Results 1 to 19 of 19
    Dec 2011
    CO2 or mini pump
    I had a road bike for a while and carried a CO2 inflator with me to inflate a spare tire if needed. Do those work for mountain bikes as well or is it too little air to inflate a mountain bike tire 29?
    Reputation: PG256's Avatar
    If you have a big enough or multiple CO2 canisters you can fill a 29" tire.
    injured reserve list
    Reputation: Scrub's Avatar
    If you're racing XC/Enduro go with CO2's for quick a quick fix on the trail to get back in the race.
    You're not entitled to anything until you work hard and earn it. CMQ
    Jonesin'
    Reputation: ForrestJones's Avatar
    I started off with a CO2, because I thought it was a cool widget and wanted to try one. Plenty of air to fill a 26" MTB tire with air to spare. In fact I think I got 2 fill-ups per can.
    I got sick of having to buy the canisters, and bought a frame pump instead. Its the way to go unless racing.
    Don't let it get you down, but there's a good chance you were an accident.
    2017 SC 5010
    Reputation: 2wheelsnotfour's Avatar
    Aug 2010
    I carry both a frame pump and CO2. I use the CO2 for convenience and ease and carry the pump as a back up. I also carry two tubes. I don't like farting around with patches.
    Rides the Desert
    Reputation: ltk1144's Avatar
    Dec 2011
    I use a pump, attached to my frame. Mines got a foot stand and a short little tube. Kinda unique.
    Reputation: kingbozo's Avatar
    Quote Originally Posted by ForrestJones View Post
    Or if you live in an area with lots of mosquitoes in summer. One tube change while getting eaten alive resulted in my always having CO2 in the camelback.
    Ride or die
    Reputation: mountainbikeloco's Avatar
    I use a pump that combines both. It is a thin mini pump that also incorporates a co2 feture. So no matter what, I am covered.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Carry both, the co2 inflators fail from time to time.
    bust a move
    Reputation: 2ridealot's Avatar
    Last week I asked my lbs owner about this subject. He said that the standard Co2 cartridge would fill a road tire to 90psi and a 26 mtb tire to 40psi. I have had to mini pump up like 6 road tires this year and it is a biotch. I just ordered a dozen cartridges because of the amount of times I flatted out this year. I will still carry the pump tho
    Reputation: Bob12676's Avatar
    Love the CO2
    I carry a CO2 set up and ride a 29er. I had a tire failure over the summer and as it would turn out the sealant in my tire had all but dried up and I had accidentally pulled the "back up" tube out of my pack at the trail head (I'll never make these mistakes again) The bead had come off completely, I thought I was screwed, never before had I been in the situation. All I had was my CO2 inflator and 2 cartridges. To my surprise, one canister re-seated the bead and filled the tire to, what I would guess was, 30ish lbs. The second cartridge was used sparingly to re-fill when the tire got low. It was enough to get me out of the woods (about a mile) and back to the trail head on dirt roads (another 2-3 miles). I don't think I would have been able to re-seat the bead with a hand pump.
    El Gato Malo
    I use a pump, I'm cheap, and air is free.
    Dec 2011
    I carry one spare tube, patches, and CO2 with with 3 cartridges.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by Trail6 View Post
    Same here, and it's a good arm workout haha!
    bi-winning
    Reputation: rkj__'s Avatar
    Maaaaan
    Reputation: Ericmopar's Avatar
    Aug 2003
    I'm always amazed at how many people with CO2 have asked to borrow my pump over the years.
    Communist Party Member Since 1917.
    Reputation: Pooch's Avatar
    I've had a couple of the small mini pumps and they can take a while to fill a tire. I bought a CO2 inflator and used it once and thought it was the best thing I ever saw. The next ride, I went through 2 tubes which used up all of my cartridges. When I got a third flat, I found out how useless an inflator could be. Now ride with a Topeak Road Morph and will not change from carrying this pump. Not too big that it weighs much but big enough to fill a tire, 29 or road, quickly.
    Self Appointed Judge&Jury
    Oct 2000
    I carry a "Topeak Two Timer" it's a mini pump on one end and a CO2 inflater on the other end. A two in one deal. It is only 7" long and fits unnoticable in my Camelbak. Most shops don't carry them in stock. I just had my LBS special order it for me. And Topeak IMO makes some of the highest quality products in the industry.
    Check it out here. TopeakŪ Cycling Accessories
    I just recently picked up a topeak mini microblaster and its dual action so it pumps when you bring it out and in. So it doesn't take as long as older mini pumps
  1. Best mini pump?
    By edenger in forum Colorado - Front Range
    Last Post: 04-18-2011, 10:01 PM
  2. what mini pump?
    By popawheelie in forum All Mountain
    Last Post: 11-02-2007, 11:15 AM
  3. Replies: 0
    Last Post: 05-27-2006, 08:18 PM
  4. Best Mini pump
    By S-Works in forum Wheels and Tires
    Last Post: 09-21-2005, 05:33 PM
  5. Mini-pump vs CO2
    By martynda in forum General Discussion
    Last Post: 09-04-2004, 07:41 PM
