Results 1 to 3 of 3
    Jul 2013
    Chain Slipping - Giant Yukon
    Hey Everyone,
    Got a quick question for anyone who may have experience with this problem. I have a 2001 Giant Yukon with a Shimano Deore shifter system. All stock parts. Recently, the chain began to slip when I am in the second gear on the front and gears 2-6 on the back. It usually happens when I go over bumps when I am pedaling hard. As a result, I try to keep it in 1st gear up front and a really high gear in the back (I think the tension might prevent it from slipping in this case?) In any event, I do not know how to fix this. I tried to adjust the rear shifter springs by tightening some screws and it did not work. It does seem like my teeth are worn down in the rear but I don't know if it is the problem. Can I fix this by getting a new, tighter chain? Do I need to adjust the tension on the chain some other way? Do I need new rear gears? Or should I just take it in to the shop?
    Thank you!
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    If your cassette is 12 years old it is time to replace it and replace the chain at the same time
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    You probley need new chain rings too. You can measure the chain for wear with a 1' ruler ,it should be 12"from pin to pin.
  1. 2005 giant reign 2(with mods) vs 2009 giant yukon fx
    By zoltanthehungarian in forum All Mountain
    Last Post: 03-06-2014, 02:06 PM
  2. My old new Giant Yukon
    By mrspickless in forum Beginner's Corner
    Last Post: 08-06-2011, 12:55 AM
  3. Old Giant Yukon
    By VTguy in forum Giant
    Last Post: 08-04-2011, 02:00 PM
  4. Replies: 7
    Last Post: 05-01-2011, 06:49 PM
  5. Replies: 2
    Last Post: 04-05-2011, 09:54 PM
