMMV.
    Dec 1998
    I addressed your question. You may not like the answer
    mtbtires.com
    Always in the wrong gear
    Reputation: Coondog#77's Avatar
    To be honest the first thing I did to my bike was upgrade to Hydros. I don't trust mechanical's ever since I had a cable break when I was younger.
    Anti-elitist
    Sep 2012
    Hmm... so far people have said the following: (No particular order)
    My "idea" sucks.
    There was never any reason for it: mechs are fine as is.
    Mechs are actually harder to maintain than hydros, but are less intimidating to beginners
    Mechs have an advantage only when repairing on the trail. (And in the case of a snag)
    There is ABSOLUTELY NO REASON for mechs to have opposed pad movement. Even thinking about it is a waste of time. That wouldn't help the power or modulation or feel in any way at all.
    BB7s are the best mech around.
    Anything else?
    My "idea" sucks.
    Anything else?
    Hey Sauprankul, can I ask you a question? Have you ever actually ridden on a real trail? Like in a forest or some mountains? Anything other than just roads? Cause according to your thread Motobecane Elite Trail Review, your bike has 1.5" tires. If you can take that bike out on a real trail (with rocks, twigs, branches, leaves, acorns, etc) and walk away unscathed, you must have some of the best bike handling skills of anyone on this forum. And why is this important? Cause you keep asking how mechs can be better, when you actually don't really know what decent mechs (or hydros) can do, because you've never actually ridden on a real trail. When I first got my bike with stock tektro novelas, I rode it around the streets with my wife, and I thought the brakes were great. They stopped OK. Then I went on a real trail here in the Ozark Mountains of Arkansas and soon thought "man I'm gonna kill myself if I don't change out these brakes". Because those tektros just wouldn't stop the bike when I was hammering down a rocky hill. And when the BB7's were installed, I then thought "damn this is sweet, I can stop whenever I want to, however I want to". After that there really wasn't much thought about why BB7's didn't have dual calipers moving, or wouldn't it be better if they designed this or that into them.
    So my point is, maybe no one is answering or wants to answer your question because no one really feels compelled to do so. Because everyone has found brakes (either mechs or hydros) that are adequate for them. And if people like what they got, than who cares if it got one caliper moving or 2 calipers moving. You, however, seem to not like your tektro novelas, so why don't you get something better and then decide if mechs really need to have 2 moving calipers. Another thing is, I don't really know how you would be able to accurately judge if one brake system was better than another anyway. This is due to your 1.5" tires. Tires have alot to do with braking, too. And I'd imagine 1.5" tires would skid all over the place, on loose stuff, on a real trail, everytime you apply the brakes, no matter what kind of brake you had.
    You know what, after contemplating long and hard about your idea, I've decided that you are right. Mech systems need more than one caliper. In fact, 2 moving calipers is not enough. I think they need 4 moving calipers. One caliper on the top, bottom, left, and right of each rotor. That's right, 4 avid BB7 calipers per rotor. And since you pioneered this breakthrough, I'll let you patent the idea. No wait..I got a better idea....
    TWO rotors per wheel. That's right, you heard it here first, peeps. 2 rotors per wheel, one on each side of the wheel. AND, 4 calipers per rotor, for a total of 8 moving calipers per wheel. I really think we're on to something here. And maybe we might even be able to keep the weight of each wheel under 10lbs. Sauprankul...See you at interbike
    Jan 2011
    My "idea" sucks.
    Anything else?
    Youir idea "sucks" because you are over complicating matters.
    Mech's aren't for newbies. Unless you are familiar with adjusting pad to rotor clearance, I'd stick with hydro's. People assume mech's are simpler than hydro's, you don't have ongoing adjustments with hydro's, so imm that makes hydro's easier to deal with.
    As for repairing on the trail, thats a load of bs, UNLESS you carry spare cables with you while riding. And it's not like your losing both brakes at the same time.
    Because mechs only have one moving pad, it's just not going to have the same stopping power as hydro's.
    If you are dead set on mechs, the BB7 is the best currently on the market.
    ****** to the dirt
    Reputation: deke505's Avatar
    Quote Originally Posted by SV11 View Post
    I rode and still do with some extra cables. With mechs even if yo don't have cable you can always jerry rig something with a little imagination.
    Jan 2011
    Hence why in my previous post I said mechs aren't for newbies.
    Let's not forget, this thread was started by a newbie, as far as I know newbies don't carry that sort of gear with them because newbies aren't mechanically inclined.
    I can understand carrying spare tubes, but there's no reason to carry spare cables. If you're breaking cables then you are doing something wrong.
    Nov 2012
    WTB IRD or WINZIP Mech Disc brakes
    looking to buy Front IRD Dual Bangers or Winzip mech disc brakes.
    private message pref. Thanks.
    ****** to the dirt
    Quote Originally Posted by Brakedancer View Post
    you could always try here as well.
    Disc Brakes - Buy and Sell and Review Mountain Bikes and Accessories
  67. #67
    Two rotors on the front wheel has already been done
    The mid 90s marzocchi bomber came with dual front disc brake mounts for exactly that. However it didn't come with a dual disc hub.
    Double disc mount Marzocchi Bomber
  68. #68
    rho
    rho is offline
    Life is strange
    Reputation: rho's Avatar
    Ive never had an issue with a brake cable ever, but ive had shifter cables break inside the shifter on both my cx bike and on my mtb. Both with less than six months on said cables.
    Stuff happens and as such when I head out into the back country a new shifter cable comes With me.
    Sent by smoke signal.
  69. #69
    I like turtles
    Reputation: TiGeo's Avatar
    Your idea seems overly complicated but interesting non the less!
    I have had both Avid mechanical (BB7) and hydro (Elixir). Both are great and easy (for me) to deal with. The BB7s needed constant tinkering with the in/outboard pad adjusters..almost every ride. They worked amazing on my rigid SS. My Elixirs were noisy/vibrated at first, fixed it with organic pads/new rotors. They are easy to deal with...you don't mess with them! Bleeding isn't hard, but I certainly understand someone who isn't mechanically inclined paying for this service. Overall, for me the hydros have been less hassle.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
