Results 1 to 9 of 9
    Mar 2013
    chain ring bolt spinning
    so, i bought some new chain ring bolts. and i cant tighten them cuz they keep spinning... is there a technique to hold the back oart so it doesnt spin, or a tool?
    please help. thx in advance!
    Search for "chainring nut wrench"
    Apr 2013
    if there is two small slots on the back side (as if it were a flat head bolt and it now has a hole drilled throught he center) You could try holding it from spining with a narow blade flat head screw driver. Once you get some tension on them they should stop spinning but Iknow that is not always the case.
    Apr 2013
    I just looked up the chain ring nut wrench, that is pretty cool. Looks like it would be pretty easy to make one but at 4 to 5$ you could just buy one and save the hassle
    I've never had a problem just holding the backside with my finger tip held tightly against the fastener, until tension/friction takes over.
    Reputation: J.B. Weld's Avatar
    If you grease the threads you are more likely to be able to get them tight without a chainring bolt wrench.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    The chainring bolts could be too long also.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Grease the chainring bolt threads. (EDIT: as J.B. Weld already said while I was entertaining myself in another tab.) It's a good practice anyways.
    That way the clamping force becomes high enough to hold the backside against the spider (or middle ring) before rotational friction of tightening the bolt starts turning the backside along.
    If this fails, superglue the backside to the spider (or middle ring).
    Or just yield and get the tool.
  1. Loking for a 20 tooth 4 bolt chain ring.
    By Flooredsubaru in forum 29er Bikes
    Last Post: 01-22-2013, 11:40 PM
  2. Chain ring bolt question
    By Onie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 12:19 PM
  3. Chain Ring bolt wrench/tool
    By giantbikeboy in forum Tooltime
    Last Post: 11-09-2011, 04:53 PM
  4. Chain ring bolt size
    By jdgang in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2011, 08:12 PM
  5. Chain Ring Bolt options
    By Rad Rider 415 in forum Beginner's Corner
    Last Post: 02-25-2011, 07:37 PM
