Results 1 to 9 of 9
    May 2010
    Carbon Bars and Barends
    Is it ok to use barends on carbon bars?
    Reputation: Stugotz's Avatar
    Dec 2011
    You can use them on Niner carbon bars. (I have 'em on mine).
    Five is right out
    Depends on the bars. Some are rated for bar-ends and have enough material or reinforced ends, some are not rated. You should check with the manufacturer's site.
    Oct 2007
    If you using bar ends on a carbon fiber bar you want to make sure that they have the internal metal reinforcements at the tips. I know the Ritchey Logic WCS bars have these reinforcements.
    Another option is Specilaized bar end plugs which you can get at most Specialized dealers. Just double check to see if they are "size" compatiable with your handle bars before you walk out of the store.
    -eddie.
    Guest
    bar ends? tree grabbers? yikes.! good luck sir.
    Reputation: Ryyder's Avatar
    Oct 2011
    been doin it for a long time myself, never had an issue.
    Oct 2007
    Riders that steer their bikes like drunken monkeys shouldn't use barends. They are for experienced riders only.
    Reputation: ecub's Avatar
    Ergon has bar end plugs for carbon bars as well...
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp Disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    Reputation: SeaBass_'s Avatar
    Quote Originally Posted by Stugotz View Post
    +1. Got Ergons on mine. Just use a torque wrench!
  1. Bar Ends on Carbon Bars.
    By 77RRad in forum General Discussion
    Last Post: 05-20-2010, 02:53 PM
  2. Cutting Syntace Carbon Bars???
    By af73 in forum Weight Weenies
    Last Post: 07-09-2009, 05:14 AM
  3. Carbon Bar w/ barends?
    By chowdownca in forum 29er Bikes
    Last Post: 04-20-2008, 09:11 AM
  4. barends on answer hyperlite carbon flatbars ?
    By caballero in forum Weight Weenies
    Last Post: 01-01-2005, 07:56 PM
  5. Which barends for carbon handlebars?
    By CharT in forum Weight Weenies
    Last Post: 09-23-2004, 11:36 PM
