Results 1 to 13 of 13
    Reputation: tailwaters's Avatar
    Carbon Seat Post
    Just purchased a Hylix carbon seat post with off-set in 400mm for my new Niner EMD. I installed it last night and it looks great however I noticed this thing has a fair amount of flex. I've never run carbon before so this makes me a bit nervous. Is this typical out of a carbon seat post?
    Reputation: IndianaXC's Avatar
    Yes, thats the whole reason to run a carbon post since i makes for a slightly more forgiving ride.
    Giant XTC Composite 29er, SID XX World Cup fork, AC Race 29 wheels
    Giant TCR advanced with Ultegra Di2
    May 2005
    IMO, flex is good, assuming it's designed that way. I've been using carbon windsurfing masts for 15 years and they deflect a lot under load, sometimes 30+ deg. and usually last a long time
    Can you post some pics of the post? The one's on eBay are not very good.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    Don't know about yours, but my Bontrager ACC has an aluminum core. It does flex, but it won't snap as easily.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    that's because it's not 29'er infused carpet fiber
    moved to general
    Click Here for Forum Rules
    BM and PQ Trail Rep
    Reputation: bankerboy's Avatar
    Got the popcorn ready for the inevitable carbon debate....
    Carbon, fantastic light weight and strong or are we completely fooled by the industry trying to sell us inferior product so they can make a buck?
    The world does not revolve around you but your actions impact us all!
    Dec 2011
    running the 9er carbon post and it flexes somewhat but not as much as the RDO. I like it so far
    Oct 2007
    Engineering wise carbon fiber is a poor material choice for seats posts. Here is why. Carbon Fiber is designed to work under tension. Don't believe me, have you ever tried to push on a rope? It doesn't work. So the next question is why do companies build seat posts out of carbon fiber? Mainly because of the cool factor and some will argue because it provides a more compliant comfortable ride.
    Since all seat posts are under what engineers call "Buckling loads." lets look at the equation for buckling.
    Buckling - Wikipedia, the free encyclopedia
    Critical Force= (pie*pie*modulas of elasticity*aera moment of inertia) / (load factor*length)^2
    So looking at the equation here is what we need to do in order to maximize how much load our seat post can take before it fails.
    1)We want to maximize the modulas of elesaticity by selecting the proper material.
    2)We want to maximize the area moment of inertia, this means using the largest diameter seatpost we can get and using the thinest allowable wall thickness.
    3)We want to keep the seat post as short as possible as length is a squared term. (very bad!)
    Understanding that you can now understand why LJ Thompson makes the bench mark seatpost in the bicycle industry. Thompson has done a lot of engineering work to optimize the cross sectional area (moment area of inertia) of the seat mast.
    As you can see Thompson puts more material where the greatest stresses are in the seat post which is in the front of and the back of the seat mast. Since the sides of the seat mast see the least amount of stress the side walls are left thinner.
    Reputation: Brewtality's Avatar
    Quote Originally Posted by Fortuitous View Post
    None of my carbon posts failed, but one of my Thompson posts did. If only they put more material on the sides...
    That pic appears to show abrasion and impact damage to your seatpost.
    Thats not a failure of the seatpost per se. Most likely any seatpost would have dented in that situation, regardless of the design or construction material.
    Its all Shits and Giggles until somebody Giggles and Shits
    Just a routine impact.
    I don't consider any impact as 'routine'.
    Well the seat post in question was in fact purchased on ebay and came from overseas. Here's a pic. I've read some good reviews on their products but like I said this is my first carbon seat post and the flex is a new thing to me. The model I purchased is the offset model but same brand.
    Actually the Hylix carbon post has this same feature. I got one a few weeks ago and havent had a chance to ride it yet so cant comment on the durability or flexibility issues...
    Oct 2007
    Unless your bicycle came orginally with a carbon seat post I don't recommend using them. In fact most bicycle component manufacters are slowly moving away from them.
  1. DIY/Ghetto Adjustable Seat Post
    By DirtyMartini in forum Tooltime
    Last Post: 03-04-2016, 04:04 PM
  2. Grip glue for slipping seat post on carbon frame?
    By Will Goes Boing in forum General Discussion
    Last Post: 11-11-2011, 10:33 AM
  3. Rush Carbon seat post clamp
    By ASI CA in forum Cannondale
    Last Post: 05-20-2010, 08:40 AM
  4. Scratched - Carbon Seat Post
    By Norco1982 in forum All Mountain
    Last Post: 10-26-2009, 07:10 PM
  5. Carbon SEAT post? Crazy
    By BigDaddyJT in forum Clydesdales/Tall Riders
    Last Post: 11-08-2004, 04:29 PM
